Does flying leave you sore if you haven't flown in a while or if you
are new to flying? I'm thinking of muscle fatigue from being in an unusual position for long periods, and in particular I'm wondering if keeping one's feet on rudder pedals for hours at a time leads to any soreness afterwards. Or do you even keep your feet on the pedals all the time? Since apparently most autopilots don't use the rudder, even running on autopilot might not eliminate the need to have feet on the rudder (?). And if pushing the pedals forward applies the brakes, does this mean that you have to hold your foot back whenever it's resting on the pedal? Does it hurt anything to apply the brakes in flight? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: Does flying leave you sore if you haven't flown in a while or if you are new to flying? I'm thinking of muscle fatigue from being in an unusual position for long periods, and in particular I'm wondering if keeping one's feet on rudder pedals for hours at a time leads to any soreness afterwards. Or do you even keep your feet on the pedals all the time? Since apparently most autopilots don't use the rudder, even running on autopilot might not eliminate the need to have feet on the rudder (?). And if pushing the pedals forward applies the brakes, does this mean that you have to hold your foot back whenever it's resting on the pedal? Does it hurt anything to apply the brakes in flight? Not much reason to touch the rudders in straight and level flight. My plane has an interconnect too so the rudders happen automatically when I use the ailerons (nearly all high performance planes do). Its not much different than sitting in a car exept that you don't get the fatigue of having to watch the road. The rudder has nothing to do with the brakes. I wouldn't touch the brakes while the gear is retracted. Probably ok, but I wouldn't mess with it. The rudders are lighter when the gear is up anyway since you aren't moving the nose wheel. -Robert |
are new to flying? I'm thinking of muscle fatigue from being in an unusual position for long periods, and in particular I'm wondering if keeping one's feet on rudder pedals for hours at a time leads to any soreness afterwards. Or do you even keep your feet on the pedals all the time? Nope. Most spam cans are stable in level flight, and -- since most flight is level -- your feet can remain firmly planted on the floor. The only time my feet are on the rudders is during take-offs, landings, and maneuvers. Since apparently most autopilots don't use the rudder, even running on autopilot might not eliminate the need to have feet on the rudder (?). And if pushing the pedals forward applies the brakes, does this mean that you have to hold your foot back whenever it's resting on the pedal? Does it hurt anything to apply the brakes in flight? One thing I've noticed with the CH pedals that we bought for the Kiwi (our flight sim) -- it's too easy to fly around with the toe brakes on. It's something to do with the angle they're mounted at, and -- even with them permanently mounted in the Kiwi at a more accurate angle, it still happens all the time. Real aircraft rudders (that have toe brakes) don't work that way, so, no, you don't have to hold your toes back whenever your feet are resting on the pedals. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck writes:
Nope. Most spam cans are stable in level flight, and -- since most flight is level -- your feet can remain firmly planted on the floor. The only time my feet are on the rudders is during take-offs, landings, and maneuvers. Does placing your feet back on the pedals cause any movement in the rudder, or is it more resistant to inadvertent movement than that? One thing I've noticed with the CH pedals that we bought for the Kiwi (our flight sim) -- it's too easy to fly around with the toe brakes on. Yes, that seems to be a problem with sim pedals. You can set the dead zone higher on the brakes to avoid actually having them applied, but you might still be pressing forward on the pedals. Real aircraft rudders (that have toe brakes) don't work that way, so, no, you don't have to hold your toes back whenever your feet are resting on the pedals. So how do they work? You have to extend your foot (press the toes forward) to apply the brakes, right? Which in turn implies that you might have to deliberately hold the tip of your foot back in order to avoid applying the brakes. I've always wondered about that. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Does placing your feet back on the pedals cause any movement in the rudder, or is it more resistant to inadvertent movement than that? No, There is some resistance in them to avoid this. One thing I've noticed with the CH pedals that we bought for the Kiwi (our flight sim) -- it's too easy to fly around with the toe brakes on. Yes, that seems to be a problem with sim pedals. You can set the dead zone higher on the brakes to avoid actually having them applied, but you might still be pressing forward on the pedals. Keyword, SIM. No replicated product will really work how they do in the real thing. So how do they work? You have to extend your foot (press the toes forward) to apply the brakes, right? Which in turn implies that you might have to deliberately hold the tip of your foot back in order to avoid applying the brakes. I've always wondered about that You push the top of the rudder in order to use the brakes. but they have a nice bit of resistance in them so u can push your whole foot to move the rudder/nose wheel without applying the brakes. so u do not need to hold the top of your foot off the rudder to aviod useing the brakes. |
VH-UNR writes:
Keyword, SIM. No replicated product will really work how they do in the real thing. Not surprising, since they don't work the same in any two aircraft, either. You push the top of the rudder in order to use the brakes. but they have a nice bit of resistance in them so u can push your whole foot to move the rudder/nose wheel without applying the brakes. so u do not need to hold the top of your foot off the rudder to aviod useing the brakes. OK. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: So how do they work? You have to extend your foot (press the toes forward) to apply the brakes, right? Which in turn implies that you might have to deliberately hold the tip of your foot back in order to avoid applying the brakes. I've always wondered about that. Unless your feet are more than about 15" you can't reach the brakes with your heals on the floor. When you need the brakes you simply slide your feet up the peddle to hit the brake and then come back down. I used to fly an Aeronca with a heal brake and a puck tailwheel. About 1/2 the landings required brake to stay aligned (since the puck has such little friction with the ground), but the heal brake is basically either on or off. You so straighten a landing out by "pumping" the heal brake to avoid over braking. It was certainly better than the J-3 though. I always flew with slippers because that is the only way I could wrap my feet around the top of the rudder to reach the brake. I kept real shoes in the back in case I had to land somewhere. -Robert |
As Oral Roberts would say to a sinner, "Heel!, heel!"
Bob Gardner "Robert M. Gary" wrote in message oups.com... Mxsmanic wrote: So how do they work? You have to extend your foot (press the toes forward) to apply the brakes, right? Which in turn implies that you might have to deliberately hold the tip of your foot back in order to avoid applying the brakes. I've always wondered about that. Unless your feet are more than about 15" you can't reach the brakes with your heals on the floor. When you need the brakes you simply slide your feet up the peddle to hit the brake and then come back down. I used to fly an Aeronca with a heal brake and a puck tailwheel. About 1/2 the landings required brake to stay aligned (since the puck has such little friction with the ground), but the heal brake is basically either on or off. You so straighten a landing out by "pumping" the heal brake to avoid over braking. It was certainly better than the J-3 though. I always flew with slippers because that is the only way I could wrap my feet around the top of the rudder to reach the brake. I kept real shoes in the back in case I had to land somewhere. -Robert |
![]() Mxsmanic wrote: Does flying leave you sore if you haven't flown in a while or if you are new to flying? I'm thinking of muscle fatigue from being in an unusual position for long periods, and in particular I'm wondering if keeping one's feet on rudder pedals for hours at a time leads to any soreness afterwards. Or do you even keep your feet on the pedals all the time? Since apparently most autopilots don't use the rudder, even running on autopilot might not eliminate the need to have feet on the rudder (?). And if pushing the pedals forward applies the brakes, does this mean that you have to hold your foot back whenever it's resting on the pedal? Does it hurt anything to apply the brakes in flight? -- Transpose mxsmanic and gmail to reach me by e-mail. For a new pilot, while your on the ground yes, your claves can become sore, because your whole foot is on the rudder peddle, thats if you have toe brakes. once your ready to take off, as my instructor says, part of your pre-takeoff checklist should inclue a saying, heels on floor. The rudder becomes extremely responsive once you start you run up and you should only be placing you balls of your feet on the pedel to control them, still resting your heels on the floor. This is very important during the takeoff roll as your really do not want to hit them brakes. as the other guys said, if your ot having to balance a turn or manouver then you can take you feet of the rudder. |
![]() VH-UNR wrote: Mxsmanic wrote: For a new pilot, while your on the ground yes, your claves can become sore, because your whole foot is on the rudder peddle, You probaby don't want to have your foot on the brake on the ground unless you actually mean to use the brake. I teach my students to taxi with their feet flat on the floor because they would otherwise always drag the brakes during taxi. Most people seem to want to use brake to control taxi speed rather than power, which is not a good habit. -Robert, CFII |
