Our 172 has two screws missing from under the wing where
it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S |
sounds like screws that cover the trim piece where the wing and fuselage
meet. The "Bolts" you seek are rather large.. not screws.. that hold the wing.. and should be found behind the trim piece.. but when in doubt.. ask your mechanic to show things to you. B wrote in message ups.com... Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S |
They are where the wing and fuselage meet. What you said makes sense.
Those screws looked large compared with those on the household appliances, but they are not that big. Google'd a bit and found Sporty's offering bags of exterior screws and washers, explicitly stating there are not interior structural parts. Do these things fall off often ? like the fasteners in passenger compartment in cars. But what can cause these screws to become loose one by one, over the period of 3 months ? But no screws from under the other wing ? I suspect the AP in the last 100 hours didn't screw them in, if these needed to be unfastened. I called our AP and couldn't reach him. Will call again. Thanks for the response. P S On Mar 10, 8:32 pm, "BT" wrote: sounds like screws that cover the trim piece where the wing and fuselage meet. The "Bolts" you seek are rather large.. not screws.. that hold the wing.. and should be found behind the trim piece.. but when in doubt.. ask your mechanic to show things to you. B wrote in message ups.com... Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S |
On Mar 11, 2:44 am, wrote:
They are where the wing and fuselage meet. What you said makes sense. Those screws looked large compared with those on the household appliances, but they are not that big. Google'd a bit and found Sporty's offering bags of exterior screws and washers, explicitly stating there are not interior structural parts. Do these things fall off often ? like the fasteners in passenger compartment in cars. But what can cause these screws to become loose one by one, over the period of 3 months ? But no screws from under the other wing ? I suspect the AP in the last 100 hours didn't screw them in, if these needed to be unfastened. I called our AP and couldn't reach him. Will call again. Thanks for the response. P S On Mar 10, 8:32 pm, "BT" wrote: sounds like screws that cover the trim piece where the wing and fuselage meet. The "Bolts" you seek are rather large.. not screws.. that hold the wing.. and should be found behind the trim piece.. but when in doubt.. ask your mechanic to show things to you. B wrote in message oups.com... Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S Those screw are likely #8 sheet metal screw with countersunk washers used to hold the wing root trim panel on. You should check exterior screws on access panels every couple of flight. The vibration wil cause them to back out. |
On Mar 12, 9:12 am, Mark Hansen wrote:
On 03/12/07 08:07, wrote: On Mar 11, 2:44 am, wrote: They are where the wing and fuselage meet. What you said makes sense. Those screws looked large compared with those on the household appliances, but they are not that big. Google'd a bit and found Sporty's offering bags of exterior screws and washers, explicitly stating there are not interior structural parts. Do these things fall off often ? like the fasteners in passenger compartment in cars. But what can cause these screws to become loose one by one, over the period of 3 months ? But no screws from under the other wing ? I suspect the AP in the last 100 hours didn't screw them in, if these needed to be unfastened. I called our AP and couldn't reach him. Will call again. Thanks for the response. P S On Mar 10, 8:32 pm, "BT" wrote: sounds like screws that cover the trim piece where the wing and fuselage meet. The "Bolts" you seek are rather large.. not screws.. that hold the wing.. and should be found behind the trim piece.. but when in doubt.. ask your mechanic to show things to you. B wrote in message oups.com... Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S Those screw are likely #8 sheet metal screw with countersunk washers used to hold the wing root trim panel on. You should check exterior screws on access panels every couple of flight. The vibration wil cause them to back out. I'm always tightening screws during the pre-flight inspection. Just yesterday I found a screw on the front of the cowling that was backed about half way out. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA- Hide quoted text - - Show quoted text - Those screws go into anchor nuts that have a self-locking feature. The nuts wear out and don't hold the screw snug anymore and vibration will shake them out. It's not a big deal unless enough of them fall out that the trim starts beating around in the wind. It could foul the flap, besides beat the windows up. Or make you mess your pants. The nuts need replacing, but the wing tank has to come out to do it. Pain in the neck. Maybe a bit of Loctite on the screw would do it. Use the Loctite 222 purple (low strength) stuff. Dan |
On Mar 10, 8:00 pm, wrote:
Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S My old CFI used to say that screws were used for things that were not very important. Important stuff has rivets. I've mostly found that to be true. -Robert |
On Mar 10, 10:00 pm, wrote:
Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S Those screws are for the fairing that covers the joint between the fuselage and the wing. There is a long narrow fairing panel secured with a 10 or 12 screws. The holes in the panel are quite large ( to allow for variation in space between the wing and fuselage when first installed) the screws are put in with countersunk washers to cover the holes. The holes in the wing have #8 size Tinnerman nuts. These are sheet metal type fasteners and take a type B sheet metal screw. A type B sheet metal screw has a blunt point and a different thread pitch than the more common Type A screw which has a sharp point. These are not self locking nuts so the screws can back out over time if not properly torqued. Type B screws will torque up properly many times Type A screws will eventually damage the nut and lose torque more easily. Some times a loose or damaged #8 tinnerman nut will take a #10 screw for a while. Sometimes when the Tinnerman nuts are completely stripped out they will be replaced with a Rivnut which is an aluminum nut designed to be installed in a blind area. These take machine screws so you might have a mix of both styles. |
On Mar 13, 6:49 am, "John" wrote:
On Mar 10, 10:00 pm, wrote: Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S Those screws are for the fairing that covers the joint between the fuselage and the wing. There is a long narrow fairing panel secured with a 10 or 12 screws. The holes in the panel are quite large ( to allow for variation in space between the wing and fuselage when first installed) the screws are put in with countersunk washers to cover the holes. The holes in the wing have #8 size Tinnerman nuts. These are sheet metal type fasteners and take a type B sheet metal screw. A type B sheet metal screw has a blunt point and a different thread pitch than the more common Type A screw which has a sharp point. These are not self locking nuts so the screws can back out over time if not properly torqued. Type B screws will torque up properly many times Type A screws will eventually damage the nut and lose torque more easily. Some times a loose or damaged #8 tinnerman nut will take a #10 screw for a while. Sometimes when the Tinnerman nuts are completely stripped out they will be replaced with a Rivnut which is an aluminum nut designed to be installed in a blind area. These take machine screws so you might have a mix of both styles.- Hide quoted text - - Show quoted text - The Tinnermans often lose one side of their "thread." The steel is brittle and the thing will break off. There's the possibility of a Rivnut but the Tin nut has to be removed first, and doing so will leave loose bits rattling around under the fuel tank. Those bits have a way of wedging into places they shouldn't be and will wear holes in the tank. The better solution is to replace the nut, but the tank has to come out. To do that, the tank has to be completely drained, another pain. Still, it's a better system than Citabria uses. They have really short sheet metal screws into the root rib, and the compression rib is just inside that root rib and gets in the way. The rib holes strip out and won't hold the screws anymore. Dan |
Hi everyone,
On Mar 13, 7:57 am, wrote: On Mar 13, 6:49 am, "John" wrote: On Mar 10, 10:00 pm, wrote: Our 172 has two screws missing from under the wing where it connects to the fuselage above passenger door. The size of those screws are quite big. My question is whether they are important to the stuctural integrity of the wing ? They may have come off during flight due to the vibrations. But it is still some hours before the next 100 hours. Are those screws important for holding the wing to the fuselage ? or are they only there to cover the holes, and there are some other bigger screws/nuts inside the wing that are doing the real work ? A speedy reply will be appreciated. P S Those screws are for the fairing that covers the joint between the fuselage and the wing. There is a long narrow fairing panel secured with a 10 or 12 screws. The holes in the panel are quite large ( to allow for variation in space between the wing and fuselage when first installed) the screws are put in with countersunk washers to cover the holes. The holes in the wing have #8 size Tinnerman nuts. These are sheet metal type fasteners and take a type B sheet metal screw. A type B sheet metal screw has a blunt point and a different thread pitch than the more common Type A screw which has a sharp point. These are not self locking nuts so the screws can back out over time if not properly torqued. Type B screws will torque up properly many times Type A screws will eventually damage the nut and lose torque more easily. Some times a loose or damaged #8 tinnerman nut will take a #10 screw for a while. Sometimes when the Tinnerman nuts are completely stripped out they will be replaced with a Rivnut which is an aluminum nut designed to be installed in a blind area. These take machine screws so you might have a mix of both styles.- Hide quoted text - - Show quoted text - The Tinnermans often lose one side of their "thread." The steel is brittle and the thing will break off. There's the possibility of a Rivnut but the Tin nut has to be removed first, and doing so will leave loose bits rattling around under the fuel tank. Those bits have a way of wedging into places they shouldn't be and will wear holes in the tank. The better solution is to replace the nut, but the tank has to come out. To do that, the tank has to be completely drained, another pain. Still, it's a better system than Citabria uses. They have really short sheet metal screws into the root rib, and the compression rib is just inside that root rib and gets in the way. The rib holes strip out and won't hold the screws anymore. Dan I just found there were so many more helpful posts. Very educational. I sure hope the parts broken off inside the wing do not get caught under the fuel tank. I flew that airplane. Funny thing is that when I took off, I was a bit close to another small plane (1/2 mile), and got in its wake. The plane shook and one wing dropped. I kept turning my head to look at the right wing. Silly, but I couldn't stop wanting a visual confirmation that that wing was still the-). If we have to take out the fuel tank to fix those screws, it probably will not be done until it is absolutely necessary. Will watch out for the other screws around that area. I bought a small screw/bit set, and will tighten the loose ones in my next pre-flight. Thanks much for all the insight. P S |
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA | [email protected] | Soaring | 0 | September 11th 06 03:48 AM |
Stuck panel screws | [email protected] | Owning | 10 | July 7th 06 12:51 AM |
FAA Screws Up Again | BushOKDemocratsSTUPID | Instrument Flight Rules | 2 | March 22nd 06 10:39 PM |
Media screws up again... | Sam | Piloting | 181 | June 17th 04 06:08 PM |
Avsim screws itself | Azhosers | Simulators | 2 | April 5th 04 10:32 PM |
