tricycle undercarriage
Old November 26th 03, 02:58 PM
G. Stewart
Default tricycle undercarriage
From late WW2 onwards, many aircraft designs started using the
tricycle undercarriage scheme. Prior to this, most used the other one
(you know, two large wheels up in front, with the plane tilted back
onto a small support wheel).
Why the change? Well, good visibility (while taxing/take-off/etc.)
would seem to be a huge advantage of the tricycle undercarraige ... so
I suppose the question really should be - why did most aircraft NOT
use the tricycle undercarriage design until late WW2?
Old November 26th 03, 03:03 PM
QDurham
Weight, drag, expense. Of course the Wright Flyer had tricycle gear.
Quent
Old November 26th 03, 03:12 PM
Steven P. McNicoll
"QDurham" wrote in message
The Wright Flyer had skids.
Old November 26th 03, 04:53 PM
QDurham
I stand corrected. But I think the first wheeled Wright plane was tricycle.
Q
Old November 27th 03, 04:13 AM
Steven P. McNicoll
tricycle.
I believe you're thinking of a Curtiss machine. The first Wright airplane
with wheels was the Model B of 1910. It still had skids, but added two
bicycle-type wheels on each skid near the center of gravity. You can see an
image of one he
http://www.fi.edu/press/aviation/BFlyer_front_view.jpg
Steven P. McNicoll
"G. Stewart" wrote in message
m...
The tricycle gear has more drag and weight, but the primary reason was
generally poor runways prior to 1950 or so.
Old November 26th 03, 04:40 PM
Tex Houston
m...
Are you referring to those 'late' designs such as
Bell P-39, Production 1939
Douglas A-20, Production 1939
Douglas C-54, Production 1942
Martin B-26, Production 1940
North American B-25, Production 1940
Consolidated PBY-5, Production 1939
Consolidated B-24, Production 1941
ERCO Ercoupe, Production 1937
Fairchild AT-13, AT-14, At-21 Production ??? but early
I really do not think they were as rare as you say and I only included USA
aircraft.
Regards,
Tex Houston
Old November 26th 03, 06:48 PM
WDA
Tail draggers are prone to ground loop whereas the trike configuration makes
for less destructive landings by tyro pilots.
WDA
end
m...
Old November 26th 03, 08:43 PM
killfile
Early landing gear was heavy, because materials technology dictated that it
had to be big, and thick to solid. In addition to this it was, of course,
another thing to fail. One of the other big, big factors was that the nose
gear needs to go into the nose - which on on piston engined fighters, was
usally full of ... engine. (Bar the P-39, which was rear-engined.)
One of the best illustrations of why the switch was made was the Me-262,
which originally had a tail-dragger configuration. On the initial test
flight, they found that the jet wash headed straight for the tailplanes and
pinned the aircraft to the ground - to get it airbourne, the pilot had to
take the horrendously dangerous manouver of tapping the brakes to bring up
the tail.
Matt
Old November 27th 03, 10:58 AM
Pat Carpenter
Tail draggers help when you have a very large diameter prop circle
i.e. stops the prop hitting the runway. Of course not a problem with
multi-engine or jet propulsion.
Mustang
Spitfire
Hurricane
Tempest
Typhoon
to name a few.
On Wed, 26 Nov 2003 20:43:34 -0000, "killfile"
the tail.
Matt
Tricycle Midget Thought Dick Home Built 4 March 26th 04 11:12 PM
