I am trying to find any regulations about Oxygen use, type of masks and/or
delivery allowed versus altitude, frequency of inspection of various parts of the O2 system. I've spent several hours searching on the FAA website with no luck beyond 91.211. Any help would be appreciated. Also I need help in locating someone to service A-14 regulators. Thanks, John Scott |
Go here
http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl and search for "oxygen" in Title 14. Part 23 has a number of citations for supplemental oxygen flow rates and stuff like that. Google "aviation oxygen". There a number of sites that only deal with aviation O2 systems. One or more of them should be able to service your regulator. |
See FAR 91.211
and http://www.dr-amy.com/rich/oxygen/ Tom Idaho On Feb 19, 2:20 pm, "John Scott" wrote: I am trying to find any regulations about Oxygen use, type of masks and/or delivery allowed versus altitude, frequency of inspection of various parts of the O2 system. I've spent several hours searching on the FAA website with no luck beyond 91.211. Any help would be appreciated. Also I need help in locating someone to service A-14 regulators. Thanks, John Scott |
On Feb 19, 2:20*pm, "John Scott" wrote:
I am trying to find any regulations about Oxygen use, type of masks and/or delivery allowed versus altitude, You don't say anything about your intended use. Unless you plan to go above 18,000ft I suggest you forget the A14 and use a modern canula system. I've had good experience both with oxymizer type canulas and with pulse delivery systems. Inspect whatever system you have before any flight you expect to use it. The most important check is to ensure the bottle valve is turned on unless it can be reached in flight. If you really want a mask I have an usused Sierra mask with built in mic I could sell you. Like I said, I use a canula. I've been high, got cold, and don't need to do it again. Andy |
John,
Also see: http://www.c-f-c.com/supportdocs/abo4.htm Tom Idaho On Feb 19, 2:20 pm, "John Scott" wrote: I am trying to find any regulations about Oxygen use, type of masks and/or delivery allowed versus altitude, frequency of inspection of various parts of the O2 system. I've spent several hours searching on the FAA website with no luck beyond 91.211. Any help would be appreciated. Also I need help in locating someone to service A-14 regulators. Thanks, John Scott |
I am a fanatic about the A14 and A20 oxygen regulator....
You could service it at: http://www.fluidpowerohio.com/oxygen.html Best regards, Bruno |
The Mountain High website (www.mhoxygen.com) has lots of information
and links. You can probably find what you need via the site. They are extremely helpful too. If you call, I am sure they can answer any question you have as well as recommend somewhere to service the A-14 regulator. On Feb 19, 10:20*pm, "John Scott" wrote: I am trying to find any regulations about Oxygen use, type of masks and/or delivery allowed versus altitude, frequency of inspection of various parts of the O2 system. *I've spent several hours searching on the FAA website with no luck beyond 91.211. *Any help would be appreciated. Also I need help in locating someone to service A-14 regulators. Thanks, John Scott |
Thanks for the info. After posting the message I did find FAR 23 and
extracted the info there for airplanes. We have Mountain High Constant Flow systems installed in parallel with our A-14s. I have been in conversation with MH. I continue to have little luck in getting specific documents on servicing the A-14s. I have struck out on getting service on them. Several outfits that use to do it, no longer do it. I'm still waiting to hear from Fluid Power of Ohio. Bottom line is we can fly to 30,000' with our MH systems and appropriate masks. John Scott |
The 2 relevant sections of the FARs are 91.211 and 23.1447.
Section 91 is contained in the 2008 FAR/AIM book whereas you will have to Google section 23. I think the interesting point from section 23 is that above 18,000 feet you must use a mouth and nose mask even if you are using a cannular. I use the EDS system with a mask at very high altitudes although MH has done testing to show that their EDS system, if used correctly, will operate to 30,000 feet. However I caution any of you who may be tempted to explore the wave above 18,000 feet to attend a FAA decompression chamber session to determine your response to high altitudes. I have now done it twice and it is a real eye opener to see how some people react to being decompressed to 25,000 feet. Scary! Section 91.211a begins " No person may operate a civil aircraft of US registry-". This implies that, under Part 103 which relates to "ultralight vehicles", oxygen is not a legal requirement for an ultralight. Crazy for 2008 although perhaps reasonable for when the regs were composed many years ago. Technology changes things so rapidly that it is hard to anticipate all the future requirements. I have flown paragliders to 16,000 feet without oxygen when I was younger - perfectly legal and if I had lost consciousness the pitch stable paraglider would have probably got me down to an altitude where I would have woken up! I don't do that any more but I know many that do. I have already contacted the FAA and suggested that they think through the use of oxygen for ultralights and maybe one day they may get to it. Hypoxia really exists. Dave |
wrote in message ... The 2 relevant sections of the FARs are 91.211 and 23.1447. Section 91 is contained in the 2008 FAR/AIM book whereas you will have to Google section 23. However I caution any of you who may be tempted to explore the wave above 18,000 feet to attend a FAA decompression chamber session to determine your response to high altitudes. I have now done it twice and it is a real eye opener to see how some people react to being decompressed to 25,000 feet. Scary! Hypoxia really exists. Dave I'll second that and raise the ante. In the chamber you will find that you are the last to realize that you are impaired. Unlike a couple of Margaritas, you don't feel a thing, and don't have a clue. A finger pulse oximeter is a great aid. Your ability to absorb the oxygen can change, and the system calibration is pretty coarse. At 15,000 ft this is not so critical, but if you intend to push the limit, you could go over before you expect it. The meter is the best check on the function of the whole system. Hartley Falbaum "KF" USA |
Fabric Covering II | [email protected] | Home Built | 1 | February 18th 08 11:49 PM |
covering | Eliot | Soaring | 5 | September 2nd 07 06:13 PM |
Fabric covering | Chris Wells | Home Built | 6 | January 17th 07 07:36 PM |
Trailer covering | mat Redsell | Home Built | 3 | December 3rd 05 03:11 AM |
Questions on covering | Ed | Restoration | 4 | March 16th 04 06:18 PM |
