FLARM Statistics
Old October 9th 06, 11:07 PM posted to rec.aviation.soaring
John Galloway[_1_]
Default FLARM Statistics
Does anyone know of a source of any statistics that
might indicate the effectiveness or otherwise of FLARM
in reducing the rate collisions between FLARM fitted
gliders in those European countries in which it is
in widespread use?
Thanks in advance.
John Galloway
Old October 10th 06, 08:11 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Dont forget Australia in your theory, John, takeup rates here have been most impressive.
bagger
Old October 10th 06, 07:13 AM posted to rec.aviation.soaring
Sven
John
at the Cape Gliding Club at Worcester, South Africa, the majority of
gliders are FLARM equiped. A recent survey of the experience with Flarm
is to be found at
http://cgcdiary.blogspot.com/2006/09...lse-alarm.html
You will note that the perception of the pilots are very positive about
FLARM.
regards
Sven
in widespread use?
Thanks in advance.
John Galloway
Old October 10th 06, 07:54 AM posted to rec.aviation.soaring
MaD
in widespread use?
Thanks in advance.
John Galloway
Not really statistical proof but all I have. Number of collisions in
Switzerland:
2002 and befo average about 2-3 gld/gld collisions per year, worst
year was about 5!
This is from memory.
The following is from here
http://www.segelflug.ch/d/6safety/pd...elle_97-06.pdf
2003: 2 (1 gld/gld and 1 cable)
2004: 3 (2 gld/gld and 1 cable)
2005: 1 gld/gld
2006: 0 AFAIK
Switzerland has a FLARM equipment rate of about 90%
Regards
Marcel
Old October 10th 06, 08:00 AM posted to rec.aviation.soaring
MaD
Addition to last post: the 2005 collision was the only one involving
FLARM-equipped gliders. They where thermalling together and both pilots
had seen the other one before.
Marcel
Old October 10th 06, 12:05 PM posted to rec.aviation.soaring
Al Eddie
one involving
and both pilots
Marcel
Very interesting.
Your data says a lot in favour of FLARM but this speaks
volumes about these two pilots...!
;o)
Old October 10th 06, 12:09 PM posted to rec.aviation.soaring
Al Eddie
one involving
and both pilots
Marcel
Very interesting.
;o)
Old October 10th 06, 02:14 PM posted to rec.aviation.soaring
Mike Schumann
Another interesting question for the US is what percentage of mid-airs are
between two gliders vs. between a glider and a powered aircraft.
Mike Schumann
"John Galloway" wrote in message
in widespread use?
Thanks in advance.
John Galloway
Old October 10th 06, 07:36 PM posted to rec.aviation.soaring
Ramy
I don't have any numbers but I heard of many more midairs between two
gliders or gliders with tow planes than between gliders and other
powered aircrafts. I'm afraid the White Mountains in Nevada are a
midair waiting to happen. On a good weekend you can have 20-50 gliders
flying in a very narrow band in both directions. It is very difficult,
almost impossible, to spot on time a glider flying straight and level
at closing speeds of over 200 knots, unless you know exactly when and
where to look. Remember, the moving targets we often spot easily are
not the threat, it is the one which don't move on the canopy which will
hit us. If we equip all gliders and tow planes with Flarm you will
significantly reduce midairs, as it has been proved in Europe and OZ.
One would wish that one of the local US manufactures of glider avionics
or an entrepreneur would have try to license flarm in US. If it is
possible to manufacture and sell TPAS like equipments in the US without
liability concerns, it should be possible to sell Flarms.
Just my humble opinion,
Ramy
Mike Schumann
in widespread use?
Thanks in advance.
John Galloway
Old October 10th 06, 08:59 PM posted to rec.aviation.soaring
Mike Schumann
My question is whether introducing another technology that isn't common with
powered aircraft is the answer. I would think that a combination of a
transponder that is visible by ATC and conventional TCAS, along with a low
cost low/power TCAS type device designed for gliders wouldn't be more
appropriate for the US environment.
Mike Schumann
"Ramy" wrote in message
ps.com...
Ramy
are
Mike Schumann
in widespread use?
Thanks in advance.
John Galloway
Glider Crash - Minden? Mitch Soaring 141 September 13th 06 07:31 PM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
Flarm Mal Soaring 4 October 19th 05 08:44 AM
Pilot statistics: SSA vs non-SSA DrJack Soaring 6 March 10th 04 05:55 PM
Safety statistics F.L. Whiteley Soaring 20 September 4th 03 05:50 PM
