I'm trying to figure out what's an appropriate value adjustment to an
engine that has an upcoming tbo on the camshaft. Engine: IO360 C1C Lycoming Engine was torn down in 2002 (prop strike inspection), new lifters, new valves, chrome cylinders honed, new rings, about 400 hours ago. Camshaft at that time was pristine. Time SMOH is about 1200. Compressions are all in 70s. What kind of value adjustment would be reasonable compared with an identical engine with a 2000 hr camshaft tbo? Is there any way without disassembling the engine to determine the current condition of the camshaft? |
On Nov 26, 3:58 pm, Paul kgyy wrote:
I'm trying to figure out what's an appropriate value adjustment to an engine that has an upcoming tbo on the camshaft. Engine: IO360 C1C Lycoming Engine was torn down in 2002 (prop strike inspection), new lifters, new valves, chrome cylinders honed, new rings, about 400 hours ago. Camshaft at that time was pristine. Time SMOH is about 1200. Compressions are all in 70s. What kind of value adjustment would be reasonable compared with an identical engine with a 2000 hr camshaft tbo? Is there any way without disassembling the engine to determine the current condition of the camshaft? There is no TBO on a camshaft. You can visually inspect the camshaft by removing cylinders. What do you mean by a "valve adjustment?" The only valve adjustment I know of is replacing the pushrods with oversized if there is too much dry lash. |
only valve adjustment I know of is replacing the pushrods with oversized if there is too much dry lash. It's VALUE adjustment - how much would of a discount would you expect on purchase given the conditions stated? |
![]() It's VALUE adjustment - how much would of a discount would you expect on purchase given the conditions stated? The engine value is exactly the same as any other 1200 hour engine . denny |
PZL vario zero adjustment. | [email protected] | Soaring | 1 | September 29th 07 03:38 AM |
KI-209 VOR/LOC/GS Indicator adjustment | kontiki | Owning | 13 | April 25th 05 11:35 PM |
Brake adjustment on the 2-33 | GM | Soaring | 11 | April 19th 05 07:05 PM |
Adjustment of Altimeter | Ron | Home Built | 5 | April 5th 04 03:12 AM |
