This ain't your grandpa's V-22
Old June 14th 06, 08:54 AM posted to rec.aviation.military.naval
Default This ain't your grandpa's V-22
http://www.nbcsandiego.com/news/9366221/detail.html
"This ain't your grandpa's V-22," said Maj. David Lane, of the U.S.
Marine Corps. "This aircraft is phenomenally safe. I've got a family. I
wouldn't strap myself in if I wasn't comfortable with where it stands
and where it was at."
Has it really been in development that long? ;-)
-HJC
Old June 14th 06, 12:10 PM posted to rec.aviation.military.naval
"Henry J Cobb" wrote in message
-HJC
I think it has been in development forever, :-) at least it seems like it.
DJ
Old June 14th 06, 01:39 PM posted to rec.aviation.military.naval
-HJC
DJ
Probably a lot longer than you're indicating (or that you
know!)...it seems most odd that it's NEVER mentioned in any info
I've seen but this aircraft was designed and flown by Canadair in
Montreal in the EARLY SIXTIES!...it was known as the CL-84
Dynavert. First flew in 1965.
http://tinyurl.com/rk2tj
-Gord.
(use gordon in email)
Old June 14th 06, 02:04 PM posted to rec.aviation.military.naval
Nope, the Dynavert rotated its wings out of the way of the prop airflow
for greater efficiency, so it was a completely different design.
-HJC
Old June 15th 06, 02:49 AM posted to rec.aviation.military.naval
-HJC
No it didn't, it worked exactly like the V-22, both engines were
mounted on the wings which tilted up to the vertical...take a
look at the URL I supplied...
-Gord.
Old June 14th 06, 02:24 PM posted to rec.aviation.military.naval
"Gord Beaman" wrote in message
And then in the 1970s Bell designed and built the XV-15 tilt rotor
demonstration aircraft for NASA research.
http://www.dfrc.nasa.gov/gallery/Photo/XV-15/index.html
JD
Old June 15th 06, 03:05 AM posted to rec.aviation.military.naval
JD
The XV-15 did not tilt the wing (only the engine pods at the
wingtips) as both the CL-84 and the V-22 do.
-Gord.
Old June 15th 06, 05:17 AM posted to rec.aviation.military.naval
JD
Sorry Gord, while the CL-84 was a tiltwing, both the XV-15 and V-22 are
tiltrotors -- the wing stays put when the nacelles rotate. See:
http://www.navair.navy.mil/v22/index...action=gallery.
among many other sites. The vertical 'wing' section you can see in some
shots when the nacelles are vertical are the large flaps, which droop
something like 85 degrees to minimize vertical drag (Dv) when in
helicopter mode.
Guy
Old June 14th 06, 10:08 PM posted to rec.aviation.military.naval
-HJC
DJ
I suppose you believe that the development of the SR-71 started on a
windy day at Kitty Hawk too, eh?
KenG
Old June 15th 06, 03:07 AM posted to rec.aviation.military.naval
-HJC
DJ
KenG
Don't seem to know much about aircraft do you?...
-Gord.
