During the recent PBS documentary entitled "Carrier," one of the
shooters on the Nimitz described the sequence after a jet on the cat takes tension, demonstrating the hand signals as well. When giving the familiar run up command with two fingers at the end of an elbow bent 90 degrees he said "military power." I assume this is because the retirement of the F-14 means no aircraft launch in afterburner, correct? Or do earlier Hornet variants use A/B off the cat? The shooter then called "combat power" and pumped his fist straight over his head. Finally he did the fencer's lunge just prior to the cat firing. I've heard of "military power," but I've never heard of "combat power." What it is? Is it something peculiar to the Hornet? And if so, does it vary between the Super Hornet and other variants? One final shooter question: Where does the tradition of using the cat to launch the shooters boots off the bow come from? |
| WTB "LucasArts Air Combat Classics" | CaryMG | Simulators | 1 | April 13th 07 06:03 AM |
| "U.S. air power grows in East Asia" | Mike | Naval Aviation | 0 | October 13th 06 08:25 PM |
| FS: 1988 "Air Power" Postcard | J.R. Sinclair | Aviation Marketplace | 0 | May 15th 06 11:40 AM |
