On C-130s painted in camoflauge they used to leave a panel bare on each side of
the vertical stab. There was a circle in the middle that was painted. What was the purpose of doing this? Dan, U. S. Air Force, retired |
That circle in the middle isn't paint, it's - for lack of a better term -
glue. Actually, a combination of adhesive and waterproofing. There is a longwire VHF antenna that runs from there to the spine just behind the flight deck. TSg Bill Most of the C-130s I worked on were the bubble top HC-130P and HC-130N and I seem to recall the long wires went to the leading edge of the vertical stab. Come to think of it the bare panel seems to have disappeared on the ones I worked on long before we went to gray. Maybe it was a change on ours. Many thanks. Dan, U. S. Air Force, retired |
William Hughes wrote:
On 18 Sep 2003 21:20:20 GMT, in rec.aviation.military (B2431) wrote: On C-130s painted in camoflauge they used to leave a panel bare on each side of the vertical stab. There was a circle in the middle that was painted. What was the purpose of doing this? That circle in the middle isn't paint, it's - for lack of a better term - glue. Actually, a combination of adhesive and waterproofing. There is a longwire VHF antenna that runs from there to the spine just behind the flight deck. TSg Bill 7 ACCS (EC-130B) '75-'79 Much more likely it's an HF (High Frequency) antenna. VHF doesn't use 'long wire antennas' -- -Gord. |
![]() "Gord Beaman" wrote in message ... William Hughes wrote: On 18 Sep 2003 21:20:20 GMT, in rec.aviation.military (B2431) wrote: On C-130s painted in camoflauge they used to leave a panel bare on each side of the vertical stab. There was a circle in the middle that was painted. What was the purpose of doing this? That circle in the middle isn't paint, it's - for lack of a better term - glue. Actually, a combination of adhesive and waterproofing. There is a longwire VHF antenna that runs from there to the spine just behind the flight deck. TSg Bill 7 ACCS (EC-130B) '75-'79 Much more likely it's an HF (High Frequency) antenna. Yep. |
... Much more likely it's an HF (High Frequency) antenna. VHF doesn't use 'long wire antennas' You can operate on long wire antennae with VHF if you cut them right (centre-fed droppy V-dipole, etc.) but there's no need to on an aircraft. -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
![]() "Andrew Chaplin" wrote in message ... "Gord Beaman" wrote in message ... Much more likely it's an HF (High Frequency) antenna. VHF doesn't use 'long wire antennas' You can operate on long wire antennae with VHF if you cut them right (centre-fed droppy V-dipole, etc.) but there's no need to on an aircraft. The c-130 is identical to what Gord wrote. In fact, my friends in Mojave are seeking an STC to eliminate these wirs and put the antenna in the vertical stab. (ie L139) |
are seeking an STC to eliminate these wirs and put the antenna in the vertical stab. (ie L139) C-130s are not STCed. To change it requires a class B mod or TCTO. Dan, U. S. Air Force, retired |
Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 07:51 PM |
Question for Fellow CFII's regarding Partial Panel Training | Brad Z | Instrument Flight Rules | 16 | May 26th 04 11:25 PM |
Air Force Academy Review Panel Sets Public Meeting | Otis Willie | Military Aviation | 0 | September 3rd 03 09:56 PM |
Air Force Museum forms review panel | Otis Willie | Military Aviation | 2 | August 29th 03 04:41 PM |
Air Force Academy Review Panel Sets Second Public Meeting | Otis Willie | Military Aviation | 0 | July 10th 03 02:39 AM |
