After flying Tomahawks and Citabrias, I took my first lesson in a
Cessna 172 last night. I asked many questions, but I had one question which nobody in my flying club (including the chief pilot) knew the answer to when I was the Why does the electric elevator trim have two switches (both of which must be depressed) on the yoke instead of one? The best theory I could come up with was "to avoid runaway trim if one switch stuck", but that is not very satisfying... Anyone know why? Chris (Another question: 13 fuel drains? What were they thinking??? But I am pretty sure the answer is "the lawyers designed that part, not the engineers.") |
Christopher Brian Colohan wrote in
: After flying Tomahawks and Citabrias, I took my first lesson in a Cessna 172 last night. I asked many questions, but I had one question which nobody in my flying club (including the chief pilot) knew the answer to when I was the Why does the electric elevator trim have two switches (both of which must be depressed) on the yoke instead of one? The best theory I could come up with was "to avoid runaway trim if one switch stuck", but that is not very satisfying... That's it. It's the one and only reason. Anyone know why? Chris (Another question: 13 fuel drains? What were they thinking??? But I am pretty sure the answer is "the lawyers designed that part, not the engineers.") There's 13 places where water gets stuck in that system. Bertie |
On Sep 28, 9:26 am, Bertie the Bunyip wrote:
There's 13 places where water gets stuck in that system. I seriously doubt that. -Robert, CFI |
"Robert M. Gary" wrote in news:1190997921.453348.284760@
22g2000hsm.googlegroups.com: On Sep 28, 9:26 am, Bertie the Bunyip wrote: There's 13 places where water gets stuck in that system. I seriously doubt that. Kay. Bertie |
That is exactly what I was taught learning the Mooney M20C meny years ago!
Ron Gardner "Robert M. Gary" wrote in message ups.com... On Sep 28, 9:26 am, Bertie the Bunyip wrote: There's 13 places where water gets stuck in that system. I seriously doubt that. -Robert, CFI |
![]() "R. Gardner" wrote in message .. . "Robert M. Gary" wrote in message ups.com... On Sep 28, 9:26 am, Bertie the Bunyip wrote: There's 13 places where water gets stuck in that system. I seriously doubt that. -Robert, CFI That is exactly what I was taught learning the Mooney M20C meny years ago! Ron Gardner Drains cost money and add points of failure, weight, and (nearly always) drag. They are *only* placed where the manufacturer is convinced that water might otherwise be trapped. Peter P.S.: Nevertheless, when this thread began, I really was tempted to suggest that the multitude of drains was to collect enough fuel to run a lawnmower--since we no longer throw it on the ground and most pilots don't put it back in the aircraft. :-) |
Peter
Using drained fuel for lawn mower. When using 115-145 fuel I always filled up my Zippo when preflighting and draining water out of tanks. We didn't have the plastic jars to drain into so let fall to ground under bird (in old days). Had to be careful and shake excess out of lighter (Zippo) or first couple of times when lit, would get a 6 inch flame and could singe your eye brows lighting your cigarette or pipe. ![]() Of course we never worried about the lead (TEL) in the gas (lots in the high octane fuel) and inhaling it when lighting the tobacco ![]() Probably part of the cause of my lung problems today. Big John ************************************************** *** ----clip---- P.S.: Nevertheless, when this thread began, I really was tempted to suggest that the multitude of drains was to collect enough fuel to run a lawnmower--since we no longer throw it on the ground and most pilots don't put it back in the aircraft. :-) |
![]() "Christopher Brian Colohan" wrote in message ... (Another question: 13 fuel drains? What were they thinking??? But I am pretty sure the answer is "the lawyers designed that part, not the engineers.") Cessna was offered the Monarch fuel tanks when the went back into production. But, according to Bill Barton, Cessna never even acknowledged the offer. There are 13 drains because they NEED them. The Monarchs need only one, ALL water is drainable, and they never leak. Cessna has particularly poor fuel tank engineering. http://www.sumpthis.com/imagescourte...er17274599.htm You should always test the trim switches according to the POH to prevent runaway trim. KG |
On Sep 28, 9:15 am, Christopher Brian Colohan
wrote: After flying Tomahawks and Citabrias, I took my first lesson in a Cessna 172 last night. I asked many questions, but I had one question which nobody in my flying club (including the chief pilot) knew the answer to when I was the Why does the electric elevator trim have two switches (both of which must be depressed) on the yoke instead of one? I assume this is a recent model 172. To avoid a stuck switch (or shorted switch) from running the trim. In the preflight checklist that Cessna provides one of the tests under the "trim test" section is to ensure that the trim does not move with either of the switches is moved by itself. Additionally you should ensure that the electric trim does not work at all when the auto-pilot cut-off is held down. The best theory I could come up with was "to avoid runaway trim if one switch stuck", but that is not very satisfying... Anyone know why? Chris (Another question: 13 fuel drains? What were they thinking??? But I am pretty sure the answer is "the lawyers designed that part, not the engineers.") No one really knows. Some believe that there is one for every lawsuit someone brought against Cessna because they forgot to drain the tanks. Few actually believe that Cessna designed the tanks to collect water at that many points. In anycase, we just drain them all. -Robert, CFII |
![]() "Robert M. Gary" wrote No one really knows. Some believe that there is one for every lawsuit someone brought against Cessna because they forgot to drain the tanks. Few actually believe that Cessna designed the tanks to collect water at that many points. In anycase, we just drain them all. From the pictures provided (by a link) in an earlier post, it is obvious (with the help of some added color agent) that there are, or could be, some very big problems if the tank is not drained at all of the provided drains. Everyone knows that the airplane is a group of compromises flying in close formation. It seems as though the tank design is a _big_ compromise, for some reason. It is hard for me to understand how Cessna could come up with such a poor design. I do realize that a wet tank has to have internal structures in place, with weight and strength being two of the most important design criteria, but it does seem like it should be possible to leave some pass through areas to let gas and water flow freely from bay to bay. It might have cost a little more, but when you are spending, what, over 200 AMU's to buy an airplane, should it not be possible to include some design improvements that costs a little more, than take the easy way out with nearly a dozen added (should be) unnecessary drains? If a tank design like that is Cessna's normal way of dong things, I would think Columbia's future owners have some genuine concerns. -- Jim in NC |
"Bad pressure switches discovered in Ospreys" | Mike[_1_] | Naval Aviation | 0 | June 22nd 07 07:14 PM |
How much do you trim? | Mxsmanic | Piloting | 89 | October 13th 06 05:14 AM |
Gear Warning Switches on a Mosquito | scooter | Soaring | 6 | March 9th 05 01:15 PM |
Fading Rocker Switches | O. Sami Saydjari | Owning | 2 | February 16th 04 03:54 PM |
FS on EBAY, circuit breaker switches | flyer | Home Built | 0 | December 3rd 03 06:59 PM |
