value adjustment for short tbo on cam
Old November 26th 07, 09:58 PM posted to rec.aviation.piloting, rec.aviation.owning
Paul kgyy
Default value adjustment for short tbo on cam
I'm trying to figure out what's an appropriate value adjustment to an
engine that has an upcoming tbo on the camshaft.
Engine: IO360 C1C Lycoming
Engine was torn down in 2002 (prop strike inspection), new lifters,
new valves, chrome cylinders honed, new rings, about 400 hours ago.
Camshaft at that time was pristine. Time SMOH is about 1200.
Compressions are all in 70s.
What kind of value adjustment would be reasonable compared with an
identical engine with a 2000 hr camshaft tbo?
Is there any way without disassembling the engine to determine the
current condition of the camshaft?
Old November 27th 07, 01:03 AM posted to rec.aviation.piloting, rec.aviation.owning
150flivver
There is no TBO on a camshaft. You can visually inspect the camshaft
by removing cylinders. What do you mean by a "valve adjustment?" The
only valve adjustment I know of is replacing the pushrods with
oversized if there is too much dry lash.
Old November 27th 07, 04:23 AM posted to rec.aviation.piloting, rec.aviation.owning
Paul kgyy
It's VALUE adjustment - how much would of a discount would you expect
on purchase given the conditions stated?
Old November 27th 07, 12:29 PM posted to rec.aviation.piloting, rec.aviation.owning
Denny
The engine value is exactly the same as any other 1200 hour engine .
denny
value adjustment for short tbo on cam Paul kgyy Piloting 3 November 27th 07 12:29 PM
KI-209 VOR/LOC/GS Indicator adjustment kontiki Owning 13 April 25th 05 11:35 PM
Brake adjustment on the 2-33 GM Soaring 11 April 19th 05 07:05 PM
Adjustment of Altimeter Ron Home Built 5 April 5th 04 03:12 AM
