Stuck Collective
Old November 26th 06, 04:19 PM posted to rec.aviation.rotorcraft
Linc
Default Stuck Collective
I remember reading an article discussing how there were emergencies
that most emergency procedures don't cover because they are
statistically improbable of happening. This article specifically
discussed flying along at cruise and discovering that your collective
could not be lowered beyond your cruise torque setting.
Since cruise torque is generally lower than hover IGE torque, you would
slow your airspeed, and while this initially results in a climb,
ultimately you will slow enough to descend. I have demonstrated this to
other pilots without actually touching down, since the approach was to
a field. I found it was not unlike techniques I was taught to conduct
FADEC Manual approaches.
I was wondering,
1. Does anyone remember the article and its source?
2. Has anyone ever experienced that kind of flight control malfunction?
Linc
Old November 27th 06, 03:53 AM posted to rec.aviation.rotorcraft
Ol Shy & Bashful
Linc
I have experienced something similar when foreign objects vibrated
their way under the collective in flight only to be discovered when
trying to lower the collective! If there is time to remove the
offending object all is cool. If it can't be removed it's going to be
back to power manipulation and that dreaded, by turbine pilots, syndome
of "Oh NOOOOO Throttle Movement Required for control. ggg
Amazing what can find its way under that collective.....maps, Jep
charts, books, towels, gloves, map cases, flashlights, tie downs, hats,
etc. Always seemed to happen when you can least afford it to. Murphy
Strikes Again.
Cheers
Rocky
I was wondering,
Linc
Old November 27th 06, 08:55 AM posted to rec.aviation.rotorcraft
Space-time foam
I was wondering,
Linc
This is a great story...
http://airsports.fai.org/jun98/jun9804.html
Old November 27th 06, 03:36 PM posted to rec.aviation.rotorcraft
Ron Snipes[_1_]
Mr. Murphy was an optimist!
Posted via a free Usenet account from http://www.teranews.com
Old November 27th 06, 06:07 PM posted to rec.aviation.rotorcraft
Jim[_8_]
http://www.ntsb.gov/ntsb/brief.asp?e...30X01889&key=1
"Linc" wrote in message
I was wondering,
Linc
PA28-181 - Stuck Mike - King Silver Crown Roy Page Owning 2 October 29th 04 03:36 AM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
