Sounds like a thread in the making. How about some
of the best and biggest oops's. Or a few very near oops's. Here are a few. Barograph on the ground in a tent after the diamond goal /gold distance flight. Big rains that night. Barograph under water in the moring. Barograph was the old smoked foil type. Luckily, the trace did not wash off, but there was a high water mark well above max flight altitude. Barograph wound and put in but not turned on. Diamond Distance flight completed, with a simple up and down scribe by the needle. Barogprah installed but the needle wasn't moved to the drum side of the 'off' post. Trace began when the plane got high enough to raise the arm above the post. This was on a home made, smoked foil barograph. Launch point then jokingly labeled as 'Bungee launch from Pike's Peak'. Ready to apply the clear lacquer to the smoked foil after the flight. Grabbed the wrong can and sprayed it with carburator cleaner. Bye-bye trace. Smoking the foil was the most fun. We used rubber cement to glue the foil to the drum. Camphor to put the soot on the foil. Hold the drum with vice grips, as it get rather exciting when the rubber cement ignites. After a while you get use to it. Just blow it out, and put it back in the soot right at the top of the flame. As for the paper types, I have seen a few flights lost by pinching the top down against the drum and keeping it from turning. Hang in there, Tony. A tip that you may not be aware of. The obvious, make sure you wrap the paper so the stylus won't catch it and pull it off. The not so obvious, put a rubber band around the drum well above the max altitude you expect to see. This way, if your tape lets the paper loose, the rubber band will hold it in place. What kind of barograph ar eyou using? Winter with paper and ink? Replogle? Other? Old Smoky? Steve Leonard Wichita KS |
Replogle barographs were what ive killed. great stories!!! |
It's not just mechanical barographs...
Me going for Silver height shortly after soloing - put in club's Model D, made sure little light is flashing, fly. Download trace in evening - corrupt. Club computer "whiz" had tried to upgrade ("flash"?) the internal software but had ballsed it up and not told anyone. The club's other Model D had a sticker on the side saying "broken" - when we tested it, it worked fine. Harrumph. Shortly after, on another flight, the battery ran out. I realised there was no system for ensuring that the logger had a good battery in it, so fitted a new (dated) Duracell battery and simply put a sticker on the side noting the date. Next week... sticker has been scratched off and a cheap supermarket battery of unknown age inserted. Great. I now know to check the barograph on the computer *before* flight (it gives the battery voltage, among other things). Dan |
| On Ebay: Winter Altimeter; Replogue Barograph; Surecheck PCAS | Steve Koerner | Soaring | 0 | September 22nd 06 04:19 PM |
| For Sale- Replogle barograph | [email protected] | Soaring | 5 | April 24th 06 03:41 AM |
| Peravia Barograph Question | Roy Bourgeois | Soaring | 5 | September 19th 05 08:26 PM |
| Replogle Barograph For Sale | Guy Byars | Soaring | 0 | September 19th 05 11:07 AM |
| FS Replogle Barograph | Al Groth | Soaring | 0 | August 15th 04 12:24 AM |
