74 Archer ignition switch question
Old September 10th 06, 12:14 AM posted to rec.aviation.owning
Mike Noel
Default 74 Archer ignition switch question
My ignition switch occasionally locks up (with the key inserted) in the off
position when I try to start the engine. At first I thought it might be a
worn key and pulled out my spare figuring it would fix the problem. No such
luck. I have to fiddle with it to get it unstuck. The first time it
happened I sprayed a bit of silicone lubricant into the slot and eventually
it came unstuck, but it has happened several times since then. I think it
is time to replace the switch.
The parts manual indicates 10-357210-1 for my serial number PA-28-180, but
that part has a push function in the start position (for priming?) that my
aircraft doesn't have. The other choice in the manual is 10-357200-1 that,
from the description, sounds like my switch.
Has anyone similarly found that their PA-28-180 uses the non-push ignition
switch instead of the push type called out in the manual? I'm guessing the
'push to prime' feature is for IO engines instead of O type that is stock on
Archers.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Old September 10th 06, 01:26 AM posted to rec.aviation.owning
Don Tuite
On Sat, 9 Sep 2006 15:14:59 -0700, "Mike Noel"
Archers.
The push function is just an interlock put there to confuse people
with older PA28s that have separate starter buttons elsewhere on the
panel. (My dad's '48 Nash was the last car I saw like that, but the
tradition carried on in Pipers and Cessnas well into the '60s.) Just
be sure the no-push switch actually has starter connections and isn't
simply a mag switch.
The '73 PA28-180 "Challenger" has the "push" feature on the combined
mag/starter keyswitch. I don't know what that implies for the '74
Archer.
Don
Old September 10th 06, 01:34 AM posted to rec.aviation.owning
Roy Smith
I've driven forklifts with pushbutton starters.
Old September 10th 06, 01:28 AM posted to rec.aviation.owning
john smith
The"push" is what engages the starter Bendix. I flew a 1972 Cherokee Six
with that type of switch. I didn't like it.
Old September 10th 06, 03:00 AM posted to rec.aviation.owning
Jay Honeck
Our '74 Pathfinder has that kind of starter key switch. What's not to
like?
Turn, push, start. It's simple, and it works.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 10th 06, 04:21 AM posted to rec.aviation.owning
john smith
In article .com,
like?
When it is the only airplane with that type of switch in a fleet of 16
flying club aircraft, it makes you scratch your head, squint your eyes
and purse you lips for a moment before you remember why nothing happens
when you turn the key.
Old September 10th 06, 02:10 PM posted to rec.aviation.owning
Jay Honeck
16 aircraft! That's not a club, that's a fleet!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old September 10th 06, 06:27 PM posted to rec.aviation.owning
Mike Spera
These switches are made by Bendix and usually cost around $275 and up.
When you say it "locks up", do you mean that you insert the key in the
slot and the switch will not turn from the "off" posisition? Can you
remove the key easily from the off position when it does this?
Here are a few things to try. First, remove the switch from the panel,
mark down the connections and remove the connections from the switch.
Next, take out the 3 screws holding the thing together. Inspect the
springs and contacts to see if any of them are broken, bent, deformed,
burned, etc. If so, try to clean and/or repair them (180 grit sandpaper
followed by a good cleaning with contact cleaner). Reassemble and see if
it still locks up. If not, the contracts were the problem. I believe
Wag-Aero has an "overhaul kit" that consists of new contacts and
springs. Wag also has new units (push to start and the other kind).
If it still locks up and the contacts/springs looked good and clean, it
is probably the lock itself. A locksmith should be able to disassemble
it and put in new pins or repair it for a lot less than a new complete
unit will cost. These are pretty simple locks. If you have 10,000 hours
on the beast you might consider replacement though.
Good Luck,
Mike
.stuff snipped
Archers.
Old September 10th 06, 07:48 PM posted to rec.aviation.owning
Mike Noel
This one has at the most 3400 hours of use if it is the original switch.
Chief sells the 'no push' version with a 'start' position for about $210. I
believe I'll take a stab at fixing it before buying a new one.
It is the lock that will not let go because it won't turn to the right at
all. The 'no push' version can be had with or without the 'start' position.
I hope that means the 'start' position is a spring loaded twist position
that engages the starter.
Best Regards,
Mike
"Mike Spera" wrote in message
nk.net...
Wag-Aero has an "overhaul kit" that consists of new contacts and springs.
If it still locks up and the contacts/springs looked good and clean, it is
probably the lock itself. A locksmith should be able to disassemble it and
put in new pins or repair it for a lot less than a new complete unit will
cost. These are pretty simple locks. If you have 10,000 hours on the beast
Good Luck,
Mike
off position when I try to start the engine. .stuff snipped
but that part has a push function in the start position (for priming?)
that my aircraft doesn't have. The other choice in the manual is
10-357200-1 that, from the description, sounds like my switch.
ignition switch instead of the push type called out in the manual? I'm
guessing the 'push to prime' feature is for IO engines instead of O type
that is stock on Archers.
Old September 10th 06, 11:46 PM posted to rec.aviation.owning
Mike Noel
News flash...I removed and disassembled the switch as suggested. The only
difficult part of the operation was reconnecting the 5 screw-down connectors
during reassembly.
As I was taking it apart on a clean rag, I noticed small shiny metal
fragments laying on the rag. Looking inside the lock casing, I could see
the outer corner of the trough the lock tumblers locked into was eroded.
Evidently that edge has been eroding for a while to create that tiny pile of
fragments. Each time it took a little extra effort to turn the key from the
locked position, the tumblers were not completely retracted by the key a bit
of metal was chewed from the edge. This was probably initially caused by
aging lubricant in the 30 year old lock.
I think the most recent hard lockups were caused by the metal fragments
preventing the tumblers from retracting. Jiggling the key eventually
knocked loose the offending fragment and allowed to lock to work again for a
while.
I've got my fingers crossed that removing the metal fragments from inside
the lock has solved the problem. Probably some light lubricant in the slot
occasionally should keep the tumblers free and avoid the internal edge
chipping. Thankfully, the way the lock is constructed didn't allow the metal
fragments to reach the internal switch contacts.
Best Regards,
Mike
"Mike Noel" wrote in message
I believe I'll take a stab at fixing it before buying a new one.
position. I hope that means the 'start' position is a spring loaded twist
position that engages the starter.
Best Regards,
Mike
nk.net...
is probably the lock itself. A locksmith should be able to disassemble it
and put in new pins or repair it for a lot less than a new complete unit
will cost. These are pretty simple locks. If you have 10,000 hours on the
Good Luck,
Mike
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Just Ordered: An Ignition Switch and Oil Filter from ACS Larry Smith Home Built 30 October 22nd 03 08:41 AM
Electronic Ignition Andre Home Built 1 September 5th 03 07:15 PM
