Full motion home flight simulator.
Old November 23rd 03, 12:23 PM
The Enlightenment
Default Full motion home flight simulator.
While I was researching pneumatic positioning systems I came across
this web site which may be of interest to rec.aviation.military. It
looks like a German Kid who's putting together a full motion flight
simulator as a cooperative 'open source project' that is affordable
for a home user.
http://www.cadsoft.de/people/kls/fltsim/index.htm
This is some background on the technology :
6.5 bar (100psi) air has a great tradition for use in Industry because
of its cheapness, clean nature and power. Several years ago the FESTO
company brought out pneumatic positioning systems using a 5/3 way
analog servo valve. With modern control electronics pneumatic servo
systems can now position with full force against a disturbance to
within an amazing 0.02mm. The analog servo valves cost about US$500
however by using normal 5/3 way solenoid valves and pulsing them (PWM
pulse width modulation) almost the same accuracy (0.2mm) can be
achieved for US$50.00
I predict incidentally that compressed air servo systems will replace
hydraulics in many aircraft. Safety, economy and ease of service will
promote that.
Old November 23rd 03, 04:31 PM
NoHoverStop
for a home user.
promote that.
100psi pneumatics do not compare favourably with 1500psi (some sims I've
dealt with) or 3000psi (aircraft) hydraulics in performance terms. He's
just not going to get the dynamics he needs because of the low supply
pressure and the compressibility of his chosen working fluid. However
he's still got to invest in pumps, precision-valves and plumbing and the
maintenance thereof. He'd be better off looking at electric drives, of
the kind that are already busy replacing hydraulics in affordable sims.
Oh and he's going to have "hours of fun" trying to integrate a cheap
head-tracked display system also. Top marks for enthusiasm and effort
though.
Old November 23rd 03, 11:03 PM
The Enlightenment
"NoHoverStop" wrote in message
across
It
flight
affordable
for a home user.
because
FESTO
servo
US$500
(PWM
replace
will
promote that.
I've
He's
supply
Modern control theory and digital contollers mean that pneumatics can
position accuately to within 0.02mm. Compressibility and cylinder
stiction is not longer an problem: the control system compensates.
These things are quite uncanny to experience. You can bash them with
your thumb or even a hammer and they do not budge even for small
cylinders.
However
Analog 5/3 servo valves are about US500 (though I've seen an Italian
brand for about $300) as I pointed out however a solenoid coil on/off
valve can do almost as good job by pulse modulating on and off and can
be brough for $30.00/pair. (You would need 6)
As far as the compressor goes; they can be brought for $100 at a local
hardware (made in china). The nylon tiubing is negligable in price.
sims.
I immagine 'affordable' refers to those texan oil millionaiers in that
case. Electric positioning systems are not cheap either from my
experience.
effort
though.
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
