Hi,
A few weeks ago a customer of mine asked me to purchase and setup soaring software on a new iPAQ 210. I have avoided this PDA in the past because it doesn't have a built-in RS-232 serial port. But this customer used a CF GPS so the serial port was not necessary. I was very, very impressed with the 210. I was very pleased to see that this PDA does not have a glass-like shiny screen. I does not need a glare reducer - which is nice since glare reducers reduce the brightness. The 210 uses the same screen size and resolution as found on the iPAQ hx4700 so the screen is very nice. It seems a little brighter than my iPAQ hx4705, but that may be due to the fact that my hx4705 is several years old and lights tend to decrease in brightness over time. Like all other color PDAs, it is not great in sunlight, but I think it is a good or better than any other color PDA I've tested. In fact, I liked it so much, I bought one. A few months ago Kolie Lombard told me that he successfully used a CF Card serial port plugged into the top of his 210 to connect to a Cambridge 302. At the time I thought that sounded a bit ugly and un-rugged, but I've since changed my mind. I now sell the Socket Ruggedized Serial I/O CF Card and a version of the Nimbus cradle that works with the iPAQ 210 and the Socket Ruggedized Serial I/O CF Card. Since the CF card's cable sticks out the top of the PDA it is not quite as elegant as other PDA systems, but it works very well and makes for a pretty clean installation. You can see many photos of the setup he http://www.cumulus-soaring.com/nimbus.htm When connected to a Cambridge 302 or Goddard PS-5a power converter, or LX7007, or LX1600, etc., the DB-9m connector on the end of the Nimbus Cradle's cable has connections for RS-232 serial data as well as 5V power. The 5V power is provided to the PDA through a mini USB connector that is built into the bottom of the cradle. The cable has a DB-9f connector the connects to the DB-9m connector at the end of the short cable on the Socket Ruggedized Serial I/O CF Card. The DB-9f connector is Velcro'd to the back of the Nimbus cradle to keep it secure. Note: The iPAQ 211 and 214 are identical to the 210. New iPAQ 210 units sell for $430. The Socket Ruggedized Serial I/O CF Card sells for $159. The Nimbus cradle with connections for the Socket Ruggedized Serial I/O CF Card sells for $149. It is not the least expensive solution, but it is a very power and nice one. Many soaring pilots looking for a good PDA would much rather buy a new PDA than a used one because they then know it will arrive in perfect condition. The iPAQ 210 is a very, very nice NEW PDA. I think it is going to be very popular with glider pilots. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
FS: Nimbus 4 | Dirk Elber | Soaring | 0 | November 10th 04 09:59 PM |
Nimbus 4 | Ray Gimmey | Soaring | 0 | May 17th 04 06:46 PM |
iPaq wiring, cradles and mounts for gliders - Ideas?? | Jim Kelly | Soaring | 12 | December 4th 03 11:45 PM |
Commercial - iPAQ Cradles In Stock | Paul Remde | Soaring | 0 | October 29th 03 10:57 PM |
F.S. Nimbus 3DM | Tom Stowers | Soaring | 0 | October 18th 03 07:06 PM |
