I have a sticky main strut in my Pa-28-151. My engineer has suggested
changing the o-rings and valves of both struts. I was curious about the whole structure and have looked everywhere in the internet with no luck Any suggestions where I could find them? Gus |
Apologies, I ";looked everywhere in the internet for diagrams, with no luck"
Gus "Gus Cabre" wrote in message ... I have a sticky main strut in my Pa-28-151. My engineer has suggested changing the o-rings and valves of both struts. I was curious about the whole structure and have looked everywhere in the internet with no luck Any suggestions where I could find them? Gus |
On Feb 10, 12:13 pm, "Gus Cabre" wrote:
Apologies, I ";looked everywhere in the internet for diagrams, with no luck" Gus"Gus Cabre" wrote in message ... I have a sticky main strut in my Pa-28-151. My engineer has suggested changing the o-rings and valves of both struts. I was curious about the whole structure and have looked everywhere in the internet with no luck Any suggestions where I could find them? Gus Gus: I have an exploded diagram of the mains in my warrior parts catalog if that is what you are looking for. If you don't turn one up send me your email and I'll zap a scanned copy to you. Leo |
Where do you live? If it's in a cold weather climate, having sticky main gear struts on a Cherokee is NORMAL at this time of year. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I have a sticky main strut in my Pa-28-151. Where do you live? If it's in a cold weather climate, having sticky main gear struts on a Cherokee is NORMAL at this time of year. They stick a lot less if you fly it frequently (at least once a week), and keep the struts free of dirt. if you do have it rebuilt, have the A&P check to make sure the strut bushing isn't worn so that the strut gets cocked slightly, jamming it position. If it is, the only solution is to replace the strut bushings that the strut rides in. |
Cherokee is NORMAL at this time of year. They stick a lot less if you fly it frequently (at least once a week), and keep the struts free of dirt. if you do have it rebuilt, have the A&P check to make sure the strut bushing isn't worn so that the strut gets cocked slightly, jamming it position. If it is, the only solution is to replace the strut bushings that the strut rides in. The last few flights, with the temperature near zero, our left strut stuck up after landing, only compressing back down when we made the right turn onto the taxiway, forcing it down with some centrifugal force. At these temperatures NOTHING moves easily. The yoke moves hard, the flaps don't retract, the knobs on the radios turn stiffly... You should hear the noises coming out of my truck. Hard to believe last Valentine's Day we had to scrub some of our "romantic sunset flights" because it was *raining* all the time. This year, liquid water is only possible indoors... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2008-02-12, Jay Honeck wrote:
At these temperatures NOTHING moves easily. The yoke moves hard, the flaps don't retract, the knobs on the radios turn stiffly... You should hear the noises coming out of my truck. The first time I took my shiny new Lexus out in subzero weather, I thought something was broke. It *never* made that kind of noise before. I'm already planning on how to seal up the air leaks in whatever I wind up buying so the cabin heat has a chance to keep up. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net http://www.hercules-390.org (Yes, that's me!) Buy Hercules stuff at http://www.cafepress.com/hercules-390 |
I routinely put both forearms under the center of each wing tip and lift to
unstick the main struts before each flight. I also do a little bounce on the step to pull up the nose strut before boarding. It just seems to be a normal part of owning a Cherokee. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Jay Honeck" wrote in message news:NV6sj.29495$9j6.24433@attbi_s22... If it's in a cold weather climate, having sticky main gear struts on a Cherokee is NORMAL at this time of year. They stick a lot less if you fly it frequently (at least once a week), and keep the struts free of dirt. if you do have it rebuilt, have the A&P check to make sure the strut bushing isn't worn so that the strut gets cocked slightly, jamming it position. If it is, the only solution is to replace the strut bushings that the strut rides in. The last few flights, with the temperature near zero, our left strut stuck up after landing, only compressing back down when we made the right turn onto the taxiway, forcing it down with some centrifugal force. At these temperatures NOTHING moves easily. The yoke moves hard, the flaps don't retract, the knobs on the radios turn stiffly... You should hear the noises coming out of my truck. Hard to believe last Valentine's Day we had to scrub some of our "romantic sunset flights" because it was *raining* all the time. This year, liquid water is only possible indoors... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Gus Cabre wrote:
I have a sticky main strut in my Pa-28-151. My engineer has suggested changing the o-rings and valves of both struts. I was curious about the whole structure and have looked everywhere in the internet with no luck Any suggestions where I could find them? Gus As others have said, these things sticking is fairly normal. You generally don't rebuild them until they start to leak. Since they already leak somewhat, you just wait until the amount becomes a bit messy and/or servicing them with air (or nitrogen as some prefer) gets to be a chore. I was surprised to find they stuck about the same after rebuilding all of them as they did before. If one is really sticking way more than the other you might be tempted to change them both. But their "stickiness" will vary quite a bit from strut to strut depending on the temperature and how much bouncing around the bird gets when parked on the ramp for weeks at a time. You may want to invest in a service manual and parts manual. Both are now available on CD-ROM. It helps to have these to review before (or after) you discuss matters with you mechanic. Just remember that the mechanic has the benefit of actually DOING these operations, often many times. They can tell you when the chapter and verse in the book ain't quite how it REALLY happens. Good Luck, Mike |
You could try brushing some STP on the outside of the exposed strut.
It is amazing how a tiny amount of STP will reduce elastomeric seal friction for many cycles, but it will probably have to be replaced (rebrushed) every few weeks. From my experience in hydraulics, it would cut friction easily in half for many cycles. |
| Thread Tools | |
| Display Modes | |
| Oleo Struts | xerxes | Owning | 4 | September 7th 06 05:54 AM |
| Cessna Struts | jls | Home Built | 7 | July 16th 05 04:26 PM |
| Gas Struts for Clamshell Trailer | [email protected] | Soaring | 1 | April 26th 05 03:49 AM |
| 172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 07:28 PM |
| Regulator/valve for filling struts | Ben Jackson | Owning | 5 | January 24th 04 04:12 AM |
