Inverted oil cooler mounting
Old March 10th 07, 05:39 PM posted to rec.aviation.homebuilt
Default Inverted oil cooler mounting
Folks--
I have a bit of a clearance problem for my oil cooler. As is usual, I
can either mount it where it gets good air flow or I can mount it
where fits nicely--but of course, not both.
I am opting for the good air flow for all the obvious reasons. Part
of what makes this location tricky is the necessity of mounting the
cooler upside-down, i.e. with the fittings facing down rather than on
top.
As I was working this out, I became quite concerned that the cooler
would air lock, since the cooler sits above the engine and the
breather port. In other words, the cooler is the high point in the
oil system and if the fittings are on the bottom, I worry that any air
previously present in the cooler or air that becomes introduced into
it will stay in the cooler and displace a volume of oil.
Now I am not a "wrench" so I bounced this concern off of everyone I
could find, including the engine dealer, several other homebuilders
and some knowledgeable race car guys. Out of approximately 8 guys, 7
told me it was not a problem (the dealer among them) and only 1 shared
my air locking concern.
The No Problem 7 all told me that the normal operating oil pressure
would purge the air from the cooler. Now I like this because it gets
me off the hook, but I can't visualize it. I'm an old SCUBA guy, and
in that realm we always see bubbles compress down until they are
equalized with the ambient pressure, but they never, never, never
purge.
When I voiced that counter-concern, the engine guys all said that the
analogy is not valid because the oil is so much more viscous than
water. Yes it is, but I can't get my head around how that makes the
air purge any differently.
So I am putting this out to a broader audience--what are your thoughts
or observations on mounting an oil cooler upside down? Bonus points
to anyone who has actually done it.
Thanks--
Steve.
Old March 10th 07, 06:26 PM posted to rec.aviation.homebuilt
Rip
Folks--
top.
purge.
Thanks--
Steve.
In production aircraft, you will see oil coolers mounted in every
possible orientation.
Keep in mind that an oil pump moves a tremendous volume of oil every
minute. Air bubbles are not an issue if the rest of the plumbing is ok.
Just my opinion, and worth what you paid for it.
Rip
CSEL, A&P/IA
Old March 11th 07, 12:40 AM posted to rec.aviation.homebuilt
stol
On Mar 10, 10:39 am, wrote:
Folks--
top.
purge.
Thanks--
Steve.
Oil pressure is usually 60-80 psi. In a full flow configuration the
cooler doesn't care if it is upside down..Any air will flush out in
the first few seconds of running. I would be a little concerned in a
partial flow set up. I haven't seen one of those is 40 years though.
Anyone tried using a portable 12v cooler in your plane? Jack Allison Owning 23 November 10th 05 03:49 AM
Oil Cooler Al Girdvainis/Penni Abram Home Built 0 November 26th 04 01:28 AM
Metal in the Oil Cooler Justin H Home Built 4 August 18th 04 11:28 AM
Oil cooler? Rick Home Built 1 March 22nd 04 09:41 AM
Oil Cooler for Auto-Conversions Bruce A. Frank Home Built 0 October 30th 03 06:06 AM
