Can Washout Cause Flutter??
Old January 16th 07, 03:48 AM posted to rec.aviation.homebuilt
DonMorrisey
Default Can Washout Cause Flutter??
A friend's homebuilt recently went down with an 8000 hour pilot at the
controls. No one was hurt and the plane was landed in a field. The
pilot reported hearing/feeling an extremely loud vibration from the
wing, he immediately killed power and landed. One of the wings was
visibly buckled. The airplane is all aluminum with a 36 ' wing span.
The NTSB showed up and after getting the plane to a hangar, the wing
was dismantled. The rear spar had failed and was twisted and buckled,
although the wing had held together. The NTSB guys said the very solid
structural design and construction of the wing was what saved the plane
from coming apart in the air, as well as the pilot's quick response.
The conclusion by the NTSB was aileron flutter, they found several
bolts in the aileron hinge bracket assemblies (which hold the aileron
to the rear spar) that were supposed to have been drilled 10 MM from
the top and bottom edge of the spar flange and these had been drilled
at 25 MM or so. That was it and they walked away. There was no
visible damage to the aileron, the aileron spar or the hinge bracket
assemblies. The pliot reported no vibration in the stick. My friend
is convinced it had something to do with the washout of the wing. The
wing is a NACA 4413 Airfoil, modified in that it has no undercamber on
the bottom, the bottom is flat. The washout, which is built into the
wing during construction, is a couple of degrees. The plane I am
building uses the same wing/washout. I have done research but can't
find anything specific linking washout to flutter.
Any thoughts on this??
Thanks. Don...
Old January 16th 07, 05:14 AM posted to rec.aviation.homebuilt
Don,
A common cause of flutter is unbalance control surfaces. Here is a link that
you might find helpful.
(http://www.soaridaho.com/Schreder/Co...l.html#flutter)
HP-14 "6F"
"DonMorrisey" wrote in message
Thanks. Don...
Old January 16th 07, 06:36 AM posted to rec.aviation.homebuilt
Fortunat1[_2_]
oups.com:
solid structural design and construction of the wing was what saved
the plane from coming apart in the air, as well as the pilot's quick
response. The conclusion by the NTSB was aileron flutter, they found
several bolts in the aileron hinge bracket assemblies (which hold the
aileron to the rear spar) that were supposed to have been drilled 10
MM from the top and bottom edge of the spar flange and these had been
drilled at 25 MM or so. That was it and they walked away. There was
no visible damage to the aileron, the aileron spar or the hinge
bracket assemblies. The pliot reported no vibration in the stick. My
friend is convinced it had something to do with the washout of the
wing. The wing is a NACA 4413 Airfoil, modified in that it has no
undercamber on the bottom, the bottom is flat. The washout, which is
built into the wing during construction, is a couple of degrees. The
plane I am building uses the same wing/washout. I have done research
but can't find anything specific linking washout to flutter.
Umm, unlikely. Mostly flutter is caused by the surface itself deflecting
whatever it's been attached to and when that surface moves the related
control surface moves with it and inertial forces cuase it to deflect in
the opposite direction, loading up the surface. In one scenario, for
instance, the wing is deflected rapidly upwards by a gust. the aileron
is left behind because of inertia, i.e, the trailing edge of the
aileron's mass tends to deflect it downwards which of course now adds to
the wing's journey upwards. the wing loads up, bends, and eventualy
springs back in the other direction, down, thereby causing the aileron
to now deflect upwards and so on. the mass balance attached to a control
surface should eliminate this problem. Flutter can also be induced by an
aerodynamic cyclic where the flow covering the surface is cycled. I've
seen this and it's nowhere near as destructive as the previous example.
One thing worth remembering about flutter is that the tendency of a
surface to flutter is exacerbated by the load on the wing. That is to
say that a surface is more likely to flutter if it's loaded up with G
than it is if not. So, you screw up a maneuver and end up pointing
downhill and accelerating fast. Off comes the power and up comes the
nose and the G. This is a likely scenario for flutter.. Anything that
loads a susceptable surface up is going to induce it more quickly at a
given speed than the same scenario without the extra G, whether it be
caused by manueveing, turbulence or W.H.Y..
Needless to say, a control surface which has been incorrectly attached
to the airframe is significantly more likely to suffer.
Even if a control surface has been correctly balanced during building,
care must be exercised to ensure balance is maintained after painting.
Paint can add significantly to the weight and quite a few accidents have
been attributed to neglecting to do this..
Old January 19th 07, 02:32 AM posted to rec.aviation.homebuilt
J.Kahn
Yeah washout has nothing to do with it.
Flutter is equivalent to when you boost yourself on a park swing to go
higher. Your body is the aileron, and the swing chains are the wing
structure, and you move the CG of your body in a harmonic relationship
to the swing to excite and then amplify its movements. The aileron is
doing the same thing if its CG is aft of its hinge line.
By balancing the aileron and putting its CG on the hinge line the
aileron is incapable of adding to the energy in the vibrating wing
structure so stiffness is less critical. Its like laying out horizontal
on the park swing so if someone moves the swing your body just goes
along and can't amplify its motion.
John
Old January 16th 07, 08:31 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"DonMorrisey" wrote
My friend
Since we don't know the design of this plane, I have to ask if the aileron
goes all the way to the tip, or is there a small region at the tip where
there is a little plain wing.
I ask because the vortices peeling off the wingtip striking the aileron can
help to excite flutter. I don't have anything to site, but I have read this
before, and it does apply to model planes.
If balanced completely, and there is no slop, this might not be a problem,
but having it attached that far down no doubt left some play in the system.
Jim in NC
Old January 16th 07, 06:14 PM posted to rec.aviation.homebuilt
DonMorrisey
Jim in NC
Hi Jim, the aileron does not extend to the tip. There is perhaps a 12"
section of wing from the outboard side of the aileron to the tip of the
wing.
Don...
Old January 16th 07, 11:11 PM posted to rec.aviation.homebuilt
cavelamb himself
Jim in NC
wing.
Don...
WERE (because it's probably a moot point now) the hinges and alieron
actuation mechanism TIGHT (or maybe a little sloppy)?
Old January 17th 07, 02:36 AM posted to rec.aviation.homebuilt
DonMorrisey
Well, I actually never saw the airplane. My firiend says they were
tight but who knows, he also didn't realize the bolts in the brackets
were too far down from the bend in the spar flange, so I can't really
say.
He was surprised that the aileron and nothing associated with it had
any damage. That's what led him to his conclusion that the washout had
something to do with it.
Don...
Old January 17th 07, 05:08 AM posted to rec.aviation.homebuilt
cavelamb himself
say.
Don...
As another poster pointed out, we don't know anything about the design
or construction of this plane.
But you _may_ have just answered your own question.
If the aileron brackets were supported by nothing more than the web of
the rear spar I wouldn't be surprised it it encountered flutter.
It's an Aero-Elastic phenomenon, remember?
If it can flex, it fer sure will...
Glad nobody was hurt.
Old January 17th 07, 10:05 PM posted to rec.aviation.homebuilt
Blueskies
"DonMorrisey" wrote in message ups.com...
: WERE (because it's probably a moot point now) the hinges and alieron
: actuation mechanism TIGHT (or maybe a little sloppy)?
: Well, I actually never saw the airplane. My firiend says they were
: tight but who knows, he also didn't realize the bolts in the brackets
: were too far down from the bend in the spar flange, so I can't really
: say.
: He was surprised that the aileron and nothing associated with it had
: any damage. That's what led him to his conclusion that the washout had
: something to do with it.
: Don...
the aileron & linkage could be stout and break the wing without any damage visible.
stall strips ??? Tri-Pacer Owning 6 December 8th 06 06:18 PM
Counterweighting to prevent flutter [email protected] Home Built 11 June 10th 05 03:51 AM
Stall strips vs. Washout [email protected] Home Built 27 February 27th 05 08:59 AM
Avoiding Vne K.P. Termaat Soaring 120 April 7th 04 07:56 PM
Tail flutter! I Can Computer Services Home Built 3 November 24th 03 12:56 AM
