The following security checking message prompts SSA to place on hold
any/all current FAI Badge claims for distance based on EW Flight Recorder models A through D, using position data provided by certain Garmin GPS units: "[Filename] "Validation check passed, data indicated as correct. "The following fixes are not recorded as being relative to the WGS84 geodetic datum. Care should be taken that these fixes are not used to validate the flight." "[#] fixes from [date & time] to [date & time] UTC inclusive." * *in the case prompting this "hold," no fixes were recorded other than those reported unusable for flight validation. PILOTS AFFECTED: applicants for any FAI badge distance or goal flight, when the above message is received during security checking. THE PROBLEM: as of an unknown date, the Garmin E-Trex GPS unit no longer records the datum in use. The same may be true of other Garmin GPS units listed in the IGC Approval Document for EW Flight Recorder models A through D. Without datum information from the Garmin, the EW security check fails. CURRENT STATUS: Garmin, EW and IGC have been alerted to the problem. Resolution appears to require their concerted and cooperative efforts. PILOT ACTION: Users of EW Flight Recorder models A through D can perform a security check on a recent data file to determine whether they're affected by this problem. (Go to http://www.fai.org/gliding/gnss/freeware.asp and download BOTH the IGC Shell "zip" file AND the EW Avionics DLL; for B & D models, download the "Windows program" as well. Install all these programs in the same directory. Create a desk-top shortcut to the IGC SHELL program and follow the simple instructions for securirty checking - it's basically a matter of point-and-click.) IF YOUR RECENT BADGE FLIGHT YIELDS AN ERROR MESSAGE AS ABOVE: you may submit the data file for FAI badge review, but realize processing will be delayed until the security message issue is resolved. Please include a current e-mail address with your application so we can keep you up to date. IF YOU RECEIVE NO SUCH MESSAGE: please submit your badge application as usual. IF YOU HAVE ANY QUESTIONS, PLEASE E-MAIL . |
| Thread Tools | |
| Display Modes | |
| Only six US OLC flight claims? | Mike the Strike | Soaring | 10 | November 30th 06 01:25 AM |
| Pilot claims no blame in July crash | Mortimer Schnerd, RN | Piloting | 48 | March 15th 06 10:00 PM |
| Australian Army torture claims surface | Aerophotos | Military Aviation | 16 | May 15th 04 10:23 AM |
| Aren't and his claims of German U2 invention | Wayne Allen | Military Aviation | 20 | February 21st 04 07:59 AM |
| How find out one's aviation insurance claims history? Aviation Claims Information Bureau? | cloudclimbr | Owning | 1 | February 16th 04 12:16 AM |
