A question on reversers
Old June 24th 06, 11:48 AM posted to rec.aviation.piloting
Default A question on reversers
If you float in above the threshold a fair bit higher than Vref, is it
acceptable technique to chance the reverser to preclude landing too far
down the runway?
Thanks in advance,
Ramapriya
Old June 24th 06, 01:37 PM posted to rec.aviation.piloting
No
Vref is 1.3 Vso and even at higher speed float is not a real
problem, you fly the pitch attitude to a firm landing and
deploy the spoilers. Most jet aircraft have a nose down,
negative wing angle when the nose wheel is on the surface.
You can "plant" a jet and keep it on the ground without the
problem of ballooning off the ground that most light
aircraft encounter.
If you are out of the proper position, the proper procedure
is a go-around.
BTW, it seems you are trying to learn about paining aircraft
(decoy) and how to "speak" pilot, is there any ulterior
motive such as passing a security check with a stolen
airplane painted away from a professional shop and flown by
a crew that isn't qualified?
Vref, is it
landing too far
| down the runway?
| Thanks in advance,
| Ramapriya
Old June 24th 06, 01:38 PM posted to rec.aviation.piloting
down the runway?
Thanks in advance,
Ramapriya
I just open the door and throw out the anchor. Works best on soft grass
runways.
Old June 24th 06, 02:29 PM posted to rec.aviation.piloting
down the runway?
Thanks in advance,
Ramapriya
runways.
That is called a soft-field landing, right? You should use it on all
grass strips, not just the soft ones. Because you never know when one
may be soft, so just assume that and always use the anchor. Worst case
is that the grass runway is hard and it just bounces along behind you.
No hard as long as it doesn't wrap around the tail. :-)
Old June 24th 06, 04:07 PM posted to rec.aviation.piloting
The props on the King Air will reverse in-flight as can the
Pilatus bushplane. There can be some interesting
aerodynamic effects. But very few recreational airplanes
have any sort of reverse. But I agree, jets require the
squat switch (unless there is a malfunction) to deploy
reverse.
James H. Macklin
ATP,CFI,A&P
| On 24 Jun 2006 03:48:13 -0700,
than Vref, is it
landing too far
| down the runway?
| I've only allegedly worked on couple of different types of
buckets,
| all on biz-jets and they have had one thing in common.
| The aircraft must have a weight-on-wheels signal present
somewhere in
| the logic circuit before the reversers will unlock or
deploy.
| Inflight, if a not-locked condition is detected, the
reversers are
| hydraulically driven to the stowed position and pressure
is maintained
| holding them there until the not-locked condition goes
away.
| Unless you are learning to fly the space shuttle:
http://www.nasa.gov/vision/space/pre...week5_sta.html
| http://www.nasaexplores.com/show2_ar....php?id=04-067
| http://www.aopa.org/pilot/features/9703feat.html
| having the buckets out while flying is a RBT (really bad
thing), but
| I'm sure there are some exceptions out there.
http://www.globalsecurity.org/milita...craft/c-17.htm
| TC
Old June 25th 06, 03:51 AM posted to rec.aviation.piloting
reverse.
I read recently the C-5 that crashed at Dover, DE had a #2 engine
reverser unstow right after takeoff. The crew attempted the approach
with full flaps instead of partial flaps per the POH and the sink rate
was too high to overcome.
Old June 27th 06, 12:57 AM posted to rec.aviation.piloting
reverse.
It was an "unlock" indication which is one step before an "unstow". They
shut down the engine in question to prevent an aysmetric deployment.. I
THINK i saw that they had pulled the opposite side engine (#3) back to
idle for some reason (directional control presumably... but I would have
thought the rudder would have enough authority for that..)..
I heard the full flap thing too.. but my version has them retracting
from full to some partial setting, and that the airplane was flying
below the stall speed for that weight and flap setting, and then simple
physics took over.
Dave
Old June 27th 06, 05:31 PM posted to rec.aviation.piloting
"Dave S" wrote in message
ink.net...
reverse.
I heard the full flap thing too.. but my version has them retracting from
full to some partial setting, and that the airplane was flying below the
stall speed for that weight and flap setting, and then simple physics took
over.
Dave
The report also said that after securing the #2, they continued to
operate the #2 thrust lever instead of the #3 which was still operating.
Dead foot, Dead engine.
Al G.
wrote in message ...
On 24 Jun 2006 03:48:13 -0700, wrote:
having the buckets out while flying is a RBT (really bad thing), but
TC
Yup, you found it. The C-17 thrust reversers are certified as flight controls.
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
