I currently subscribe to the Airchart IFR and sectional service. I was
looking at changing to the WAC and IFR service. What exactly is the difference between the WAC and sectional charts? Do the WACs show all the MOAs/restricted/etc areas? Are all the same airports listed? Thanks |
I tried WACs a while back but found insufficient detail for good visual
orientation, and went back to sectionals. The WACs are handy for planning because of their larger scale but that's about it. I also use Low Altitude En Route charges for IFR in combination with the sectionals. |
" wrote: What exactly is the difference between the WAC and sectional charts? Thw WAC charts are 1:1,000,000 scale. Sectionals are 1:500,000 scale (twice as large). Do the WACs show all the MOAs/restricted/etc areas? Yes. Are all the same airports listed? Most private strips are not shown on the WACs. Also missing are airspace details for controlled fields and radio frequency information. Most of those magenta circles you're used to seeing on a sectional aren't on a WAC. In congested areas, you'll see notes on the WAC to use the sectional -- for example, the note "for flights at and below 4400 MSL see charlotte VFR sectional chart" may be found on the WAC near RDU. This is your clue that the RDU airspace extends to 4,400'. George Patterson He who marries for money earns every penny of it. |
There are lots of little differences. All the restricted, MOA stuff is
on the WAC's. But not the Class E surface area airports (special vfr?). All the airports are there, but not the 3 or 4 letter ID's. With a GPS, it is enough. Only thing I can't find is those Class E surface areas with my WACs or GPS. |
The new issues later this year will have the identifiers added.
Doug wrote: There are lots of little differences. All the restricted, MOA stuff is on the WAC's. But not the Class E surface area airports (special vfr?). All the airports are there, but not the 3 or 4 letter ID's. With a GPS, it is enough. Only thing I can't find is those Class E surface areas with my WACs or GPS. |
This is a great victory for EAA and AOPA, which have been clamoring for this addition for a long time. Adding the airport identifiers to WACs will make them much more usable, IMHO. I will probably switch to using them exclusively after this change takes place, since that has always been my biggest objection to using them in the past. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
If you like to tool around C and B airspace VFR you won't like the WAC.
It doesn't show you the entire wedding cake. It just shows you the outer area, it doesn't show you the side area at all. -Robert wrote: I currently subscribe to the Airchart IFR and sectional service. I was looking at changing to the WAC and IFR service. What exactly is the difference between the WAC and sectional charts? Do the WACs show all the MOAs/restricted/etc areas? Are all the same airports listed? Thanks |
The Aircharts have all the Class B and Class C areas on sectionals in
the back. |
Doug wrote: The Aircharts have all the Class B and Class C areas on sectionals in the back. What do you mean by "air chart"? I'm looking at a 1994 WAC CG-21, which covers the area from Philadelphia to most of South Carolina. It does not have anything special for the Class B and C airports. Is this something new in the last 10 years? George Patterson He who would distinguish what is true from what is false must have an adequate understanding of truth and falsehood. |
He is referring to a commerical product that comes in a big book. It has
the entire US in WAC charts, with Sectional detail of all Class C and B airspace. It is updated by subscription. They also sell sectional charts in big books (east and west versions) as well as IFR LO charts for the whole country. http://www.airchart.com/ Dave George Patterson wrote: Doug wrote: The Aircharts have all the Class B and Class C areas on sectionals in the back. What do you mean by "air chart"? I'm looking at a 1994 WAC CG-21, which covers the area from Philadelphia to most of South Carolina. It does not have anything special for the Class B and C airports. Is this something new in the last 10 years? George Patterson He who would distinguish what is true from what is false must have an adequate understanding of truth and falsehood. |
| Thread Tools | |
| Display Modes | |
| Can ATC assign an airway if filed direct? | Andrew Sarangan | Instrument Flight Rules | 26 | March 4th 04 01:23 AM |
