Honda Biz Jet With Wing Pylon Mounted Engines ?
Old September 7th 07, 12:16 AM posted to rec.aviation.piloting
Robert11
Default Honda Biz Jet With Wing Pylon Mounted Engines ?
Hello,
Saw a pix of that relatively new Honda Biz jet.
The one with the engines mounted on the wing pylons.
What do they claim are the major advantages of an arrangement like this?
Is it solely to reduce cabin noise, or...?
Sure is unusual.
Thanks,
Bob
Old September 7th 07, 12:24 AM posted to rec.aviation.piloting
B A R R Y
On Thu, 6 Sep 2007 19:16:00 -0400, "Robert11"
Hello,
New? G
Less FOD.
Old September 7th 07, 08:40 AM posted to rec.aviation.piloting
Thomas Borchert
Robert11,
Sure is unusual.
Unusual - maybe. New? No! http://en.wikipedia.org/wiki/VFW-614
Thomas Borchert (EDDH)
Old September 7th 07, 09:17 AM posted to rec.aviation.piloting
On 7 Sep, 08:40, Thomas Borchert wrote:
Robert11,
Sure is unusual.
Unusual - maybe. New? No!http://en.wikipedia.org/wiki/VFW-614
My (not very well informed) understanding is that
rear mounted engines result in a quieter cabin
but that wing pylon mounted engines result in a lighter airframe
for the same size/power etc.
The reason for the weight saving is as follows:-
Consider the rear mount case. The wing root
must be strong enough and stiff enough to support the
whole weight of the plane. By moving
the engines to wing pylons the wing root structure
is relieved of some load since the weight of the engines
is now directly on the wing. The wing can therefore be
made lighter. I have read - on the internet
I guess - that the weight penalty in the case of the VC10
vs 707 was 10%. Then you need to add the extra fuel to
carry the extra weight if you want to go the same distance.
This multiplies the penalty further. And further, since
the extra fuel needs extra tanks ... Maybe the 10%
included all of that but my dodgy memory
of dodgy info says that it did not.
I understand that this issue was a major cause of the
commercial failure of the VC10. Not enough people
were prepared to pay for the quieter cabin.
There are also safety issues in the event of a
catastrophic engine failure. The moderm pylon
mounted engines are designed to safely fall off
in the event of say a huge imbalance developing
in the rotating parts. Safe for everyone except
those underneath! :-)
Old September 7th 07, 09:21 AM posted to rec.aviation.piloting
Robert11,
Sure is unusual.
Forgot these - not very authorititave looking:-
http://adg.stanford.edu/aa241/propul...placement.html
http://www.hq.nasa.gov/pao/History/SP-468/ch13-3.htm
Old September 7th 07, 11:34 AM posted to rec.aviation.piloting
Matt Whiting
Robert11,
Sure is unusual.
I suspect it is more marketing and being different than anything else.
You are correct that the wings have less fuselage weight to support when
on the ground, but they now have a lot more torsional load due to the
distance from the thrust centerline to the center of wing structure.
Without having the full specs and doing the calculations, I can't say
which one trumps, but generally resisting bending loads is easier than
resisting torsional loads.
Matt
Pylon 8 problem gatt Piloting 8 June 26th 06 10:33 PM
CAM 125 Honda [email protected] Home Built 4 November 20th 05 03:26 AM
AND THE KIS CRUISER ROUNDS THE PYLON... Paul Folbrecht Home Built 38 January 18th 05 04:29 AM
Toyota vs Honda.. in the Air? robert arndt Military Aviation 5 March 25th 04 07:10 PM
Honda's New Jet and Honda Turbine Engines Larry Dighera Piloting 1 December 20th 03 12:59 AM
