![]() A very high pressure settled in Pacific NW: KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2 SLP389 T10671078 That's the highest that I've ever remember seeing. I always thought that the NW seems to have larger pressure swings (probably more so in Alaska). We can go from 2960 to 3060 in about two days. |
![]() BTW, FAR 91.144 restricts flight operations when barometric pressure exceeds 31 inch mercury. Any idea why? (note this restriction applies to VFR traffic a well). M wrote: A very high pressure settled in Pacific NW: KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2 SLP389 T10671078 That's the highest that I've ever remember seeing. I always thought that the NW seems to have larger pressure swings (probably more so in Alaska). We can go from 2960 to 3060 in about two days. |
![]() "M" wrote in message ps.com... BTW, FAR 91.144 restricts flight operations when barometric pressure exceeds 31 inch mercury. Any idea why? (note this restriction applies to VFR traffic a well). The Kollsman Window is only required to have a range of 28.00 to 31.00 inches Hg. So if barometric pressure is outside that range, you cannot accurately set most altimeters. John Severyn @KLVK |
![]() I don't believe VFR flight requires accurate altimeter adjustable for barometric pressure. 91.205 only requires such altimeter for IFR operations. J. Severyn wrote: "M" wrote in message ps.com... BTW, FAR 91.144 restricts flight operations when barometric pressure exceeds 31 inch mercury. Any idea why? (note this restriction applies to VFR traffic a well). The Kollsman Window is only required to have a range of 28.00 to 31.00 inches Hg. So if barometric pressure is outside that range, you cannot accurately set most altimeters. John Severyn @KLVK |
Correct. But you still are required to follow the NOTAM in extremely high
or low barometric pressure conditions. If you read FAR91.144 quoted he "Sec. 91.144 Temporary restriction on flight operations during abnormally high barometric pressure conditions. (a) Special flight restrictions. When any information indicates that barometric pressure on the route of flight currently exceeds or will exceed 31 inches of mercury, no person may operate an aircraft or initiate a flight contrary to the requirements established by the Administrator and published in a Notice to Airmen issued under this section. (b) Waivers. The Administrator is authorized to waive any restriction issued under paragraph (a) of this section to permit emergency supply, transport, or medical services to be delivered to isolated communities, where the operation can be conducted with an acceptable level of safety." In other words, it says "Read the NOTAM" or "Get a Waiver". Normally the NOTAM will restrict operation at certain altitudes so that safe altitude separation can be maintained in spite of the inability to correctly enter the barometric pressure. John Severyn @KLVK "M" wrote in message oups.com... I don't believe VFR flight requires accurate altimeter adjustable for barometric pressure. 91.205 only requires such altimeter for IFR operations. J. Severyn wrote: "M" wrote in message ps.com... BTW, FAR 91.144 restricts flight operations when barometric pressure exceeds 31 inch mercury. Any idea why? (note this restriction applies to VFR traffic a well). The Kollsman Window is only required to have a range of 28.00 to 31.00 inches Hg. So if barometric pressure is outside that range, you cannot accurately set most altimeters. John Severyn @KLVK |
![]() "M" wrote in message oups.com... I don't believe VFR flight requires accurate altimeter adjustable for barometric pressure. 91.205 only requires such altimeter for IFR operations. AIM 7-2-2 might answer your question about high and low barometric pressures. John Severyn @KLVK |
That is the highest pressure you can set on the Kollsman
window. "M" wrote in message ps.com... | | BTW, FAR 91.144 restricts flight operations when barometric pressure | exceeds 31 inch mercury. Any idea why? (note this restriction applies | to VFR traffic a well). | | | M wrote: | A very high pressure settled in Pacific NW: | | KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2 | SLP389 T10671078 | | That's the highest that I've ever remember seeing. | | I always thought that the NW seems to have larger pressure swings | (probably more so in Alaska). We can go from 2960 to 3060 in about two | days. | |
Jim Macklin wrote:
That is the highest pressure you can set on the Kollsman window. I can hardly see how it should affect VFR flights. Additionally if the pressure is higher than 31 inch mercury and the altimeter is set to 3100, the true altitude would be higher than what's indicated by the altimeter. For VFR flights this would almost never introduce any problems. (Even for IFR terrain separation this allows a bigger margin for terrain clearance). The only problem I could think of is the mode C requirement for altitude above 10,000 MSL, if someone flying without a mode C x-ponder, set their altimeter to 3100, on day with pressure higher than 31" mercury, and flying right near 10,000 feet indicated on their altimeter :-) |
oups.com... Jim Macklin wrote: That is the highest pressure you can set on the Kollsman window. I can hardly see how it should affect VFR flights. Additionally if the pressure is higher than 31 inch mercury and the altimeter is set to 3100, the true altitude would be higher than what's indicated by the altimeter. For VFR flights this would almost never introduce any problems. (Even for IFR terrain separation this allows a bigger margin for terrain clearance). The only problem I could think of is the mode C requirement for altitude above 10,000 MSL, if someone flying without a mode C x-ponder, set their altimeter to 3100, on day with pressure higher than 31" mercury, and flying right near 10,000 feet indicated on their altimeter :-) I thought the Mode C transponder reports Pressure Altitude and is basically fixed at 29.92? |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
Local altimeter at BFM | Dan Luke | Instrument Flight Rules | 3 | June 15th 04 02:01 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Tony | Naval Aviation | 290 | March 7th 04 07:58 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
