I would be interested in getting opinions about backup systems for a
vacuum pump failure and/or AI failure. I have a 172P with a single vacuum pump system, standard instruments otherwise, and a Garmin 430. I am most concerned about having a good backup if I lose a vacuum pump or AI in IMC. I have been thinking about either a Garmin 396/496 or the electric AI available from Sporty's. Looks like I could get a 396 or installed electric AI for about the same price ($2200 or so). While I haven't seen the panel page/"6-pack" page on the 396 or 496, I have read (in Aviation Consumer) that it's good enough to keep control of the airplane in an emergency situation. Obviously, the 396/496 has a number of other neat features such as inflight weather, terrain info, etc. Any suggestions on which way to go with this. BTW, I had also considered the Precise Flight backup vacuum system for a while, and it certainly is cheaper (around $700 installed). However, I was concerned by the fact that it would do nothing for you in the event of failure of the AI vs. the primary vacuum pump. Thanks. Kelly |
: BTW, I had also considered the Precise Flight backup vacuum system for
: a while, and it certainly is cheaper (around $700 installed). However, : I was concerned by the fact that it would do nothing for you in the : event of failure of the AI vs. the primary vacuum pump. The DG will still work though. In something like the 172 (or my Cherokee), that's a good chunk of the necessary gyro for IMC. What about a non-TSO'd electric AI? Seems like one should be able to install one of those for backup purposes. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() "Kelly" writes: I would be interested in getting opinions about backup systems for a vacuum pump failure and/or AI failure. I have a 172P [...] Considering the nature of the 172, you likely don't engage in too much heavy duty IMC, so backup equipment could be of the "help me land now" kind rather than "help me fly for a few hours more" kind. [...] While I haven't seen the panel page/"6-pack" page on the 396 or 496, I have read (in Aviation Consumer) that it's good enough to keep control of the airplane in an emergency situation. [...] You should also consider the iQue3600a, which has essentially the same aviation features as the 396, at half the price, and with ground-side utility as PDA and car GPS. (The other backup technologies you mentioned have no separate ground utility.) In any case, you should test it out. Borrow someone's 296/396/496/iQue or other portable aviation GPS, set it up in your cockpit, go under the hood and do some partial-panel with a mostly covered-up instrument panel. An hour or two might suffice. - FChE |
![]() A Lieberma writes: (Hm, I am talking to myself. :-) Considering the nature of the 172, you likely don't engage in too much heavy duty IMC, so backup equipment could be of the "help me land now" kind rather than "help me fly for a few hours more" kind. Why would you say this based on a model of a plane? [...] Just because it's a C172 doesn't mean the plane won't be flown in hard IFR on a frequent basis [...] The inherent limitations of range and speed complicate bad weather diversion planning, power limits altitude reach and icing risk exposure, small amount of redundancy turns malfunctions into emergencies. So sure, it can be flown in hard IFR on a frequent basis, but such greater risks have to be accepted. - FChE |
![]() Why not install a 4 inch Venturi on the side or the belly of the aircraft ( 50 bucks aircraft spruce) then route to a selector valve then you could switch between engine pump or venturi. This will drive BOTH AI and the DG. Or you could install the venturi to drive a back up CHEAP ( older type; black face) Gyro Horiz. I am sure an instrument shop will sell you one at a good price as every one wants a color faced type. Now what about BACK UP electrical power thats CHEAP and portable! I use one in my Airplane it provides 5 hours of FULL Avionics power ! It cost LESS than 30 bucks to make and all parts are from WAL - MART! Hint: GARDEN TRACTOR |
Hint, unless a homebuilt, all parts must be approved parts.
My vote for safety and redundancy would be for the Sporty's AI [not as a replacement for T&B] and the 496 GPS. The 496 is aviation, marine and highway, it is your XM radio too. Unlike the emergency attitude indicators used in jets, the Sporty's AI does not have a separate battery for power. You can have your shop create a redundant power source with a small battery that will be charged from the bus, but isolated if the alternator fails. "wise purchaser" wrote in message ps.com... | | | Why not install a 4 inch Venturi on the side or the belly of the | aircraft ( 50 bucks aircraft spruce) then route to a selector valve | then you could switch between engine pump or venturi. This will drive | BOTH AI and the DG. | | Or you could install the venturi to drive a back up CHEAP ( older type; | black face) Gyro Horiz. I am sure an instrument shop will sell you one | at a good price as every one wants a color faced type. | | Now what about BACK UP electrical power thats CHEAP and portable! | | | I use one in my Airplane it provides 5 hours of FULL Avionics power ! | It cost LESS than 30 bucks to make and all parts are from WAL - MART! | | | Hint: GARDEN TRACTOR | |
Is this really true? I cannot mount an unapproved CD player someplace so that it won't flop around in flight? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
yes
"Jose" wrote in message m... | Hint, unless a homebuilt, all parts must be approved parts. | | Is this really true? I cannot mount an unapproved CD player someplace | so that it won't flop around in flight? | | Jose | -- | "Never trust anything that can think for itself, if you can't see where | it keeps its brain." (chapter 10 of book 3 - Harry Potter). | for Email, make the obvious change in the address. |
I wouldn't bother with a backup vac system because its use is limited.
A backup pump won't cure a dead AI. I would buy the Sporty's backup AI. For under $2K and next to no labor (just a couple power hookups ) you get full, 100% AI redudency. -Robert, CFII Kelly wrote: I would be interested in getting opinions about backup systems for a vacuum pump failure and/or AI failure. I have a 172P with a single vacuum pump system, standard instruments otherwise, and a Garmin 430. I am most concerned about having a good backup if I lose a vacuum pump or AI in IMC. I have been thinking about either a Garmin 396/496 or the electric AI available from Sporty's. Looks like I could get a 396 or installed electric AI for about the same price ($2200 or so). While I haven't seen the panel page/"6-pack" page on the 396 or 496, I have read (in Aviation Consumer) that it's good enough to keep control of the airplane in an emergency situation. Obviously, the 396/496 has a number of other neat features such as inflight weather, terrain info, etc. Any suggestions on which way to go with this. BTW, I had also considered the Precise Flight backup vacuum system for a while, and it certainly is cheaper (around $700 installed). However, I was concerned by the fact that it would do nothing for you in the event of failure of the AI vs. the primary vacuum pump. Thanks. Kelly |
Backup Flight Data Recorder? | Fox Two | Soaring | 14 | August 27th 06 09:42 AM |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Fllight Recorder Wars, Part II: What Backup to Use? | Chip Bearden | Soaring | 13 | March 31st 04 10:10 PM |
Good AI backup, wish me luck | Robert M. Gary | Instrument Flight Rules | 29 | March 1st 04 05:36 PM |
Solid State Backup AI | Dan Truesdell | Instrument Flight Rules | 20 | January 15th 04 09:53 PM |
