I did annual checks about a month ago, when we were encouraged to try
low position on the way up for spin checks. I decided that I like low tow and will use it in future, but before I do so there's one thing I'd like to ask the Aussies and other habitual low towers: when you release do you just pull the bung in the low position or do you pop up above the wake first? I fly a Libelle, which normally tows with a lot of sag in the rope, even with the wheel down, and it occurred to me that releasing in the low position could cause the rings to pass close to the canopy or even hit it. At least the Libelle has a nose hook: if this is an issue, would it be even worse with a belly hook? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Mar 5, 8:50 am, Martin Gregorie wrote:
I did annual checks about a month ago, when we were encouraged to try low position on the way up for spin checks. I decided that I like low tow and will use it in future, but before I do so there's one thing I'd like to ask the Aussies and other habitual low towers: when you release do you just pull the bung in the low position or do you pop up above the wake first? That was the procedure I was taught in South Africa. Just release and immediately initialize a turn away. It is interesting, though, when the tug slows down in a thermal to watch the slack tow rope disappearing backwards over your canopy towards the tail! I had a Jantar-1 that had a forward, but not nose- mounted tow hook. Mike |
On Mar 5, 8:34 pm, "Mike the Strike" wrote:
On Mar 5, 8:50 am, Martin Gregorie wrote: I did annual checks about a month ago, when we were encouraged to try low position on the way up for spin checks. I decided that I like low tow and will use it in future, but before I do so there's one thing I'd like to ask the Aussies and other habitual low towers: when you release do you just pull the bung in the low position or do you pop up above the wake first? That was the procedure I was taught in South Africa. Just release and immediately initialize a turn away. It is interesting, though, when the tug slows down in a thermal to watch the slack tow rope disappearing backwards over your canopy towards the tail! I had a Jantar-1 that had a forward, but not nose- mounted tow hook. Mike - Hide quoted text - - Show quoted text - Interestingly enough, the FAA written exam. includes a question on just this subject. The question is something like (pardon the liberal paraphrasing, I left my book at the shop) "Releasing the tow rope from the low tow position is:" A. Just fine; B. Not so good, because the rope can snap forward and whack the towplane; C. Not a good idea because it can whack your glider after release. The FAA's "correct" answer is C. I have only a CG hook, and would be kind of uncomfortable with the tow rope rubbing the side of my glider during the entire tow. Jim |
If you were taught (in South Africa) to release in low tow, I'm sorry to say
that you were taught the wrong procedure by the individual instructor. The approved procedure, also in SA, is to come up to high tow slowly, put some tension on the rope, and then release. If you release in low tow, you run the risk of the odfur ring breaking through your canopy, or at worst, tangling up your glider. "Martin Gregorie" wrote in message ... I did annual checks about a month ago, when we were encouraged to try low position on the way up for spin checks. I decided that I like low tow and will use it in future, but before I do so there's one thing I'd like to ask the Aussies and other habitual low towers: when you release do you just pull the bung in the low position or do you pop up above the wake first? I fly a Libelle, which normally tows with a lot of sag in the rope, even with the wheel down, and it occurred to me that releasing in the low position could cause the rings to pass close to the canopy or even hit it. At least the Libelle has a nose hook: if this is an issue, would it be even worse with a belly hook? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Oscar:
As far as I remember, what I describe was standard procedure in both Jo'burg clubs in the 1970's and 1980's. Not wrong, just different. I remember also being taught never to release from a slack rope for the reasons you describe. Slack rope during low tow gave me more interesting experiences than I have seen since using high tow here in the USA. Mike On Mar 5, 11:46 pm, "Oscar Goudriaan" wrote: If you were taught (in South Africa) to release in low tow, I'm sorry to say that you were taught the wrong procedure by the individual instructor. The approved procedure, also in SA, is to come up to high tow slowly, put some tension on the rope, and then release. If you release in low tow, you run the risk of the odfur ring breaking through your canopy, or at worst, tangling up your glider. |
I did annual checks about a month ago, when we were encouraged to try low position on the way up for spin checks. I decided that I like low tow and will use it in future, but before I do so there's one thing I'd like to ask the Aussies and other habitual low towers: when you release do you just pull the bung in the low position or do you pop up above the wake first? In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots at the same time as they're trying to stay in position, check for traffic before release, think about which knob to pull and how to initiate a turn. The current teaching in Oz is to tow in whatever position you prefer (most choose low) BUT you release from the tow position you used for the climb so you don't scare the tuggies. KISS principle. In general, while all gliders in Oz should have a nose hook for aerotow, in practice this isn't always possible and the few gliders with only belly hooks usually high tow, while the rest have the luxury (as Martin discovered, it's easier) of low tow. So Oscar's problem of the Ottfur ring (?) breaking the canopy is not relevant. I fly a Libelle, which normally tows with a lot of sag in the rope, even with the wheel down, and it occurred to me that releasing in the low position could cause the rings to pass close to the canopy or even hit it. At least the Libelle has a nose hook: if this is an issue, would it be even worse with a belly hook? I've never heard of a problem with low towing Libelles with nose hooks. Obviously it would be sensible to release when the rope is under tension but this applies to all towing. For those with only belly hooks, see above. GC |
![]() "Graeme Cant" gcantinter@tnodedotnet wrote in message ... Martin Gregorie wrote: I did annual checks about a month ago, when we were encouraged to try low position on the way up for spin checks. I decided that I like low tow and will use it in future, but before I do so there's one thing I'd like to ask the Aussies and other habitual low towers: when you release do you just pull the bung in the low position or do you pop up above the wake first? In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots at the same time as they're trying to stay in position, check for traffic before release, think about which knob to pull and how to initiate a turn. The current teaching in Oz is to tow in whatever position you prefer (most choose low) BUT you release from the tow position you used for the climb so you don't scare the tuggies. KISS principle. In general, while all gliders in Oz should have a nose hook for aerotow, in practice this isn't always possible and the few gliders with only belly hooks usually high tow, while the rest have the luxury (as Martin discovered, it's easier) of low tow. So Oscar's problem of the Ottfur ring (?) breaking the canopy is not relevant. I fly a Libelle, which normally tows with a lot of sag in the rope, even with the wheel down, and it occurred to me that releasing in the low position could cause the rings to pass close to the canopy or even hit it. At least the Libelle has a nose hook: if this is an issue, would it be even worse with a belly hook? I've never heard of a problem with low towing Libelles with nose hooks. Obviously it would be sensible to release when the rope is under tension but this applies to all towing. For those with only belly hooks, see above. GC We used to go from low tow up into high tow or level tow as some may prefer. After a few TUG pilots were killed in and some nearly killed they stopped high tow unless you only have a belly hook. We turn right after release. We have released without turning like in wave etc and just to experiment I have never come into contact with the rings as the tug accelerates away. http://www.mals.net/ |
![]() "Graeme Cant" gcantinter@tnodedotnet wrote in message ... In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots... That trip up (and/or down) through the wake is part of the drill for the "boxing the wake" manuver. I would never solo a student who couldn't do that. Vaughn |
Vaughn Simon wrote:
"Graeme Cant" gcantinter@tnodedotnet wrote in message ... In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots... That trip up (and/or down) through the wake is part of the drill for the "boxing the wake" manuver. I would never solo a student who couldn't do that. Vaughn Good. Your point is? GC |
And you thought AMARC was bad.... | Ron | Aviation Photos | 18 | February 2nd 07 05:27 AM |
Thought Police | Michael Baldwin, Bruce | Products | 0 | November 17th 06 06:58 AM |
Just when I thought I'd heard it all:-) | Dudley Henriques | Piloting | 14 | November 23rd 05 08:18 PM |
A thought on BRS | Martin Gregorie | Soaring | 47 | April 29th 04 06:34 AM |
I thought some of these are classics | goneill | Soaring | 0 | April 8th 04 10:51 AM |
