Well done, Boeing:
BOEING FLIES FUEL CELL AIRCRAFT (http://www.avweb.com/eletter/archive...ll.html#197531) Boeing has successfully flown the world's first fuel-cell-powered aircraft and it took its time announcing it. The Diamond Dimona motorglider has flown three times since February out of an airfield at Ocana, south of Madrid. The aircraft took off on a combination of battery power and the fuel cell but used the fuel cell alone to cruise at 3,300 feet and about 55 knots for 20 minutes. ... Click to watch the video (http://www.avweb.com/avwebflash/excl...7 546-1.html). EXCLUSIVE VIDEO: THE STORY OF BOEING'S HYDROGEN FUEL CELL AIRCRAFT (http://www.avweb.com/eletter/archive...ll.html#197546) (http://media.avweb.com/banmanavweb/a...umber= 741780) http://boeingmedia.com/imageDetail.c...90&clr=release http://www.aviationweek.com/aw/gener.../CELL04038.xml Boeing Fuel Cell Flights Point To UAVs Apr 3, 2008 By Michael Mecham In a series of three flights, Boeing has demonstrated straight and level flight in a two-seat motor glider powered entirely by a hybrid combination of a fuel cell and lithium-ion battery. While the demonstration flights were piloted, Francisco Escarti, managing director of Boeing Research & Technology Europe (BR&TE), says the company's goal is to apply the data BR&TE has collected toward unmanned aerial vehicles (UAVs) to take advantage of a fuel cell's zero CO2 emission count, very low noise levels and insignificant infrared (IR) signature for surveillance flights. ... Made in Austria, the aircraft has a 53.5-foot wingspan, tricycle landing gear and a takeoff weight of 1,850 lb., including the 205 lb. fuel cell (dry weight) and 22 lb. of water as fuel. Flights with pilot Cecilio Barberan at the controls (the second seat was full of instruments) included takeoff and climb out to an altitude of 3,300 ft. under battery- and fuel cell-power. He then switched to the fuel cell only to test performance in cruise at 100 kph (62 mph), followed by a return to the battery/fuel cell combination for landing. "That's about all the speed we could get," says Escarti. Flight time was generally about 30 min. with 20 min. devoted to the fuel cell demonstration. The fuel cell had approximately 10 min. of margin beyond the 20-min. planned for the tests. The first flight on Feb. 7 was for configuration control only and did not include the fuel cell-only test. Two of the three fuel cell test flights were held Feb. 26 with a third on March 8. All flights were conducted in controlled air space above the Ocana air field 40 mi. south of Madrid. Built by Intelligent Energy of the U.K., the Proton Exchange Membrane fuel cell motor delivered 15 kW power in cruise, about what was expected, Escarti says. The lithium-ion batteries were provided by France's SAFT. The flight also was supported by contractors in Germany, Spain and the U.S. - 18 in all. ... The cockpit was unusually quiet, with only the sounds generated by the airframe and the propeller from Germany's MT Propeller. The electrochemical conversion of hydrogen into electricity does generate some heat but Escarti says the signature is so low that would be an IR-plus for a surveillance UAV. While there is opportunity for fuel cells to power manned aircraft, Escarti expects them to play a bigger role in UAVs with wingspans of about 20 ft. For commercial operations, solid oxide fuel cells might be applied to secondary power-generating systems such as auxiliary power units. But as promising as fuel cell's emissions-free operations are for the environment, Boeing doesn't expect them to become primary power sources for commercial aircraft. "The data we collected from the three tests are all that we need," Escarti said in a telephone interview from Madrid. "We won't fly again but this moves us much closer to final product to put into an unmanned aircraft." The end of flights doesn't mean the fuel cell-powered Dimona will disappear, however. It's under consideration for display at this year's Farnborough air show. http://blog.wired.com/cars/2008/04/in-an-aviation.html Boeing Fuel Cell-Powered Plane Takes Flight By Dave Demerjian April 04, 2008 | 2:50:10 ... Madrid-based Boeing Research & Technology Europe led the project, partnering with an international mix of universities and aerospace companies, including SAFT France, Intelligent Energy, and the US-based UQM Technologies. Boeing believes that PEM fuel cell technology has the potential to power small manned and unmanned air vehicles. The company also said that solid oxide fuel cells could eventually play a part in the secondary power-generating systems (think auxiliary power units) of large commercial airplanes, but will likely never provide primary power for large passenger planes. Although the company was quick to point out that this is something they continue to explore, along with a host of other alternative fuels and energy sources. Photo courtesy of Boeing http://www.fuelcellsohio.org/images/...esentation.pdf Boeing Fuel Cell Powered Airplane. Demonstrator. NASA FC APU. http://www.silobreaker.com/DocumentR...em=5_842161168 What others report on the same story... |
"The World's First Jet Powered Beer Cooler" | Bob Fry | General Aviation | 0 | March 2nd 08 01:12 AM |
"The World's First Jet Powered Beer Cooler" | Bob Fry | Piloting | 0 | March 2nd 08 01:12 AM |
"The World's First Jet Powered Beer Cooler" | Bob Fry | Home Built | 0 | March 2nd 08 01:12 AM |
ENvironmentally Friendly Inter City Aircraft powered by Fuel Cells | Larry Dighera | Piloting | 83 | June 11th 07 11:07 PM |
Marine team designs and flies homemade, muscle-powered plane | Otis Willie | Military Aviation | 0 | October 26th 03 12:41 AM |
