![]() You are flying a high performance single recip. about two hours south to an airshow you really, really want to go to. In fact, this airshow is an annual thing you haven't missed in years. You are not yet instrument rated but about halfway through the training for commercial & instrument. The enroute forecast is for heavy fog 20 miles south of your departure airport to about 30 miles north of your destination. The fog layer top is consistently 100-200 ft agl the whole way. Ceiling is nil and visibility is 1/4 mile at best in the fog. Above the fog it is clear blue with light winds the whole way. Destination is excellent VFR. Conditions are forecast to remain this way for the duration of your flight. Fog will be gone later in the morning but the destination airport will be closed for the airshow by then. To make it to the airshow in time you must fly over the fog for about an hour & 45 minutes (most of the way). The fog layer stretches 100 miles or more both sides of your intended route, flying around it is unreasonable and would compromise your fuel supply. Go or No-Go? What if it was something more important like a business meeting or a critically ill close relative who may die within hours? How about two engines instead of one? Go or No-Go? Ricky |
"Ricky" wrote in message
... You are flying a high performance single recip. about two hours south to an airshow you really, really want to go to. In fact, this airshow is an annual thing you haven't missed in years. You are not yet instrument rated but about halfway through the training for commercial & instrument. The enroute forecast is for heavy fog 20 miles south of your departure airport to about 30 miles north of your destination. The fog layer top is consistently 100-200 ft agl the whole way. Ceiling is nil and visibility is 1/4 mile at best in the fog. Above the fog it is clear blue with light winds the whole way. Destination is excellent VFR. Conditions are forecast to remain this way for the duration of your flight. Fog will be gone later in the morning but the destination airport will be closed for the airshow by then. To make it to the airshow in time you must fly over the fog for about an hour & 45 minutes (most of the way). The fog layer stretches 100 miles or more both sides of your intended route, flying around it is unreasonable and would compromise your fuel supply. Go or No-Go? What if it was something more important like a business meeting or a critically ill close relative who may die within hours? How about two engines instead of one? Go or No-Go? Ricky The reason for the flight is irrelevant. Personally I have never seen a 200 mile wide section of fog over dry land where conditions were constant over the entire area, but even if such conditions were possible the answer wouldn't be much different than if were a body of water and you had no water survival gear. If you feel comfortable flying a single engine plane over such a stretch, then go for it. Lots of people do. |
"Mike" nospam@ microsoft.com wrote in
: "Ricky" wrote in message news:9b9ea44b-afaf-4864-8d3d-8e19039e8377 @v72g2000hsv.googlegroups.com. .. You are flying a high performance single recip. about two hours south to an airshow you really, really want to go to. In fact, this airshow is an annual thing you haven't missed in years. You are not yet instrument rated but about halfway through the training for commercial & instrument. The enroute forecast is for heavy fog 20 miles south of your departure airport to about 30 miles north of your destination. The fog layer top is consistently 100-200 ft agl the whole way. Ceiling is nil and visibility is 1/4 mile at best in the fog. Above the fog it is clear blue with light winds the whole way. Destination is excellent VFR. Conditions are forecast to remain this way for the duration of your flight. Fog will be gone later in the morning but the destination airport will be closed for the airshow by then. To make it to the airshow in time you must fly over the fog for about an hour & 45 minutes (most of the way). The fog layer stretches 100 miles or more both sides of your intended route, flying around it is unreasonable and would compromise your fuel supply. Go or No-Go? What if it was something more important like a business meeting or a critically ill close relative who may die within hours? How about two engines instead of one? Go or No-Go? Ricky The reason for the flight is irrelevant. Personally I have never seen a 200 mile wide section of fog over dry land where conditions were constant over the entire area, but even if such conditions were possible the answer wouldn't be much different than if were a body of water and you had no water survival gear. If you feel comfortable flying a single engine plane over such a stretch, then go for it. Lots of people do. I've seen this a good few times and have actually flown over it VFR to the end. In a Chief, in fact. We had a way out, but were screwed in the event of an engine failure, of course. I don't think I'd do it now... Bertie |
On Oct 4, 7:47*pm, "Mike" nospam@ microsoft.com wrote:
The reason for the flight is irrelevant. Personally I have never seen a 200 mile wide section of fog over dry land where conditions were constant over the entire area, but even if such conditions were possible I actually flew over this about 10 or so years ago from San Antonio to Harlingen, TX. The fog band was wide enough to make going around unreasonable and it started just south of S.A. and ended not too far north of Harlingen. The fog stretched all the way down to the Gulf Of Mexico and went far north west into Texas, It was huge...and very strange. I remember it like it was yesterday, the nervousness, the constant listening of the wx in Harlingen to make sure it was staying VFR, I was totally preoccupied with wondering what I would find under the plane if my engine failed and I had to go down. In this case an instrument rating wouldn't matter much anyway, except for the experience of being able to fly with a very different-looking horizon and staying upright in the fog if my engine failed. Straight & level flight I found to be somewhat of a challenge for a little while. Today I don't think I'd make the flight, but in a twin I probably would if it was loaded to enable single engine cruise & climb performance. Ricky |
On Sat, 4 Oct 2008 17:32:10 -0700 (PDT), Ricky wrote:
No-Go yep |
wrote: You are flying a high performance single recip. about two hours south to an airshow you really, really want to go to. In fact, this airshow is an annual thing you haven't missed in years. You are not yet instrument rated but about halfway through the training for commercial & instrument. The enroute forecast is for heavy fog 20 miles south of your departure airport to about 30 miles north of your destination. The fog layer top is consistently 100-200 ft agl the whole way. Ceiling is nil and visibility is 1/4 mile at best in the fog. Above the fog it is clear blue with light winds the whole way. Destination is excellent VFR. Conditions are forecast to remain this way for the duration of your flight. Fog will be gone later in the morning but the destination airport will be closed for the airshow by then. To make it to the airshow in time you must fly over the fog for about an hour & 45 minutes (most of the way). The fog layer stretches 100 miles or more both sides of your intended route, flying around it is unreasonable and would compromise your fuel supply. Go or No-Go? What if it was something more important like a business meeting or a critically ill close relative who may die within hours? How about two engines instead of one? Go or No-Go? Ricky whenever you are unsure, or whenever you are sure but the hairs are satnding up on the back of your neck the best bet is to find a window seat, preferably where you can see the weather that approaches, and have a beer while you study the pattern of the weather. Stealth Pilot |
On Oct 5, 8:17*am, Stealth Pilot
wrote: find a window seat, preferably where you can see the weather that approaches, and have a beer while you study the pattern of the weather. Stealth Pilot Well, then I'd have to wait 8 hours if the wx improved. : ) Ricky |
On Sun, 5 Oct 2008 19:47:40 -0700 (PDT), Ricky
wrote: On Oct 5, 8:17*am, Stealth Pilot wrote: find a window seat, preferably where you can see the weather that approaches, and have a beer while you study the pattern of the weather. Stealth Pilot Well, then I'd have to wait 8 hours if the wx improved. : ) Ricky the boy has got it!!!!! when in doubt wait for a while. have a beer. dont be in such a hurry to get the site of your fatal accident. let the moment pass. :-) Stealth (there's hope for you yet) Pilot |
On Oct 4, 8:32*pm, Ricky wrote:
You are flying a high performance single recip. about two hours south to an airshow you really, really want to go to. In fact, this airshow is an annual thing you haven't missed in years. You are not yet instrument rated but about halfway through the training for commercial & instrument. The enroute forecast is for heavy fog 20 miles south of your departure airport to about 30 miles north of your destination. The fog layer top is consistently 100-200 ft agl the whole way. Ceiling is nil and visibility is 1/4 mile at best in the fog. Above the fog it is clear blue with light winds the whole way. Destination is excellent VFR. Conditions are forecast to remain this way for the duration of your flight. Fog will be gone later in the morning but the destination airport will be closed for the airshow by then. To make it to the airshow in time you must fly over the fog for about an hour & 45 minutes (most of the way). The fog layer stretches 100 miles or more both sides of your intended route, flying around it is unreasonable and would compromise your fuel supply. Go or No-Go? What if it was something more important like a business meeting or a critically ill close relative who may die within hours? How about two engines instead of one? Go or No-Go? Ricky This is not much different than complex SEL IMC or even VFR at night, is it? i admit to being one of those IFR rated pilots who does fly at night in IMC so long as destination or comfortable alternates are golden. |
