![]() Having almost worn out my Pazmany "Landing Gear Design for Light Aircraft" while trying to resolve available materials and my fabrication abilities regarding the main legs, a little help is requested.. Not having access to heat treating and basically being too cheap to purchase HT'd, solid rod or leaf legs , the main gear leg ended up being a 4130 tube sliding inside another, compressing an external Die Spring under landing loads. This has tricycle gear with mains angled slightly aft of main spar and maybe 30 degrees outboard. Gross is anticipated at 950 lbs. Now in a fit of "amateur designer remorse "G, my concern is the "slot" cut lengthwise into the one tube possibly weakening the leg too much considering the "outboard alignment" ?? Additionally visual inspection of any "slot" cracking or through bolt wear would be difficult with external spring and outer tube . Presently considering eliminating the Die Spring approach since a nearby Sonex has a solid 1-1/2" Titanium rod leg and a T-18 grossing at 1500 lbs has concentric heavy wall 4130 legs. To me, both appear to have no shock absorption except in tire deflection. Please feel free to muddy my mental waters G. Thanks, Dick |
Dick wrote:
Having almost worn out my Pazmany "Landing Gear Design for Light Aircraft" while trying to resolve available materials and my fabrication abilities regarding the main legs, a little help is requested.. Not having access to heat treating and basically being too cheap to purchase HT'd, solid rod or leaf legs , the main gear leg ended up being a 4130 tube sliding inside another, compressing an external Die Spring under landing loads. This has tricycle gear with mains angled slightly aft of main spar and maybe 30 degrees outboard. Gross is anticipated at 950 lbs. Now in a fit of "amateur designer remorse "G, my concern is the "slot" cut lengthwise into the one tube possibly weakening the leg too much considering the "outboard alignment" ?? Additionally visual inspection of any "slot" cracking or through bolt wear would be difficult with external spring and outer tube . Presently considering eliminating the Die Spring approach since a nearby Sonex has a solid 1-1/2" Titanium rod leg and a T-18 grossing at 1500 lbs has concentric heavy wall 4130 legs. To me, both appear to have no shock absorption except in tire deflection. Please feel free to muddy my mental waters G. Thanks, Dick I got my Delta gear legs heat treated (6150 steel hardened to C41). I think it was something like $40, plus the shipping to somewhere up around Pittsburgh, PA. |
![]() Dick wrote: the main gear leg ended up being a 4130 tube sliding inside another, compressing an external Die Spring under landing loads. Now in a fit of "amateur designer remorse "G, my concern is the "slot" cut lengthwise into the one tube possibly weakening the leg too much considering the "outboard alignment" ?? Additionally visual inspection of any "slot" cracking or through bolt wear would be difficult with external spring and outer tube . This the use of a slot and a bolt to align and travel limit the gear is a loser in any plane heavier than an ultralight. The Teenie Two used such an approach, and the landing gear is by far the worst aspect of that design. Presently considering eliminating the Die Spring approach since a nearby Sonex has a solid 1-1/2" Titanium rod leg and a T-18 grossing at 1500 lbs has concentric heavy wall 4130 legs. To me, both appear to have no shock absorption except in tire deflection. Let's distinguish between "shock absorption" and "Dampening" first. Contrary to the terminology used in the US, "shock absorption" is a functon of SPRINGS. Contrary to first appearances, both the titanium rod and the 4130 gear legs examples cited are just that, springs. You'll be surprised, once you actually start selecting die springs, just how stiff a spring you need. But springs just STORE energy, you need DAMPENING to destroy it by turning it into heat. Wittman style spring landing gear (which both the T-18 and Sonex are examples of) use the FRICTION of the tires SCRUBBING on the pavement as the damping. The type of spring gear you are proposing actually has VERY LITTLE damping. Certainly less than an oleo or a Wittman style gear. That doesn't mean it's bad. My airplane will have a similar gear ;-) It's just a little less forgiving than gear with effective damping. But the problem of keeping the main gear aligned remains. Here are two approachs for you to think about. The first is nesting SQUARE tubing. You'll have to figure out some external way of limiting travel up and down. This is the way I'm going. The second approach is to retain the round tube and use a scissors. Tony Bingelis' books have some examples of home built scissors (as does Pazmany's), or you can swipe one off a junk C150 nose gear, or P140 nose or main gear. I've seen them chewed out of aluminum plate with not much more than Drill Press technology, or bent up out of 4130. Hummelbirds use this approach. |
flybynightkarmarepair wrote:
the T-18 and Sonex are examples of) use the FRICTION of the tires SCRUBBING on the pavement as the damping. The type of spring gear you The friction in the mounting hardware also provides some damping. I say that because on an old car I used to own (I know, here we go...) the rear shocks absorbers (properly referred to as dampers) were totally worn out (they fell apart in my hands), but the car's motion was still damped (it would just bounce several times first). This was almost totally due to the friction in the suspension bushings. |
On 14 Oct 2006 09:41:10 -0700, "flybynightkarmarepair"
wrote: Let's distinguish between "shock absorption" and "Dampening" first. But springs just STORE energy, you need DAMPENING to destroy it by OUCH is my instructor in systems rolling over in his grave. If we said dampen, he threw a cup of water on us. One DAMPS or uses a DAMPING material ... |
In a previous article, GeorgeB said:
On 14 Oct 2006 09:41:10 -0700, "flybynightkarmarepair" wrote: Let's distinguish between "shock absorption" and "Dampening" first. But springs just STORE energy, you need DAMPENING to destroy it by OUCH is my instructor in systems rolling over in his grave. If we said dampen, he threw a cup of water on us. One DAMPS or uses a DAMPING material ... I blame Star Trek: The Next Generation. They used "dampen" incorrectly all the time. -- Paul Tomblin http://blog.xcski.com/ ---------------- hit any user to continue ---------------- |
Saratoga Gear Retract Problem | Yahoo! News | Owning | 16 | November 29th 05 11:17 PM |
Titanium landing gear | Neal Fulco | Home Built | 0 | June 17th 04 11:11 PM |
Cessna landing gear legs Reserve MET! | Bill Berle | Home Built | 1 | February 23rd 04 12:31 AM |
Cessna landing gear legs Reserve MET! | Bill Berle | Aviation Marketplace | 0 | February 22nd 04 07:50 PM |
Cessna landing gear legs Reserve MET! | Bill Berle | Restoration | 0 | February 22nd 04 07:50 PM |
