Cobra trailer trim.
Old July 18th 06, 03:57 PM posted to rec.aviation.soaring
Bob
Default Cobra trailer trim.
Does anyone have any experience or comments on replacing the vinyl trim
that runs the length on both sides of the trailer. (Mine has faded over
the years but otherwise good.)
What's involved and how difficult?
Thanks,
Bob
Old July 18th 06, 05:02 PM posted to rec.aviation.soaring
Gary Evans[_1_]
Yes, unfortunately I do. My original red strips faded
to black within 2 years and then started cracking.
Just received a set of replacement strips directly
from Cobra for $216 US delivered (not cheap). They
slide onto channels on the frame. Looks easy enough
for a couple of people to install. You have to trim
the ends and refasten with pop rivets included.
the vinyl trim
Thanks,
Bob
Old July 18th 06, 09:31 PM posted to rec.aviation.soaring
Bob
Thanks for the info.
Are the 'new' weather strips UV resistant or will they too fade with
time?
Bob
the vinyl trim
Thanks,
Bob
Old July 18th 06, 05:31 PM posted to rec.aviation.soaring
Bela Szalai
You are lucky. My red trim turned black in just one summer. Colorado UV.
Once it became uniformly black I learned to accept it.
I also learned to replace O-ring in the hydraulic ramp jack in 30 minutes,
an annual chore.
It looks like I need to replace the right tire about every 12-15 K miles,
since wheel toe is not adjustable, replacements easily beats cost of new
axle.
- Béla
------Original Message-----
-Sent: Tuesday, July 18, 2006 8:41 AM
-To: Bela Szalai
-Subject: [r.a.s] Cobra trailer trim.
-Newsgroup: rec.aviation.soaring
-Subject: Cobra trailer trim.
-Author: Greg Arnold
-Date/Time: 15:30 18 July 2006
-T o d d P a t t i s t wrote:
- "Bob" wrote:
- Does anyone have any experience or comments on replacing the vinyl
- trim that runs the length on both sides of the trailer. (Mine has
- faded over the years but otherwise good.)
- I can't answer this (mine has faded too), but I've got a related
- question - where can I get brake shoes for a Cobra trailer?
-Try Williams Soaring in N. California.
Old July 18th 06, 06:08 PM posted to rec.aviation.soaring
Greg Arnold
an annual chore.
Do you make your own O-ring, or do you have a source for one that fits?
axle.
- Béla
Old July 18th 06, 08:43 PM posted to rec.aviation.soaring
chipsoars
Anyone know where I can get the weatherstripping seal on the bottom
half of the trailer. This is what the clamshell closes against.
Also, has anyone replace lights with LED's and mounted a high center
stop light? What bulbs are in the tail lens?
Chip F.
Old July 19th 06, 04:18 AM posted to rec.aviation.soaring
bumper
I installed Maxxima LED replacement brake/turn/tail lights as well as a
high, fin mounted 3rd brake light on my Cobra.
For the fin, it is important to fabricate a wedge of some sort (I used white
plastic) to get the LED perpendicular to the ground, as the beam angle is
narrower than with incandescent lighting.
For the 3rd brake light "logic", I used a relay, with the coil being driven
off one brake/turn and the NO contact on the relay being driven by the other
brake turn. That way the fin brake light is only on when both L & R brake
lights are on.
I used all flush mount lights with rubber grommets. Also mounted LED aux
turn signals on the side of the trailer on the upper clam just above the
existing running lights, amber mid-ship and red at the rear.
bumper ZZ (reverse all after @)
"Dare to be different . . . circle in sink."
"chipsoars" wrote in message
Chip F.
Old July 18th 06, 11:29 PM posted to rec.aviation.soaring
Bubba
First, purchase from Williams Soaring (best price).
Second, The new stuff is difficult to slide into the channel. The
secret is to have 3 people. One person pulling, one pushing and one
feeding makes all the difference.
One person impossible
Two people, all day task
Three have it done in 30 minutes.
Thanks,
Bob
Old July 18th 06, 11:45 PM posted to rec.aviation.soaring
Bela Szalai
How long does it lasts? Same as original?
- Béla
-Sent: Tuesday, July 18, 2006 3:41 PM
-To: Bela Szalai
-Author: Bubba
-Date/Time: 22:30 18 July 2006
-First, purchase from Williams Soaring (best price).
-Second, The new stuff is difficult to slide into the channel.
- The secret is to have 3 people. One person pulling, one
-pushing and one feeding makes all the difference.
-One person impossible
-Two people, all day task
-Three have it done in 30 minutes.
- What's involved and how difficult?
- Thanks,
- Bob
Old July 19th 06, 02:39 AM posted to rec.aviation.soaring
Last year my wife and I replaced the vinyl trim on my Cobra trailer. It
took some muscle to pull the strips through. First, we soaked the trim
in a bucket filled with warm water and dishwashing liquid to add some
slick. The warm water made the vinyl more pliable.
When we started pulling, the first ten feet went easily. Then, the
lubrication wore off. We started over with Pam spray. That worked well.
To pull the vinyl, I used locking pliers. As I pulled, the wife
sprayed.
When the pulling was done, all that was needed was to pop-rivet the
vinyl ends to the trailer.
Then, our arms were tired.
Raul Boerner
Help - Cobra Trailer Trim? WDM Soaring 2 January 12th 05 07:47 PM
Cobra Trailer Hookup [email protected] Soaring 12 January 12th 05 03:08 PM
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 04:38 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 03:21 PM
