Wedekind Safety Sleeves
Old March 4th 07, 10:11 PM posted to rec.aviation.soaring
ContestID67
Default Wedekind Safety Sleeves
I uploaded the pictures of my installation of Wedekind safety
sleeves. These go on L'Hotelier fittings and are much easier to use
than any other method.
http://geocities.com/jhderosa
Enjoy, John DeRosa
Old March 5th 07, 02:16 AM posted to rec.aviation.soaring
Andy[_1_]
Enjoy, John DeRosa
Thanks for posting the gory details. I have always considered safety
pins to be a good solution. Nothing here to make me change my mind.
A few cents worth of piano wire, 15 minutes or less making a set of
pins, and 30 seconds to install them at each assembly. Why do you
claim the sleeves are better?
Andy
Old March 5th 07, 04:10 AM posted to rec.aviation.soaring
ContestID67
The Wederkind sleeves are simply easier to use, but not necessarily
any more/less safe.
At least on the DG's air brakes, the pins are a bear to insert. While
the aileron connects are right in the middle and very vissible, the
brakes are deep inside and you have to insert the pins by feel. Not
fun.
I had the pins. Then I went to the Uerling sleeves (which need to be
replaced every few years). The Wederkind sleeves are definately the
best of the three for ease of use.
- John DeRosa
Old March 5th 07, 12:04 PM posted to rec.aviation.soaring
alex8735
In my opinion Wedekind sleeves are more prone to mounting errors due
to their ease of use. After connecting the L'Hoteliers and snapping
back the Wedekind sleeves it is important to carefully check whether
the sleeve aktually covers the securing plate and then pull at the
fitting in opening direction. This is the only way to ensure a safe
connection!
Last year we had a serious accident at our club after the L'Hotelier
of the left aileron had disconnected. Ironically it was the Wedekind
sleeve of the disconnected aileron which caused it to jam, therefore
also blocking the connected aileron.
Generally L'Hoteliers are far from full proof an require carefull
handling. Wedekind sleeves are surely the easiest to use. I think the
LS-Sleeves which are screwed all the way over the connection are
probably the safest because they do no only stop the securing plate
from opening but secure the whole connection.
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 02:15 PM
Hints on Securing L'Hotellier with Wedekind Sleeves ContestID67 Soaring 0 December 1st 05 08:29 PM
Uerling Safety Sleeves BDS Soaring 0 September 20th 05 08:02 PM
Wedekind Safety Sleeves Huds Soaring 5 May 8th 05 03:07 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
