Fuel prices--BTU's per gal.
Old May 28th 07, 02:27 AM posted to rec.aviation.homebuilt
jerry wass
Default Fuel prices--BTU's per gal.
Hate to disagree. but there are more BYU's in a GALLON of Avgas than in
a GALLON of Mogas. Why?? Avgas weighs more per Gallon...
Most fuel type hydrocarbons have nearly the same BTU's per Lb.
Old May 28th 07, 02:44 AM posted to rec.aviation.homebuilt
"Jerry Wass" wrote in message
. net...
Hate to disagree. but there are more BYU's in a GALLON of Avgas than in a
More BYUs? Let see...BYU, BYU Hawaii, and BYU Idaho. How do you get all of
those universities in a gallon of avgas?
Old May 28th 07, 02:46 AM posted to rec.aviation.homebuilt
. net...
Old May 29th 07, 01:14 PM posted to rec.aviation.homebuilt
Ron Natalie
. net...
BTU is British Thermal Unit...So there's no bacon at all in it?
Old May 28th 07, 05:43 AM posted to rec.aviation.homebuilt
Morgans[_2_]
I may have to back up off of that statement, and I'll tell you my (possible)
faulty reasoning.
Generally, the more refined, higher octane fuel will have less BTU content.
I "forgot" to take into account that the primary way that 100LL gets its
high octane rating is by the use of lead. That throws things off a little
bit.
Jim in NC
Old May 28th 07, 03:21 PM posted to rec.aviation.homebuilt
Peter Dohm
"Morgans" wrote in message
a
(possible)
faulty reasoning.
content.
bit.
Jim in NC
Very true, although I don't know enough chemistry to understand just why the
fuels with the higher octane number are generally less dense. Fortunately,
the lead is probably a small fraction of one percent of the fuel by weight.
However, in the case of Mogas, the addition of unknown quantities of so
called oxigenates, such as ethanol, the energy content per unit is reduced
by some amount.
When measuring fuel by volume (usually gallons or litres) the ethanol is
said to contain approximately 60% of the energy of gasolene--that is simply
the relationship which I have heard/read consistently repeated. Thus, Mogas
that contains 10% ethanol should contain about 96% as much energy as "real"
gasolene.
When measuring by weight, I suspect that the result is slightly worse. My
recollection from physics class is that an oxigen atom is about the same
size as a carbon atom and slightly heavier; so that the ethanol should be
slightly heavier by volume. However, the oxigen atom contributes nothing to
energy content--since ample oxigen is readily available from the air.
Therefore, with the caveat that my knowledge of molecular structure and
density is not strong; the effect of ethanol on energy content by weight is
probably worse than by volume. As a guess, Mogas that is 10% ethanol by
volume probably contains about 95% as much energy, per pound or per
kilogram, compared to "real" gasolene--despite being more hygroscopic and
(so they say) also slightly more expensive to produce.
Peter
Old May 28th 07, 08:38 PM posted to rec.aviation.homebuilt
Barnyard BOb
From Wikipedia, the free encyclopedia:
Energy content
Gasoline contains about 34.6 megajoules per litre (MJ/l) or 131 MJ/US
gallon. This is an average, gasoline blends differ, therefore actual
energy content varies from season to season and from batch to batch,
as much as 4% more or less than the average, according to the US EPA.
Fuel type BTU/US gal Research octane
Regular Gasoline 125,000 Min 91
Aviation gasoline 120,200
- Barnyard BOb -
Old May 29th 07, 01:05 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Why, Barnyard BoB, I would like to thank you for that information.
I really didn't think you cared, but you must, since you backed up my
original claim! g
Jim in NC
Old May 29th 07, 04:29 PM posted to rec.aviation.homebuilt
Barnyard BOb
original claim! g
I 'care' about truth, justice and the American way!
Even a blind pig can stumble on an acorn.
Seems you did. g
Be well ol' friend,
Barnyard BOb - let the chips fall where they may
Old May 29th 07, 10:14 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Well, thanks again, ........
Sooopperrr BoB ! ! ! g
Jim in NC
You can tell high fuel prices ... john smith Piloting 0 August 17th 06 08:09 PM
Fuel prices Paul kgyy Owning 14 October 19th 05 11:55 PM
Fuel Prices Ross Richardson Owning 60 September 30th 05 03:06 AM
Fuel Prices ~R Rotorcraft 0 September 10th 05 04:56 PM
Fuel Prices S Green Piloting 0 May 9th 04 10:47 PM
