Thunderbird crash today
Old September 15th 03, 04:37 AM
John Doe
Default Thunderbird crash today
Looks like one of the thunderbirds crashed today....pilot ejected.....
Old September 15th 03, 11:13 AM
David Hartung
"John Doe" wrote in message
link.net...
At least the Pilot got out!
Old September 15th 03, 11:24 AM
Aerophotos
another SINGLE engined regular crashing Viper bites the dust.. told ya
so... twins much safer...
heavens forbird the F-35 ever entering service...it will replicate the
F-16 in every way.. just be a more costly toy.
link.net...
Old September 15th 03, 02:15 PM
Keith Willshaw
"Aerophotos" wrote in message
Lets look at the actual Class A loss rates shall we
http://safety.kirtland.af.mil/AFSC/R...aft_stats.html
F-4 4.64
F-5 8.82
F-15 2.47
F-16 4.19
F-16 (Engine mishaps) 1.53
F-102 13.69
F-104 30.63
F-106 9.47
F-111 6.13
F-117 4.62
Seems like the F-16 is a pretty safe airplane in fact, only the
F-15 has bettered it in safety terms
Keith
Old September 15th 03, 10:47 PM
Bil Reese
Usually the problem with a two engine A/C loosing an engine very suddenly
is... Loosing one engine suddenly causes a yaw which to great to save the
plane still using the other engine and application of a LOT of opposite
rudder to avoid a fatal spin condition... From what I seem to remember
regarding general aviation, the crash rates of dual engine planes is about
1/2x higher than in single engine planes, BUT those dual engine planes that
fall out of the sky have a 3 times higher death rate per crash than single
engine planes.. so which one is more safe??? the plane that crashes a
little less, or the one that will kill you more quickly ??
BR
"Keith Willshaw" wrote in message
F-4 4.64
F-5 8.82
F-15 2.47
F-16 4.19
F-102 13.69
F-104 30.63
F-106 9.47
F-111 6.13
F-117 4.62
Keith
Old September 15th 03, 11:34 PM
Ed Rasimus
BR
There are stats and then there are stats. Which is right usually
relates to what you want to prove at the moment.
While what you say may be true with regard to general aviation, most
tactical military aircraft are center-line thrust, so the engine out
yaw is really insignificant. Not too many problems losing an engine
even in critical flight regimes as long as you're above min control
speeds.
OTOH, my experience with regard to combat engine losses was that there
was no significant difference between single engine and multi engine.
Certainly if the loss is a pure mechanical failure, a second engine is
nice, but if the first engine is lost due to battle damage, there's a
good chance the second engine will follow shortly thereafter.
Now, all that being said, I've got a good friend flogging heavies for
American Airlines who recently transitioned to 777s. I asked him about
what you do with a fully loaded crowd-killer that losses one of those
behemoth engines on the wing right at Vmc or shortly after lift-off.
His answer was that it's all computer controlled. Engine is pushed up,
engine is shut down, rudder is input, controls respond as required to
provide neutral control impressions to the driver. Neat stuff. Takes a
lot of the thrill out of the business.
Ed Rasimus
Fighter Pilot (ret)
***"When Thunder Rolled:
*** An F-105 Pilot Over N. Vietnam"
*** from Smithsonian Books
ISBN: 1588341038
Old September 16th 03, 05:01 AM
Wingedhoof
Gee, I must have missed the outcome of the Safety Investigation Board when they
said there was an engine problem.
Old September 16th 03, 05:39 AM
Gene Storey
No electricity, plane stops flying, pilot gives it back to the taxpayers.
Homebuilt Airplane Crash Harry O Home Built 1 November 15th 04 03:40 AM
Four Winds 192 Crash into the Miami Federal Reserve Building, a year ago today Billgran Home Built 3 December 6th 03 03:22 PM
Homemade plane crash Big John Home Built 9 October 17th 03 06:45 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 07:31 PM
