www.defensedaily.com
Marine Corps Plans To Keep Harriers Flying Until At Least 2021 June 20, 2007 The Marine Corps is taking several steps, including an airframe fatigue effort and work to maintain the supplier base, to ensure its fleet of Boeing [BA] AV-8B Harriers will continue to fly well into the next decade and beyond, according to a Marine Corps official. The service has to maintain its fleet of Harriers for operational use until the first Lockheed Martin [LMT] F-35B short take off and vertical landing (STOVL) variant of the Joint Strike Fighters comes on line. The first Harrier is set to leave the fleet in 2012, with the final aircraft retiring in 2021, Col. Mitch Bauman, AV-8B program manager, told Defense Daily in a recent interview. The Marine Corps has a fatigue life effort currently underway looking specifically at the Harrier airframe, Bauman said. The Harrier was built with 6,000 hours of lifetime in it, he added. Working with the program's structural engineers, the Marine Corps has been able to track flight hours and convert them into a metric called Fatigue Life Expended (FLE), Bauman said. The operational flight program (OFP) inside the aircraft will record that information, he added. "We believe we can get the airplane out to 2025 plus, using the FLE method and using inspections to take care of the airframe," Bauman said. Back in the 1990s, the Marine Corps realized the Harrier was going to be flying a lot longer than originally imagined. So they put together an aircraft life extension program that extended the service life of the wing, the vertical tail and some subsystems components out to 9,500 hours, Bauman said. A Rolls-Royce engine is the heart of the Harrier. The STOVL peculiarities of the airplane and the components Rolls-Royce builds are very complex, Bauman said. The Marine Corps has been working with Rolls-Royce to get those components into a component improvement program (CIP). "We have what we call a propulsion systems management plan that looks at the total aircraft engine and looks at life of the engine, all the individual components, the hot section, the cold section and dictates through analysis what needs to be improved or replaced," Bauman explained. The Marine Corps also needed to get the supply chains for the airframe and the engine under control, he added. The service took a major step in that direction earlier this month when the Pentagon signed a $258 million performance-based logistics (PBL) contract with Boeing. The Harrier Integrated Supply Support (HISS) program also covers the Italian and Spanish Harriers, the company reported. The five-year firm fixed price contract will look at 48 aircraft systems, 1,026 repairables and 70,500 consumables, Bauman said. Under terms of the contract, which includes the ability to forecast and project Harrier flight hours, Boeing will work with its sub vendors to maintain the AV-8B's supply chain, he added. "Some decisions will have to be made, [for example] whether you buy lifetime buys, because sometimes it is not affordable for some of these companies to keep their [production] lines open," Bauman said. The United States has 150 Harriers in its fleet; the Italians 17, the Spanish 17, and the British 83. "Rolls-Royce, just like Boeing, is going to have to step up to the plate, too, working with Naval Inventory Control Point (NAVICP) in getting the supply chain under control for the engine components," Bauman said. "They are working toward these long-term requirements contracts so they can forecast out and move toward a component PBL in the future." The AV-8B is seeing extensive use in Iraq, particularly in Al Asad, Bauman said. The Marines have 10 aircraft assigned to the area and they are averaging more than 30 flight hours a month. In 2006 and 2007 during Operation Iraqi Freedom, Harriers flew 18,000 combat hours, 6,000 sorties, and the service never lost a single plane, he added. "They have been flying close air support with the LITENING pod. That has brought the Harrier back into the real-world of precision guided munitions," Bauman said. "They have been doing a wonderful job of dropping JDAMs (Joint Direct Attack Munition), the 500-pounders and 1,000-pounders. And we just got clearance to drop the GBU-51, which is the low- collateral damage bomb." The last squadron that just came back also reported that they identified approximately 50 improvised explosive devices (IED) in theater with Northrop Grumman's [NOC] LITENING pod, Bauman noted. One of the things that the Marine Corps has put together to help offset some of the operational wear and tear of its Harriers is a program called "Preset-Reset," Bauman said. Before the airplane goes to Iraq, the Marine Corps uses contractor maintenance to put in all the technical directives and engineering change proposals (ECP) that the aircraft needs to make it a full mission systems to go to Iraq, he added. The AV-8B goes through a similar process when it returns from operations, Bauman said. "We took money [Headquarters] Marine Corps sent down and pushed it down to fleet support teams and they have come up with these maintenance requirements decks, cards, that have developed. It's one more way of priming the pump to get these airplanes out there in great condition," he said. |
"Marine Corps Grounds V-22 Osprey Aircraft" | Mike[_1_] | Naval Aviation | 0 | February 18th 07 03:40 PM |
MARINE AIRSHOW - "YIMG_1179.jpg" 104.6 KBytes | David Dyer-Bennet | Aviation Photos | 3 | November 13th 06 07:24 AM |
MARINE AIRSHOW - "YIMG_1118.JPG" 97.3 KBytes | Bruce R | Aviation Photos | 0 | November 9th 06 02:19 AM |
Marine Corps Now Authorized To Use "Involuntary Recall" To Force Thousands Back To Iraq (for Israel, of course!) - see comments on page 1 of following URL: | dontcowerfromthetruth | Naval Aviation | 0 | August 23rd 06 09:23 AM |
"'Marine One' finds home at Nixon site" | Mike | Naval Aviation | 7 | July 2nd 06 09:54 PM |
