Plexiglas cement??
Old November 5th 07, 05:09 AM posted to rec.aviation.homebuilt
Larry
Default Plexiglas cement??
I am planning a "touchy" repair job to my canopy. I've done some test
sheet acrylic bondings with acrylic IPS Weld-On (#16). I don't like
the ugly bubbles and noticed some fine plexiglas stress cracking on
one test piece. Is there another sort of cement (eg. Weld-On #40)
which would make for a better looking bond between 2 sheets of .080 in
plexiglas? Thanks.
Larry
Old November 5th 07, 10:37 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
plexiglas? Thanks.
Larry
isnt chloroform a thin solvent suited to wicking into plexiglas
cracks?
Stealth Pilot
Old November 5th 07, 03:37 PM posted to rec.aviation.homebuilt
Larry
On Nov 5, 2:37?am, Stealth Pilot
plexiglas? Thanks.
Larry
cracks?
Stealth Pilot
Stealth: Yes it is but my repair patch is not a perfect match due to
curved surface so some air pockets would prevent complete wicking. I
thought maybe a thicker solvent could possibly work better. It is not
a structural requirement. Thanks
Larry
Old November 5th 07, 09:23 PM posted to rec.aviation.homebuilt
Craig[_2_]
plexiglas? Thanks.
Larry
cracks?
Stealth Pilot
Larry
Acrifix 192 is a good material for this. It is fairly viscous and can
be worked just like the plexi when it's cured. It is UV cured.
Most of the sailplane online stores will carry it (Knauff & Grove,
Wings & Wheels, Cumulus, etc.)
Craig
Old November 5th 07, 10:16 PM posted to rec.aviation.homebuilt
David Kazdan
Chloroform would probably work, but I think you mean methylene chloride.
David
plexiglas? Thanks.
Larry
cracks?
Stealth Pilot
Old November 9th 07, 12:36 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
David
no.
anaesthetic chloroform although it probably hasnt been used as an
aesthetic in years.
applied by dipping a fine point artist brush in the stuff and then
touched to the closed up crack, it wicks in , does its stuff and then
evaporates.
plexiglas? Thanks.
Larry
cracks?
Stealth Pilot
Old November 5th 07, 09:26 PM posted to rec.aviation.homebuilt
flybynightkarmarepair
plexiglas? Thanks.
Larry
#16 is just the water thin #3 with acrylic dust pre-dissolved in it to
make it thick, it's still the same action, I.E. softening the existing
acrylic, then evaporating away.
If you have gaps in particular, #40 is the shizz you want. It
actually is syntesizing new, full strength acrylic, and not just
softening up your substrate. Years ago, I built a planing boat towing
tank model out of acrylic sheet, and #40 worked far better than the
Methyl Chloride solvent cements, gaps and all. Once cured, it works
just like the base material, and polishes up nice. It can be a little
different tint, it's not quite as gin-clear.
Old November 8th 07, 04:09 PM posted to rec.aviation.homebuilt
Larry
plexiglas? Thanks.
Larry
Hello Above: Was talking with Ridout plastic techs yesterday. They
warned me about possible stress fracture when cementing plexiglas that
is not "cast cured". In other words plexiglas that is "extruded" has
stress in it and many solvents will cause hair line stress fractures
when applied. This makes me nervous about bonding a 7 inch plexiglass
ring to my canopy. .083 in thickness. Any ideas about cast vs.
extruded and potential problems?
Thanks
Larry
Old November 9th 07, 04:02 PM posted to rec.aviation.homebuilt
Wonder how silicone would do? They use it to make home aquariums. I
use it for holding lots of things - small sheet metal covers for wing
bolt holes, txpdr antenna metal base to my composite plane.......
Holds great. And it flexes slightly to help with differential heat
expansion (your cracking problem?). Just let it cure overnight.
plexiglas? Thanks.
Larry
Old November 9th 07, 05:32 PM posted to rec.aviation.homebuilt
Rich S.[_1_]
plexiglas? Thanks.
Larry
There is a very clear Silicone-like product which I used to install my
windshield. It is packaged in a caulking-gun tube. Someone here must know
it's name. I'll bet it would work well in this application.
Rich S.
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
molding plexiglas websites? [email protected] Home Built 13 February 6th 05 09:26 PM
OOPS! Got contact cement on the windshield Mike Rapoport Owning 12 November 13th 04 11:13 PM
Plexiglas/canopy adhesive Michael Pilla Home Built 3 May 3rd 04 05:09 PM
Plexiglas cleaner/ polish eddie Owning 9 August 1st 03 12:59 AM
