OT - Garmin database updates PROBLEM SOLVED
Old December 1st 06, 09:27 PM posted to rec.aviation.piloting
Michael Ware
Default OT - Garmin database updates PROBLEM SOLVED
Couldn't get update to run on my Windows 98 machine (166mHz) it was time for
a new one, got a 3 gHz with Windows XP works fine. Got the obstacle database
updated.
Garmin tech support did a fine job, tried lots of things. Now since
Micros@ft isn't supporting 98 anymore, it was REALLY time for a new box.
Mike
Old December 1st 06, 11:56 PM posted to rec.aviation.piloting
john smith
updated.
And I thought I was th only one, using an ancient technology Windows 95
Thinkpad 760!
Old December 2nd 06, 12:20 PM posted to rec.aviation.piloting
kontiki
I finally bit the bullet myself last week as well, although I never had
trouble updating my GPS with my old Win98 system.
Old December 2nd 06, 05:27 PM posted to rec.aviation.piloting
Morgans[_2_]
"Michael Ware" wrote in message
Couldn't get update to run on my Windows 98 machine (166mHz) it was time for a
updated.
Garmin tech support did a fine job, tried lots of things. Now since Micros@ft
My GOd !!! How old is that thing? I didn't know there were any of those left
running. Just curious, but how much RAM did it have? 8 meg? 16?
Jim in NC
Old December 2nd 06, 05:39 PM posted to rec.aviation.piloting
Stefan
time for a new one, got a 3 gHz with Windows XP works fine. Got the
obstacle database updated.
those left running. Just curious, but how much RAM did it have? 8
meg? 16?
Why shold that matter? I find it just plain crazy that 166 MHz shouldn't
be enough for a plain simple data transfer over a serial line.
But then, I've just seen that Michael wrote 166 mHz. Now this may be
marginal, agreed.
Stefan
Old December 2nd 06, 07:58 PM posted to rec.aviation.piloting
Peter Duniho
"Stefan" wrote in message
marginal, agreed.
It is enough.
However, I have found that not all serial devices are the same and what
should work in theory does not always.
For example, I have some pinball machines that use a serial connection to
update the firmware. Unfortunately, I could just not get the update to work
correctly with a newer computer. I had to actually downgrade to a slower
one for things to work.
It wasn't a performance issue. It was a basic difference in timing issue
somewhere, in which the slower computer didn't manifest the problem but the
faster one did.
I was later able to modify the firmware updating software so that it could
deal with the subtle timing difference and run on faster computers (the
timing difference generated spurious bytes on the serial line, and the
update software wasn't doing enough error checking to accomodate the
errors). But if I hadn't had access to the source code, the easiest option
for fixing the problem would have been to simply use a different computer.
Just as is the case here. It's unlikely that the difference between the
166Mhz and 3Ghz PCs is specifically related to a performance requirement.
It's much more likely that there's just something different about the slower
computer that was never tested or discovered by Garmin when they were
writing the update software (probably because there didn't seem to be a need
to). Using a different speed computer makes the problem just go away.
Pete
Old December 2nd 06, 06:00 PM posted to rec.aviation.piloting
Mxsmanic
Morgans writes:
There are still a lot of people running Windows 3.1.
Old December 2nd 06, 08:25 PM posted to rec.aviation.piloting
john smith
Mxsmanic wrote:
Morgans writes:
left
I have 3.11
Old December 2nd 06, 06:11 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Sat, 2 Dec 2006 12:27:03 -0500, "Morgans"
I can remember running multiuser UNIX machines with that much memory
and they ran *very* well...
Old December 2nd 06, 06:18 PM posted to rec.aviation.piloting
Mxsmanic
Grumman-581 writes:
In those days, programmers tried to write efficient code. And there
was no elaborate, transparent, three-dimensional, glowing, glistening
graphic user interface to drive (the GUI can easily consume 80% of
processor power on a Windows system).
Garmin 430 Jeppesen Skybound updates John Doe Owning 17 November 30th 05 03:50 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
Garmin 195 screen problem BPattonsoa Home Built 30 December 3rd 03 02:14 AM
who moved SAV, forgot to tell Jepp? Dave Butler Instrument Flight Rules 15 November 9th 03 02:16 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
