How is IFF working?
Old November 21st 03, 12:25 PM
Tobias Endrullis
Default How is IFF working?
Hi,
can anyone tell (explain) me how IFF mode 4 is working? Or does anyone know a page in the web where I can find information about
that?
Tobias
Old November 21st 03, 03:52 PM
GLOSM
Americans need not answer
Old November 21st 03, 10:34 PM
Tobias Endrullis
"GLOSM" schrieb im Newsbeitrag ...
yep, but I would like to know!!!!
Old November 22nd 03, 01:41 AM
Brian
"Tobias Endrullis" wrote in message
It uses a ROT-13 encoded flux capacitor to generate very high powered
microwave pulses that can only be decoded with another matched flux
capacitor. Use the wrong flux capacitor and you get nothing.
Old November 22nd 03, 02:06 AM
Gene Storey
There really isn't much data published on the IFF algorithm,
because it is mostly confidential, and not released to the public.
Basically the system is a challenge/response system. You challenge
the target with an encrypted word. This word is decoded if you have
the right code of the day. The word is changed every challenge, so
in effect, you may get a stream of 100 words, and you have to
decode about 95% of them in your 100 replies, or you will not be
upgraded to friend.
The word tells you to do something with the reply pulses.
Since IFF is in the L-Band, it is pretty much line-of-sight, and most
operators will select a single target on their scope, and the IFF will
operate over just that azimuth.
German IFF (NATO) is the same as all other IFF systems in the west.
The newer Soviet IFF system operates pretty much the same as NATO
and is also L-Band.
Hi,
that?
Old November 22nd 03, 02:27 AM
Larry
Ah yes Comradski. You vont to know this Information Friend or Foe, more
commonly known as IFF, yes?
Dis system relies on a "daily key" or "Code of the day" and if I told you
more, I'd have to . .
Larry
AECS (AW/SW/MTS)
Disabled Combat Veteran
USN Retired
20 years of Navy in my rear view mirror
and getting further away every day ;-)
Hi,
that?
Tobias
Working Stainless Steel Bob Babcock Home Built 7 February 14th 04 04:12 PM
Air Force Museum Working Group to release final report Otis Willie Military Aviation 0 November 18th 03 12:28 AM
Air Force Battlelabs working to keep service ahead of the curve Otis Willie Military Aviation 0 July 31st 03 09:37 PM
Looking for ATC working in LAX/ORD/NYC Tracon Marc Instrument Flight Rules 0 July 11th 03 01:30 PM
