Dynamic Prop Balancer
Old March 4th 07, 12:28 PM posted to rec.aviation.owning
Robert Scott
Default Dynamic Prop Balancer
Can anyone tell me how a dynamic prop balancer works? I have heard that it
involves an accelerometer to detect vibration, but it what do they use to detect
the prop position to correlate with that accelerometer? Could it be an optical
pickup from a mark placed on the prop? Or perhaps a pickup from the magneto?
Although a mag pickup would be ambiguous by 180 degrees, I think. I was just
brainstorming on how I might design one from scratch.
Robert Scott
Ypsilanti, Michigan
Old March 4th 07, 12:58 PM posted to rec.aviation.owning
Robert Scott
Ypsilanti, Michigan
I believe an optical pickup is placed on the cowl with a reflector on
one of the prop blades.
Old March 4th 07, 02:40 PM posted to rec.aviation.owning
Robert Scott
Ypsilanti, Michigan
On the Acers unit I use to balance my prop the accelerometer is bolted
to the centerline of the engine in the proper direction. That sensor
is position sensitive. The light sender is taped on the top of the
cowling facing forward shining on the prop. it is about 13" away from
the reflective tape thats applied to the prop. The handheld unit is
routed into the cockpit using long cables from both sensors. The thing
works amazingly good. My last balance procedure got the prop/ spinner
to within .001 IPS. The smoothness is well worth the hour or so of
setup and running...
Ben
www.haaspowerair.com
Old March 4th 07, 04:00 PM posted to rec.aviation.owning
RST Engineering
I've got one in the back of my head that I want to use for a future
Kitplanes article. I'm going to use an old phonograph cartridge with a
short "ball on the end of a needle" as my accelerometer and I was seriously
thinking of an inductive pickup on the #1 plug wire. The optical gig was
also a consideration, but I got to thinking how that would work out in the
sunlight.
"Robert Scott" ---@--- wrote in message
it
detect
optical
magneto?
just
Robert Scott
Ypsilanti, Michigan
Old March 4th 07, 06:55 PM posted to rec.aviation.owning
Tim
Robert Scott
Ypsilanti, Michigan
No idea, but can anyone recommend a shop that will balance my single
engine grumman - one close to KISP - Long Island NY? I have no problems
travelling to CT or RI or MA or VT for this - might make a day trip out
of it.
thanks
Old March 5th 07, 12:32 AM posted to rec.aviation.owning
Peter Clark
On Sun, 04 Mar 2007 13:55:54 -0500, Tim
of it.
Keyson at Nashua, NH.
Old March 5th 07, 12:38 AM posted to rec.aviation.owning
Tim
of it.
ok, thanks. that's a hike, but it would be a fun trip. I might wait
until it warms up a bit.
Old March 5th 07, 01:06 AM posted to rec.aviation.owning
Peter Clark
On Sun, 04 Mar 2007 19:38:28 -0500, Tim
of it.
Yea, and they like to see winds of ~10 or less for best results. The
restaurant is closed on (Wednesday?). Call ahead and ask for Byron to
confirm they'll do the model (I doubt you'll have a problem with
practically any single/multi engine piston though). I've done the
stay-and-wait thing, it generally runs them around +- 3 hours from
sign in to release.
Old March 5th 07, 02:41 PM posted to rec.aviation.owning
On Mar 4, 6:06 pm, Peter Clark
of it.
sign in to release.
The only way to get perfect results is for the wind to be calm. A 10
MPH breeze give you false readings, At least it does on the Acers
unit.. YMMV...
Ben
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
dynamic prop balancing George A. Graham Home Built 2 April 21st 05 01:20 PM
Dynamic prop balance Ben Jackson Owning 18 June 27th 04 01:45 AM
Need Micro Balancer Jim Products 39 August 26th 03 01:34 AM
Need Micro Balancer Jim Rotorcraft 35 August 26th 03 01:34 AM
