on helis?... and the static pressure point??...... rc or full
size....R22...or Jetranger any info appreciated.. Cheers Nick |
![]() "Nick" wrote in message ... on helis?... and the static pressure point??...... rc or full size....R22...or Jetranger any info appreciated.. Cheers Nick Male pilots are always located in the cockpit. For female pilots it has been renamed the box office. |
Hahahahahahahahahaha.........You don't know what a pitot is do you?
sigh......anyone know where a piTot is situated? ..... when do they start to work?...... Oh alright then......at what airspeed do they start to function usefully / accurately.... or even .....when does the down wash have no effect of the pitot. "Maxwell" wrote in message ... "Nick" wrote in message ... on helis?... and the static pressure point??...... rc or full size....R22...or Jetranger any info appreciated.. Cheers Nick Male pilots are always located in the cockpit. For female pilots it has been renamed the box office. |
Aaaaagh, that's what I get for trying to answer without my glasses. I
thought it said pilot, and was wondering why you were asking about the static port too. I recall two different locations in my limited experience. Seems like the Huey's and larger birds often had a long pitot straight out the front in to clean air, maybe as much as 18 to 24 inches long, and very much horizontal with the air flow. But I also think I recall seeing at least a few Jet Rangers that had a 90 degree mount, about 3 inches from the cabin, and pointed down the center of the windshield, paralell with the windshield, and about 45 degrees or so to the horizontal. Obviously placed to measure flow up the windshield after deflection from the nose of the aircraft. I don't recall the location of their static ports, but every one I have ever seen has always been on the side of the cabin, 90 degrees to the slip stream. But again my knowlege is somewhat limited. I'm just a fixed wing pilot, that loves helos. "Nick" wrote in message ... Hahahahahahahahahaha.........You don't know what a pitot is do you? sigh......anyone know where a piTot is situated? ..... when do they start to work?...... Oh alright then......at what airspeed do they start to function usefully / accurately.... or even .....when does the down wash have no effect of the pitot. "Maxwell" wrote in message ... "Nick" wrote in message ... on helis?... and the static pressure point??...... rc or full size....R22...or Jetranger any info appreciated.. Cheers Nick Male pilots are always located in the cockpit. For female pilots it has been renamed the box office. |
![]() "Maxwell" wrote in message ... Aaaaagh, that's what I get for trying to answer without my glasses. I thought it said pilot, and was wondering why you were asking about the static port too. No worries.....I did exactly the same thing ....when posting on a rc heli forum earlier. Misread a post, with embarassing consequences. Large oops.. Cheers Nick |
The pitot is useful at about any speed as long as youre going forward. It
might not be totally accurate at low speed, but its all relatve anyways. Bart "Nick" wrote in message ... Hahahahahahahahahaha.........You don't know what a pitot is do you? sigh......anyone know where a piTot is situated? ..... when do they start to work?...... Oh alright then......at what airspeed do they start to function usefully / accurately.... or even .....when does the down wash have no effect of the pitot. "Maxwell" wrote in message ... "Nick" wrote in message ... on helis?... and the static pressure point??...... rc or full size....R22...or Jetranger any info appreciated.. Cheers Nick Male pilots are always located in the cockpit. For female pilots it has been renamed the box office. |
Pitot locations vary depending on engineering convenience, but in
general somewhere near the front end of the helicopter, pointing forward, matters not much where unless the bubble shape influences airflow (vs, for instance, bernoulli). Static can be on side of fuselage, but another good place is in some wide-open space over the engine or behind the transmission. Low-speed (less than 35 knots?) accuracy, however, is just plain terrible for any pitot system mounted anywhere, the extremely low ram pressures at those low speeds are woefully sensitive to minor changes in angle of impact of the airflow, making it nigh impossible to get a good reading. The only remedy I've seen is at the engineering-test-pilot training school at the Nat'l Test Pilot School in Mojave, CA, on a 206: a 24" dish-shaped pod, non-rotating, above the main rotor (looking something like the radar pods on the OH-58 for target aquisition), with a rotating cuff (100 rpm?) containing multiple pitot tubes (or so it appears), electronically instrumented with pressure transducers to look at the DIFFERENTIAL between forward-moving side of disc and rearward, the arithmetic sum (hey, at last something simple, 3-1=2) being the airspeed. Quite accurately. The quickie tour I got was brief on this, I may be misrepresenting portions of the mechanism. Whatever. Certainly you won't find one on ebay. The total absence of real accurate IAS data throughout the rest of the helicopter fleet is a flaming pain in the butte, there are so many useful things we could teach and learn and do if we just knew accurately, for instance, how much translational lift we were getting-- or even exactly when we achieve zero airspeed in OGE hover. But there seems to be no way to get that info easily, so the entire industry has gotten used to doing without it--even though a gyroscopic HSI costs around $3000, nobody sees a NEED for 10 or 20-knot airspeed accuracy. Not that it would free us from the grim realities of the h-v curve . . . |
On the R22 / R44, the pitot is a short tube mounted on the front of the mast
fairing perhaps about 3" above the cabin. The pitot on the R22 is just an open tube located within the rear top fairing about a foot behind the transmission. Anything below 20 knots is too hard to read with any accuracy .... above that seems to be OK. "Nick" wrote in message ... on helis?... and the static pressure point??...... rc or full size....R22...or Jetranger any info appreciated.. Cheers Nick |
pitot tube down | Emilio | Military Aviation | 16 | March 6th 04 11:37 PM |
Pitot heat | Paul Mennen | Owning | 10 | November 6th 03 09:54 AM |
Pitot heat | Paul Mennen | Piloting | 10 | November 6th 03 09:54 AM |
Pitot Heat | Roger Long | Piloting | 12 | November 6th 03 02:01 AM |
Pitot Heat | Larry Fransson | Piloting | 0 | November 3rd 03 03:33 AM |
