The ADF in our Cessna 172 isn't working right. Yes, we can receive the
audio but the indicator only swings through 180 degrees on the indicator (from 180 to 360) and doesn't point in the direction of the transmitter. We tried repalcing the indicator with no improvement. Can someone ewnlighten us as to other remedies? Simple antenna checks? Clues? All in all, it's not worth spending a pile of money on an ADF. Of course, we can still get the football and baseball games on the radio, so it's at least worth something. Plus it fills a spot on the stack. Thanks Al 1964 Skyhawk Spokane |
On Nov 23, 3:50 pm, Al wrote:
The ADF in our Cessna 172 isn't working right. Yes, we can receive the audio but the indicator only swings through 180 degrees on the indicator (from 180 to 360) and doesn't point in the direction of the transmitter. We tried repalcing the indicator with no improvement. Can someone ewnlighten us as to other remedies? Simple antenna checks? Clues? All in all, it's not worth spending a pile of money on an ADF. Of course, we can still get the football and baseball games on the radio, so it's at least worth something. Plus it fills a spot on the stack. Thanks Al 1964 Skyhawk Spokane Next time you fly, switch off the ALT half of the Master Switch. If the needle then points to the station, your alternator filter has fallen off or failed. |
Check the antenna connectors. My Archer had a loop antenna mounted on the
belly and a sense antenna mounted from cabin top to the vertical stabilizer. When I unscrewed and removed the loop antenna I found quite a bit of contact corrosion. The female side of the plug was a mini tube socket that I was able to buy at a local electronics store. I eventually pulled out the ADF and installed an Air Gizmo panel mount for my 496. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel |
On Nov 23, 4:27 pm, "Mike Noel" wrote:
Check the antenna connectors. My Archer had a loop antenna mounted on the You didn't say what kind it was, but as the other poster said it relates to the antenna. There are a pair of coils at right angles. You symptom suggests that the fore aft one is OK but the other one is dead either for connection reasons or some other failure. You could check it with an ohmmeter. Bill Hale belly and a sense antenna mounted from cabin top to the vertical stabilizer. When I unscrewed and removed the loop antenna I found quite a bit of contact corrosion. The female side of the plug was a mini tube socket that I was able to buy at a local electronics store. I eventually pulled out the ADF and installed an Air Gizmo panel mount for my 496. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel |
On Fri, 23 Nov 2007 16:27:42 -0700, "Mike Noel"
wrote: I eventually pulled out the ADF and installed an Air Gizmo panel mount for my 496. Funny you should mention that... Our plane had the ADF removed in the mid-90's by it's previous owners, because the never needed it. We have dual VOR's, DME, and a handheld GPS similar to yours. The airport I fly to most often with my wife has "ADF Required" on the ILS. ;^( |
302 Problem | Hal | Soaring | 11 | August 17th 04 06:27 PM |
ADF Problem | tony roberts | Owning | 13 | May 12th 04 02:59 AM |
Problem with this NG? | Regnirps | Military Aviation | 10 | April 29th 04 03:39 PM |
ILS problem | Bernie Samms | Simulators | 2 | September 17th 03 01:36 AM |
EGT Problem | Dennis O'Connor | Owning | 4 | August 27th 03 04:25 PM |
