ATC failure in Memphis
Old September 26th 07, 04:54 AM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Default ATC failure in Memphis
See
http://us.cnn.com/2007/US/09/25/memp...afu/index.html
Was it truly an accident? It sure happens at a convenient time for those who
want to fuel the argument that there's something wrong with ATC. However, the
incident could be used for both pro and con arguments, depending on how it is
spun, i.e., one could argue that "ATC lacks the resources it needs," or that
"ATC needs to be replaced by something new."
Old September 26th 07, 06:53 AM posted to rec.aviation.piloting,rec.travel.air
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
In rec.aviation.piloting Mxsmanic wrote:
See
One, it doesn't matter to you, since you don't fly.
Two, things like this happen. Wildfires in SoCal and Palmdale
come to mind. That's why there are LOAs in place with adjacent sectors
to handle things like this.
IF you do the research you say you do, you'd know and realize
this.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFG+fPayBkZmuMZ8L8RAhLHAJsFMUBODD96Z7KpEiYfDv TVV7Nj2gCg7gtX
7ajfwGmvzzIFfGyUMbCdexc=
=mYK4
-----END PGP SIGNATURE-----
Old September 26th 07, 05:21 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
A Guy Called Tyketto writes:
True, but many people on these groups do fly.
I don't think CNN bothered to mention that.
this.
I'm not the one who controls or influences the money or the policy of U.S.
aviation. You might want to share your research with those who do.
Old September 27th 07, 06:41 AM posted to rec.aviation.piloting,rec.travel.air
Hash: SHA1
The only true statement you've said in either newsgroup.
You actually think Continuous Negative News is going to go into
that? If so, you take them for granted. They are only going to tell the
public what they need to know. And the commercial flying public don't
give a damn about LOAs between ATC sectors in US airspace. They only
care about if it affects the flight they're on. If it doesn't, it isn't
their concern.
this.
Why should I? You're just going to tell me that it doesn't
square to what you've learned, and when asked about it, you tell us to
do our own research. So why should I share with others what you
wouldn't if you were in my position?
BL.
iD8DBQFG+0KYyBkZmuMZ8L8RAhsoAKDSs2HmF4YamHXl+RH+Xh X5wAepsACfWXqb
vpVmplmyZAXHKlumsNhFzMM=
=U6H+
Old September 27th 07, 07:45 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
that?
No, but since they don't, most people won't know about it--and so it won't
have any effect on the opinions of those who don't know. And a lot of those
people who don't know will vote.
The voting public.
And the commercial flying public don't give a damn about LOAs between
ATC sectors in US airspace. They only care about if it affects the
flight they're on. If it doesn't, it isn't their concern.
That's right. So after watching the report, it will seem to them that ATC
screwed up, which either means that ATC needs more resources, or that ATC
needs to be eliminated, depending on which spin they accept.
Why should I?
Because you may not be able to fly one day if you don't.
Old September 27th 07, 09:38 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
that?
won't have any effect on the opinions of those who don't know. And a
lot of those people who don't know will vote.
The voting public.
ATC screwed up, which either means that ATC needs more resources, or
that ATC needs to be eliminated, depending on which spin they accept.
Why should I?
I'll always be able to fly, fjukktard
Mainly because I know how to.
Bertie
Old September 26th 07, 08:38 AM posted to rec.aviation.piloting
Mxsmanic wrote in
See
those who want to fuel the argument that there's something wrong with
ATC. However, the incident could be used for both pro and con
arguments, depending on how it is spun, i.e., one could argue that
"ATC lacks the resources it needs," or that "ATC needs to be replaced
by something new."
Doesn't matter to you since you don't fly and never will
Bertie
Old September 26th 07, 11:26 AM posted to rec.aviation.piloting,rec.travel.air
Craig Welch
Mxsmanic wrote:
See
Huh? Failures such as this happen ...
Craig
Old September 26th 07, 12:41 PM posted to rec.aviation.piloting,rec.travel.air
Denny
ATC failed due to commercial phone lines going down, so we need to
replace ATC ????
How simply about replacing the part that failed with something more
robust..
I can see us spending 10 billion dollars for a whole new ATC structure
- that still depends on Ma Bell's 1912 phone lines...
denny
Old September 26th 07, 05:30 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Denny writes:
replace ATC ????
No, the argument would be along the lines of ATC being fragile and dangerous,
either because it needs more people/money, or because it is outdated and needs
to be replaced with Something New (depending on which ax you are grinding).
Ma Bell built telephone lines to be very robust indeed; its successors are not
so conscientious, unfortunately. In fact, Ma Bell went well beyond that (cf.
AUTOVON).
SSA Convention - Memphis [email protected] Soaring 29 February 16th 07 10:14 PM
NC/SC/VA Pilots to Memphis? [email protected] Soaring 1 January 25th 07 02:51 PM
Memphis Belle Update jsmith Piloting 1 September 2nd 05 10:22 PM
Flying to Memphis Greg Esres Piloting 6 October 15th 03 12:26 AM
Memphis in September Jim Fisher General Aviation 0 July 2nd 03 02:59 PM
