Well, hello again.
"That which doesn't kill me - has made a huge tactical mistake". Not up to 100%, but I'm still kicking and getting my strength back. Can't believe how long it has taken, but... No new tumors! ![]() Only problem now is boredom! A person can only watch TV for so long before his brains liquefy. I've dusted off the sketches of the low wing design study and worked on them up a bit. It seems to be coming along nicely. All the fuselage bulkhead patterns are finally done. Wraps up pretty nice. While it could be powered with a VW (1835 or 2180), I'd love to hang a Rotax 914 (turbo version) on it with an electric prop and the long wing option (with 30 gallons of gas?). And a relief tube! http://www.home.earthlink.net/~cavelamb/l-one.htm Richard |
"cavelamb himself" wrote in message
link.net... I've dusted off the sketches of the low wing design study and worked on them up a bit. It seems to be coming along nicely. All the fuselage bulkhead patterns are finally done. Wraps up pretty nice. http://www.home.earthlink.net/~cavelamb/l-one.htm Why not directly connect the elevator control linkage to the bottom of the elevator instead of using that movement reversing thingy (blue moving part)? I hate moving parts (can you tell?) |
Steve Foley wrote:
"cavelamb himself" wrote in message link.net... I've dusted off the sketches of the low wing design study and worked on them up a bit. It seems to be coming along nicely. All the fuselage bulkhead patterns are finally done. Wraps up pretty nice. http://www.home.earthlink.net/~cavelamb/l-one.htm Why not directly connect the elevator control linkage to the bottom of the elevator instead of using that movement reversing thingy (blue moving part)? I hate moving parts (can you tell?) Hi Steve, See the side view x-ray sketch. It's a pretty small ship. A bit larger than a Hummelbird, but still smaller than a Midget Mustang. There isn't much (any?) room under the seat! For what it's worth... Some people might enjoy a steel tube push rod running through their butt, but I thought it would be more comfortable to pass it along the side of the seat instead. ![]() Another point is to keep the long slender pushrod in the aft fuselage in tension (for postive G loads) rather than compression. This morning I took out the extra break in the side longeron (frame 2). It's now a straight shot from the firewall to frame 3. See w12-04x6 and w12-05x9. Should make it a little simpler to build. Maybe? The skins will still have to be sectioned up there because of the shape of the bottom curves. I never was happy with a break in the side skins right at the wing Center of Pressure point. That change ought so smooth out the cross section plot a bit too. It's all compromise, you know. Richard |
Some random notes about the stick mechanism from my experience building
and installing a retrofit cockpit control stich mechanism: * The way the two aileron bellcranks are located below the axis of the stick's pitch pivot, there will be rather a lot of unintended mixing of pitch input into the ailerons. The usual way of avoiding that is to place one or both ends of each transverse aileron PP tube near the pitch pivot axis. They don't have to be right on the axis, just close. * That other poster is right, the blue reversal bellcrank behind the seat is probably something you can do without. Parts you leave on the ground can't break in the air. * If you want to see some really elegant ways of implementing control sticks where you can't fit anything under the seat pan, have a look at a European sailplane. Bob K. http://www.hpaircraft.com |
Bob,
Your HP-18 side-stick to center-stick is an example of good design. http://www.hpaircraft.com/center_sti...22_january.htm (Complete story http://www.hpaircraft.com/center_stick/) Other designs that may be of interest to the group are Udo Rumpf's use of a PIK-20 sailplane stick http://www.soaridaho.com/Schreder/Co...ter_Stick.html and Brian Case's HP-16 modification. Brian need to lower the seatpan in his HP16 to allow more head/canopy clearance. So he removed the old cable system which ran under the seat and designed the following modification: http://www.soaridaho.com/Schreder/Co..._Stick_Mod.htm (Brian by his HP-16T http://www.soaridaho.com/Schreder/HP...Mackay_IDa.JPG) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder "Bob Kuykendall" wrote in message oups.com... Some random notes about the stick mechanism from my experience building and installing a retrofit cockpit control stich mechanism: * The way the two aileron bellcranks are located below the axis of the stick's pitch pivot, there will be rather a lot of unintended mixing of pitch input into the ailerons. The usual way of avoiding that is to place one or both ends of each transverse aileron PP tube near the pitch pivot axis. They don't have to be right on the axis, just close. * That other poster is right, the blue reversal bellcrank behind the seat is probably something you can do without. Parts you leave on the ground can't break in the air. * If you want to see some really elegant ways of implementing control sticks where you can't fit anything under the seat pan, have a look at a European sailplane. Bob K. http://www.hpaircraft.com |
Wayne Paul wrote:
Bob, Your HP-18 side-stick to center-stick is an example of good design. http://www.hpaircraft.com/center_sti...22_january.htm (Complete story http://www.hpaircraft.com/center_stick/) Other designs that may be of interest to the group are Udo Rumpf's use of a PIK-20 sailplane stick http://www.soaridaho.com/Schreder/Co...ter_Stick.html and Brian Case's HP-16 modification. Brian need to lower the seatpan in his HP16 to allow more head/canopy clearance. So he removed the old cable system which ran under the seat and designed the following modification: http://www.soaridaho.com/Schreder/Co..._Stick_Mod.htm (Brian by his HP-16T http://www.soaridaho.com/Schreder/HP...Mackay_IDa.JPG) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder The second picture from the top tells the tale. I'd assume (?) that there is something like a U joint behind the cockpit to let the push rod line up with the elevator horn? I'll have to think about this some more. You guys just could be right! Richard |
![]() "cavelamb himself" wrote in message hlink.net... Wayne Paul wrote: Bob, Your HP-18 side-stick to center-stick is an example of good design. http://www.hpaircraft.com/center_sti...22_january.htm (Complete story http://www.hpaircraft.com/center_stick/) Other designs that may be of interest to the group are Udo Rumpf's use of a PIK-20 sailplane stick http://www.soaridaho.com/Schreder/Co...ter_Stick.html and Brian Case's HP-16 modification. Brian need to lower the seatpan in his HP16 to allow more head/canopy clearance. So he removed the old cable system which ran under the seat and designed the following modification: http://www.soaridaho.com/Schreder/Co..._Stick_Mod.htm (Brian by his HP-16T http://www.soaridaho.com/Schreder/HP...Mackay_IDa.JPG) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder The second picture from the top tells the tale. I'd assume (?) that there is something like a U joint behind the cockpit to let the push rod line up with the elevator horn? I'll have to think about this some more. You guys just could be right! Richard, Here are some pictures from behind the cockpit that may help understanding Brian's control system.. http://www.soaridaho.com/Schreder/Co...ick_Mod_11.jpg The above picture was take looking forward. It shows the bulkhead aft of the wheelwell. You can see the series of bell cranks that actuate the ailerons and the push the stick's push rod as it is routed through the right side of the bulkhead. The elevator push rod and direction reversal crank can be seen on the left side of the bulkhead. (More pictures http://www.soaridaho.com/Schreder/Co...tick_Mod_9.jpg http://www.soaridaho.com/Schreder/Co...ick_Mod_10.jpg) As you can see, there are no "U-joints". The linkage has almost no "slop" and give good control surface feed-back. It should also be noted that the ailerons droop and reflex with the flaps avoiding misalignment during normal cruise and thermaling flap configurations. Wayne HP-14 "6F http://www.soaridaho.com/Schreder Richard |
Wayne Paul wrote:
"cavelamb himself" wrote in message hlink.net... Wayne Paul wrote: Bob, Your HP-18 side-stick to center-stick is an example of good design. http://www.hpaircraft.com/center_sti...22_january.htm (Complete story http://www.hpaircraft.com/center_stick/) Other designs that may be of interest to the group are Udo Rumpf's use of a PIK-20 sailplane stick http://www.soaridaho.com/Schreder/Co...ter_Stick.html and Brian Case's HP-16 modification. Brian need to lower the seatpan in his HP16 to allow more head/canopy clearance. So he removed the old cable system which ran under the seat and designed the following modification: http://www.soaridaho.com/Schreder/Co..._Stick_Mod.htm (Brian by his HP-16T http://www.soaridaho.com/Schreder/HP...Mackay_IDa.JPG) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder The second picture from the top tells the tale. I'd assume (?) that there is something like a U joint behind the cockpit to let the push rod line up with the elevator horn? I'll have to think about this some more. You guys just could be right! Richard, Here are some pictures from behind the cockpit that may help understanding Brian's control system.. http://www.soaridaho.com/Schreder/Co...ick_Mod_11.jpg The above picture was take looking forward. It shows the bulkhead aft of the wheelwell. You can see the series of bell cranks that actuate the ailerons and the push the stick's push rod as it is routed through the right side of the bulkhead. The elevator push rod and direction reversal crank can be seen on the left side of the bulkhead. (More pictures http://www.soaridaho.com/Schreder/Co...tick_Mod_9.jpg http://www.soaridaho.com/Schreder/Co...ick_Mod_10.jpg) As you can see, there are no "U-joints". The linkage has almost no "slop" and give good control surface feed-back. It should also be noted that the ailerons droop and reflex with the flaps avoiding misalignment during normal cruise and thermaling flap configurations. Wayne HP-14 "6F http://www.soaridaho.com/Schreder Richard Sorry. my bad. I was refering to the U-Joint in the Elevator pushrods. (and a word of warning about them...) http://www.soaridaho.com/Schreder/Co...ll.html#ujoint That lateral torque tube (actually a walking beam) in my sketch is in the elevator control system. It takes the pushrod from the lateral joystick torque tube and inverts it so the long tube to the elevator is in tension. Also centers up the aft push pull tube. The lower arm in the center is the attach horn for a MAC servo (elevator trim) coupled by a "U" shaped fiberglass spring. I didn't dream that one up - saw it on the net some years back - but I wish I had. Well, _I_ thought it was a pretty simple setup... Richard |
Bob Kuykendall wrote:
Some random notes about the stick mechanism from my experience building and installing a retrofit cockpit control stich mechanism: * The way the two aileron bellcranks are located below the axis of the stick's pitch pivot, there will be rather a lot of unintended mixing of pitch input into the ailerons. The usual way of avoiding that is to place one or both ends of each transverse aileron PP tube near the pitch pivot axis. They don't have to be right on the axis, just close. * That other poster is right, the blue reversal bellcrank behind the seat is probably something you can do without. Parts you leave on the ground can't break in the air. * If you want to see some really elegant ways of implementing control sticks where you can't fit anything under the seat pan, have a look at a European sailplane. Bob K. http://www.hpaircraft.com Man, Bob, that thing is some kinda slick! You do really nice work! It took a while to find the details of the center stick setup. If you don't mind, here are some links for the gang. First pics I located. http://www.hpaircraft.com/center_sti...te_9_april.htm Now I see what you mean. Small U joints in the PP tube allows for some angular offset. You have the advantage here with a Looong tail. Small angular offset. Some more pics of the stick and mechanism here... http://www.hpaircraft.com/center_sti...22_january.htm http://www.hpaircraft.com/center_sti..._9_october.htm Aileron (roll) bellcranks - in DOUBLE shear! http://www.hpaircraft.com/center_sti...704,18-705.pdf I built some kinda sorta like this once, but with joggled arms. The spacer approach makes a lot more sense. And more accurately reproducible too. But then I found this one... http://www.hpaircraft.com/hp-24/upda...ovember_05.htm the DISadvantage of that Looong tail... 92% done - 80% to go??? Richard |
Earlier, cavelamb himself wrote:
...But then I found this one... http://www.hpaircraft.com/hp-24/upda...ovember_05.htm the DISadvantage of that Looong tail... 92% done - 80% to go??? Yup, something like that! Funny you should mention those pictures. This weekend I'm going up to Seattle (Monroe, actually, out beyond Arlington) to help Brad Hill build the equivalent tooling to locate the elevator PP tube in his Glidair motorglider fuselage. Here's the latest Glidair update at my Web site: http://www.hpaircraft.com/glidair/up...january_07.htm These pages show us making and installing the elevator PP tube guides in the HP-24 fuselage: http://www.hpaircraft.com/hp-24/upda...January_06.htm http://www.hpaircraft.com/hp-24/upda...January_06.htm The guides themselves are copies of a standard ACS part - which is a copy of a standard Rolladen-Schneider part. They're about $10 ea from ACS. They have an ID of 5/8", which makes for a reasonable light-duty PP tube in .035" wall 6061-T6. Thanks, and best regards to all! Bob K. http://www.hpaircraft.com |
doodles damit... | Richard Lamb | Home Built | 8 | March 5th 06 08:17 AM |
Doodles... | Richard Lamb | Home Built | 39 | January 20th 06 08:34 PM |
