Wood Laminations and Springback
Old January 24th 08, 12:31 AM posted to rec.aviation.homebuilt
Kyle Boatright
Default Wood Laminations and Springback
I'm working on the center section for a Hatz. The trailing edge of the
center section is a recurved lamination that provides better access to the
front cockpit.
I've steamed and clamped the strips into a form, and they have taken on some
of the curve, but when I unclamp 'em after they dry, I get significant
springback. The question is whether I need to allow for this in the
finished lamination, or whether the springback will go away when I glue up
the assembly?
FYI, the lamination starts as four 3" x 1/4" strips.
Thanks in advance,
Kyle Boatright
Old January 24th 08, 12:53 AM posted to rec.aviation.homebuilt
Doug Palmer
Most of the laminations I have done will within reason, retain the
shape they are set to when glued together. I have done laminations
where as the individual plies are NOT steam bent, and then glued in an
arc around a form. Once the glue dries the lamination holds the shape
of the form with zero or very little spring back. I would imagine you
could get some spring back if the lamination is highly stressed, that
is you are bending the hell out of the wood.
Good luck
Doug
Old January 24th 08, 02:12 AM posted to rec.aviation.homebuilt
Morgans[_2_]
What he said.
If the parts have more that around a 9" radius to the bend, you will
probably get about 1/4" spring back. If the radius is significantly larger,
there will be less, possibly a lot less spring back.
I would imagine that the part will be anchored to other stuff to help it
maintain it's shape, right? If that is the case, you probably don't need to
take any special efforts into account.
Ain't wood wonderful? It has life, and personality. It talks to me.
I like it a whole lot better than rocks that have been heated to thousands
of degrees, and melted into shapes. It has no life; it has had all of its
personality scorched out of it. JMHO. :-)
Jim in NC
Old January 24th 08, 01:12 AM posted to rec.aviation.homebuilt
Kyle Boatright
"Kyle Boatright" wrote in message
Snip
Thanks in advance,
Kyle Boatright
One correction and a bit more information, the strips are 1/8" thick and the
wood is Spruce.
Thanks again,
Kyle
Old January 24th 08, 01:00 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Wed, 23 Jan 2008 19:31:29 -0500, "Kyle Boatright"
front cockpit.
the assembly?
Thanks in advance,
Kyle Boatright
Kyle
wood is cellulose which is actually massive sugar molecules joined end
to end. joining all the cellulose together are a family of molecules
known as lignins. some lignins are thermo plastic and some are
thermosetting.
when you select wood for steaming and laminating you need to select a
timber with thermo softening lignins or you'll never get it to go soft
enough for forming.
when you've steamed a wood and placed it hot on the former then
clamped it in place until cold the wood should come off the former
with no springback. ...if it is a thermosoftening lignin.
I'd say that you've picked the wrong timber for laminating.
Stealth Pilot
Old January 25th 08, 02:47 AM posted to rec.aviation.homebuilt
Bertie the Bunyip[_22_]
Stealth Pilot wrote in
the center section is a recurved lamination that provides better
access to the front cockpit.
on some of the curve, but when I unclamp 'em after they dry, I get
significant springback. The question is whether I need to allow for
this in the finished lamination, or whether the springback will go
away when I glue up the assembly?
Thanks in advance,
Kyle Boatright
Kyle
thermosetting.
enough for forming.
Spruce is what's specified in the plans. I used it and they came out of
the jig with no springback whatsoever.
Bertie
Old January 25th 08, 12:28 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Fri, 25 Jan 2008 02:47:56 +0000 (UTC), Bertie the Bunyip
Thanks in advance,
Kyle Boatright
Kyle
thermosetting.
enough for forming.
Bertie
kyle steam it some more you use it. it should be too hot to handle
and pretty floppy. use leather gardening gloves.
as a guide to how small a curve can be I laminated up a bow when a
friend complained like you have.
the bow was 6" wide by 7" tall and was like a capital U.
the tighter the curve the thinner the lamination.
when wood is correctly glued is has the equivalent strength of solid
wood so dont be afraid of lots of thin laminations.
my smartarse piece has 9 laminations for 3/4" thickness of
laminations.
bandsaw thinner laminations and add another lamination or two to make
up for the kerfs.
Stealth Pilot
Wood Laminations and Springback Kyle Boatright Piloting 3 January 24th 08 04:33 AM
Flying on the Cheap - Wood [email protected] Home Built 66 August 18th 06 05:33 AM
wood species question Stewart Glenn Home Built 78 August 11th 05 06:42 AM
Wood glider plans? Scott Soaring 4 January 18th 04 05:04 PM
Using Balsa wood Lou Parker Home Built 10 December 8th 03 05:08 PM
