A BFR question
Old January 22nd 08, 07:00 PM posted to rec.aviation.piloting
Dallas
Default A BFR question
Being a new pilot I don't know much about the BFR process.
Over Xmas I was chatting with my pilot Brother-in-law about my new status
as a pilot when he stated that he thought he could just go to the local FBO
and rent an aircraft himself. I said yes and reminded him that he'd also
need a medical and a BFR.
He's a retired Air Force F-15 pilot with an FAA commercial ticket,
multiengine and instrument rating. Impressive stuff, but the last time he
flew was in 1983. While looking over a chart he had no idea what Bravo
airspace was.
It's pretty clear that his knowledge base is obsolete and he's not ready to
fly in today's sky. My question is, could he pass through the BFR process
in a couple of hours or would the instructor make him go back and hit the
books for a few weeks.
I'd hate to think the system would let him back up in the sky in his
current state.
Dallas
Old January 22nd 08, 07:07 PM posted to rec.aviation.piloting
Robert M. Gary
and rent an aircraft himself. * I said yes and reminded him that he'd also
multiengine and instrument rating. *Impressive stuff, but the last time he
flew was in 1983. *While looking over a chart he had no idea what Bravo
airspace was.
fly in today's sky. *My question is, could he pass through the BFR process
current state.
King makes a good DVD for just this situation. Its designed to help
pilots who have been out of the cockpit through the process. That is
what I recommend to students. Sure, they can pay me to teach it to
them but its usually more cost affective for them to get the DVDs
first so we can streamline what we talk about.
As to your question; I have no idea what any particular CFI may
require when performing a BFR.
-Robert, CFII
Old January 22nd 08, 07:20 PM posted to rec.aviation.piloting
Jim Burns[_2_]
http://www.aopa.org/members/files/gu...rview.html#80s
"If you have been out of flying since the '80s." may be helpful.
Old January 22nd 08, 07:28 PM posted to rec.aviation.piloting
kontiki
current state.
Its clear he's a little behind the curve. It is up to the CFI who
does his BFR whether or not he is sufficiently proficient and
competent.
There are two parts to the BFR... ground and flight. The ground
portion reviews current FARs, airspace and flight planning issues.
If the CFI determines the pilot is not proficient with ground portion
does not preclude him from continuing on to the flight portion of the
review. He should not however, sign off the BFR if he feels the pilot
is deficient in the airspace knowledge you mention.
It would simply be a matter of scheduling additional time with the CFI
in training and/or review to the point where he would be comfortable
signing the man off for the BFR.
Old January 22nd 08, 10:49 PM posted to rec.aviation.piloting
Blueskies
"kontiki" wrote in message ...
current state.
competent.
Took me two hours with a CFI, one on the ground talkin and one in the sky flyin, to get the bfr endorsement...after a 24
year and three month 'break'.
I did get a current copy of the AIM, some charts, and etc so I could distinguish the difference between Bravo and a TCA,
a control zone and Delta, etc.
That was three years ago...whatta blast flying again.
Old January 23rd 08, 01:51 AM posted to rec.aviation.piloting
150flivver
airspace was.
current state.
Dallas
If all he flew has been in the Air Force, he may have to get SEL added
to his ticket before he can go renting a single engine. He may be
limited to centerline thrust on multis also.
Old January 23rd 08, 02:08 AM posted to rec.aviation.piloting
Robert M. Gary
airspace was.
current state.
Dallas
to his ticket before he can go renting a single engine. *He may be
limited to centerline thrust on multis also.- Hide quoted text -
- Show quoted text -
That would be interesting. To have a ME limited to centerline thrust
but no single engine rating. Almost seems like an oxymoron.
-Robert
Old January 23rd 08, 03:16 AM posted to rec.aviation.piloting
BT
-Robert
It's true.. and it happens.. AF Trained pilots, T-37, T-38, F-15 are Multi
Engine, Centerline Thrust.
They take a written, and based on military check ride (Form 8) are able to
be issued a Commercial, Instrument, Multi Engine and never know anything
about Props or P-factor or engines other than jets.
No SE.
You want to have real fun.. teach those jet jockeys how to fly gliders,
providing they had not gone through the glider course at the academy.
BT
Old January 23rd 08, 05:00 AM posted to rec.aviation.piloting
Dallas
BT, I was under the impression that a military pilot didn't need an FAA
certificate to fly in the military. Was this an incorrect assumption?
Dallas
Old January 23rd 08, 05:26 AM posted to rec.aviation.piloting
BT
"Dallas" wrote in message
to
Dallas
Dallas, you are correct, no FAA Certificate, but does have to have a valid
military check ride that is recorded on AF Form 8. The military issues the
military pilot his qualifications. No "certificate", just papers in a folder
maintained in "Flight Records".
The military pilot can take that current AF Form 8 to the nearest FSDO and
be issued a Civilian Pilot Certificate. If he is flying aircraft with more
than one engine, he gets a ME rating, if it is "fighters", certain types are
considered centerline thrust. If he is flying a tanker or transport, he can
have the centerline thrust removed. Also, as part of the Form 8 papers are
annotations of instrument checkride, so he gets the Instrument rating.
That does not qualify him to fly, Airplane Single Engine, unless his
military Form 8 is for a single engine aircraft.
BT
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
