Is taking off on single mag bad for engine
Old September 16th 03, 08:42 PM
flyer
Default Is taking off on single mag bad for engine
I inadvertently did not return the ignition switch to "BOTH" after a
preflght mag check cause: distraction, I was an idiot) the other day
departing in my Glasair with my partner. The engine is a 150hp
O-320-E2D. The engine only developed 1900 rpm (2200 is normal for us
on 2 mags with fixed pitch prop) and climbed poorly and ran rough.
After figuring it out in approximately 1 minute, I switch back to
"BOTH" and everything was fine. That was a few months ago. Our
recent annual showed some low compression in #3 (55) and the others
were in the mid 60s, down a few points from last year. Not what I
would like but the engine runs strong. My partner said that the
single mag takeoff could have caused "detonation" or "cylinder
glazing" or "a bad flame front in the cylinders" and ruined the
compression.
I don't think that at that low power setting in a 7:1 compression
engine anything bad could happen. I am not aware of anything bad that
could happen in general from single mag operation at any power
setting, other than rough performance. This would be the same thing
as having a fouled plug in a cylinder, and nothing bad happens then.
Does anyone have any other feelings about this phenomenon.
Old September 16th 03, 08:53 PM
Ron Natalie
"flyer" wrote in message om...
My partner said that the single mag takeoff could have caused "detonation"
No. I can't see how it would. Detonation is caused by increased cyl. pressures
and preignition comes from screwing up the timing (or other factors). None of this
I can see how one mag would this effect.
or "cylinder glazing"
Doubtful. Glazing is usually an effect of colder than standard operating temperaturs.
Well, this is why you get worse performance on one mag. Since there are two plugs
neither one is optimally situated, so running on one is a degredation. But...
and ruined the compression.
I don't think so.
I agree with your assesment.
Old September 16th 03, 09:28 PM
flyer wrote:
: O-320-E2D. The engine only developed 1900 rpm (2200 is normal for us
: on 2 mags with fixed pitch prop) and climbed poorly and ran rough.
Sounds about right, but...
: would like but the engine runs strong. My partner said that the
: single mag takeoff could have caused "detonation" or "cylinder
: glazing" or "a bad flame front in the cylinders" and ruined the
: compression.
Running at only 1900 RPM instead of the normal 2200 RPM on
climbout means that there's more absolute time from the spark (at 25
degrees BTDC) until TDC. For that matter, there's more time from the
beginning of the compression stroke to the spark. That extra time could
cause either preignition or detonation. Not likely, but possible
: I don't think that at that low power setting in a 7:1 compression
: engine anything bad could happen.
7:1 is pretty low compression, granted. BUT, it's rated for a
certain octane gasoline at certain min/max RPM settings.
: could happen in general from single mag operation at any power
: setting, other than rough performance.
Aside from roughness and the potential for lower-than-normal RPM,
I'd agree
: as having a fouled plug in a cylinder, and nothing bad happens then.
: Does anyone have any other feelings about this phenomenon.
... except that with one fouled plug, the other three jugs still
run on 2 plugs, so the RPM wouldn't decrease nearly as much.
Just for a bit more clarification... this on avgas (100LL), or cargas?
I'll give you one more data point that might be somewhat related. I've
noticed on my O-360 180 hp 8.5:1 Lycoming with the 91 octane cargas STC
that with a hot (recently flown) engine, it will actually diesel when I
cut the mags off. I was at idle, and rather than cut the mixture, I cut
the mags. It slowly shook to close to a stop, but at 100 rpm or so, it
continued to sputter and run enough to keep shaking and running. I was
very surprised at this, but when I started thinking about it, I realized
that at this (very) low RPM, there was lots of time to get the mixture
burning in the jugs, and also the idle throttle position allowed the MP to
build up to 20" or so (again very small airflow). It's almost like
lugging the engine at full throttle at 100 RPM... pretty tough.
But still... in your situation that 1900 instead of 2200
*shouldn't* have done it.... but it doesn't mean that it didn't. Try a
static RPM runup (and lean if DA is an issue). Make sure the tach is
calibrated, and the runup is within spec as per TCDS (Type certificate...
www.faa.gov)
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old September 17th 03, 09:25 PM
Peter Dohm
----------snip--------
-----------snip---------
I was present when one of the mechanics, who I respect a lot, told a friend at
FXE that mogas and avgas have significantly different viscosities; and that an
engine will run much richer on one than the other. Me recollection fails me,
but your account indicates that magas has the lower viscosity and will run
rich. A rich mixture at idle, and carbon deposits from rich operation, used to
be the classic causes of "dieseling" in cars--sometimes people had to kill the
engines with the clutch! :-(
My best recollection of the mechanic's advice was to only use mogas if you could
use it all of the time. It might be possible to eliminate the problem by
leaning under all permissible modes of operation; and I plan to explore that
avenue when I have a plane avaible and start flying again.
Peter
Old September 17th 03, 09:39 PM
Peter Dohm
compression.
I dunno. I am not a mechanic, and haven't flown in a long time. However, the
two most probable problems are that you could foul the plugs associated with the
inoperative magneto and that you would have the effect of a slightly retarded
spark--increased head temperature and egt and very slightly reduced power. The
real risk would be the lack of any automatic redundancy in the event the the
operating magneto shold fail. The short answer is that you probably didn't hurt
it any more on one mag than I did climbing out with the carb heat on after a
touch and go.
Try not to make my second, and much more dissastrous mistake as well: After
about the third time in two months that I forgot to turn off the carb heat on a
touch-and-go, I got the idea that about a two month break from flying would
enable me to forget the bad habbits which I had developed and resume the proper
and efficient use of my checklist. The dissastrous result was that two months
became three and three became six and ... and I currently hope to put flying
into next year's budget. What makes that bad decision so bad is that it
happened in 1983! :-(
Old September 19th 03, 07:39 PM
Phil Sisson, Litchfield Aerobatic Club
For what its worth, the lycoming 0-290-G only had one mag.
Old September 19th 03, 06:00 PM
Richard Lamb
That's all it needed for ground power duty...
The O-290 AIRCRAFT engine has two.
Richard Lamb
http://www.flash.net/~lamb01/
Old September 19th 03, 06:57 PM
Ron Natalie
"Richard Lamb" wrote in message ...
RIght, but it has no problems with detonation, cylinder glazing,
or other compression-reducing syndromes. The plug isn't even
moved to where you would put a single plug if you'd designed
that engine for only one plug. They just took the 2-plug O-290
cyls and blocked off one side.
Old September 21st 03, 09:43 PM
Brent Rehmel
Most of the discussion on here about possible problems and theoretical
possible problems is just a lot of arm waving.
Your engine is designed to fly with either mag. The reason you take off with
both mags is in unlikely event that one happened to fail you would still be
flying instead of looking for a soft place to crash. The engine will run
fine with either mag or both.
You say your engine was running a bit rough with one mag. I don't know how
new your mags are, but mags do wear. Most likely this only indicates that
the single mag that you were using is not working at peak performance. It's
older, a little worn, but not something you would notice when using both.
Since everything is in pairs, it could also be that the wires or plugs for
that mag are not quite as good; one worn plug or a wire with a cut would
give you the same rough operation. You might want to have your mags, wires,
and plugs looked at but it is not likely that your engine suffered any
damage.
2004 California airshow schedule taking shape! Wings Of Fury Aerobatics 0 December 31st 03 05:32 AM
DK-1 All Metal single seat biplane Michael Home Built 0 July 28th 03 05:16 PM
