i'm considering buying a used s10-vt, and have so been flying one in
the x-plane flight simulator extensively as of late. but i think it's model of the control surfaces is inaccurate and so am hoping someone could provide me with some info regarding the flaperons. specifically, an australian POH that i found says there are 6 positions for the flaps: -10, -5, 0, +5, +10, and +16. a brazilian certification form confirms this, and further says that the ailerons can deflect from -16 to +10. what i don't understand, perhaps because i'm new to full-span flaperons, is how the 6 flap positions affect the range through which the ailerons can move. how to say this succinctly... hmmm: irrespective of the flap position, can one always move the ailerons through 26 degrees? in other words, with flaps set at 0, do the ailerons move from -16 to +10, and with flaps at +16, do they then range from 0 to +26? or does it work some other way? i ask, b/c in the x-plane simulator, with full flaps in (+16), aileron input has no effect on flaperon position. essentially there is no roll control with full flaps other than to use the rudder and then wait for the roll coupling. what the x-plane model does is to have flap input limit the upward deflection of the flaperons without increasing the possible downward deflection. and with full flaps, the movement is completely restricted to none at all. this can't be how it really works, or is it? thanks in advance for any info. |
On Thu, 9 Oct 2008 05:47:09 -0700 (PDT), bjarthur
wrote: i ask, b/c in the x-plane simulator, with full flaps in (+16), aileron input has no effect on flaperon position. essentially there is no roll control with full flaps I don't know about the geometry, but I can tell you from my past experience in the S-10V that you have very poor roll control with the ailerons, when flap are set to positive. Not to mention to full positive. If you are not flying very slowly, moving the flap lever to positive and full positive requires a condiderable effort, too. Zero is quite good for manouvres, in the pattern and when centering thermals. Aldo Cernezzi |
On Oct 9, 5:47*am, bjarthur wrote:
can deflect from -16 to +10. *what i don't understand, perhaps because i'm new to full-span flaperons, is how the 6 flap positions affect the range through which the ailerons can move. i ask, b/c in the x-plane simulator, with full flaps in (+16), aileron input has no effect on flaperon position. *essentially there is no roll control with full flaps other than to use the rudder and then wait for the roll coupling. You are right about the settings being -10, -5, 0, +5, +10 and +16. As to flaps and ailerons, I believe all S10's (S10, S10V and S10VT) have the same aileron and flap mixing, but can speak from personal experience only about the VT. It has flaps that run along the inner wing (the wings fold for hangaring) and ailerons along the outer wing. There is a mixer which causes a left or right stick move (an aileron command) to also move the flaps, but the amount of mixing depends on the flap setting. With positive flap settings, stick motions do not (and probably cannot) move the flaps as much. This is most exaggerated at +16. However, even with +16, I have never experienced a problem with inadequate roll response. Compared to some other long wing ships, such as the ASH25, the S10 is quite responsive in roll. The ship is specified to have a 4 sec roll rate from a 45 degree bank to 45 in the other direction. I suspect that is with 0 flaps, but have never timed it. BTW, is the S10VT model included in X-plane's basic software or was that an outside addition. In the latter event, where did you find it? Thanks and hoping this helps. Martin |
thanks martin. but i'm confused now. you make it seem like the flaps
can move independently of the ailerons. the descriptions of the S10 i've seen specify it as having "full-span flaperons", which i took to mean that the inboard and outboard control surfaces on the foldable wings were physically attached when assembled such that they were always at the same angle. if this is not the case, then i think i'm beginning to understand. however, if it's not the case, then why call them flaperons? simply because there is a mixer which coordinates their movement? |
a few responses i've received directly:
============== Don't know about the stemme in particular, but it is quite common for flap positions to affect aileron travel. This happens in my ASW27. The flaps and ailerons move together, so if the flaps are in "down" position, both ailerons are "down." Then the "up" aileron may not be able to move to its full upward position when the stick goes all the way in one direction. For this reason in the ASW27, when you move the flaps to landing position, the ailerons cease to follow along and instead move up to zero degrees, in order to give full aileron authority. I would not be surprised if the programmers of x plane did not include this subtlety of the flap-aileron mixer system. =============== I own an S10 VT and would like to know details about how to get it into the x-plane simulator. Shall be a great way of practicing while at home. By the way, have a look at the Condor Flight Simulator. For soaring training and competition, there is nothing similar. =============== In real life, I use +10 degrees for landing. This gives adequate aileron response for landing. I do not know the technical data for the mixing of the ailerons and flaps but they will reduce roll rate as you increase the flap position toward LAND (+16 degrees). I sometimes use full flaps for landing "short" with light wind or wind down the runway. My initial advice to a new Stemme pilot is to use +10 degrees flaps for landing. =============== Yes you do have aileron control with full landing flaps. It will seem to be a little restrictive and it does fly with a slower roll rate with full flaps but they do continue to control at a slower roll rate. |
you can find the x-plane model of the stemme he
http://forums.x-plane.org/index.php?...&showfile=6392 and can download a trial copy of x-plane he http://x-plane.com/demo.html note that you need version 8 of x-plane, not 9. if there's enough interest, i could update the stemme model to work on 9... I own an S10 VT and would like to know details about how to get it into the x-plane simulator. Shall be a great way of practicing while at home. |
On Oct 10, 11:45*am, bjarthur wrote:
thanks martin. *but i'm confused now. *you make it seem like the flaps can move independently of the ailerons. *the descriptions of the S10 i've seen specify it as having "full-span flaperons", which i took to mean that the inboard and outboard control surfaces on the foldable wings were physically attached when assembled such that they were always at the same angle. *if this is not the case, then i think i'm beginning to understand. *however, if it's not the case, then why call them flaperons? *simply because there is a mixer which coordinates their movement? The flaps and ailerons can move somewhat independently, being connected via the "mixer" I mentioned. In any event, roll response in a Stemme is very good for such a long-winged (23 meter) ship. Hope this helps. Martin |
Stemme | Mal[_4_] | Soaring | 2 | June 23rd 07 03:17 AM |
Stemme S10 VT | Mal | Soaring | 1 | August 29th 06 04:15 PM |
Who got the dipped Stemme? | Bob Kuykendall | Soaring | 0 | November 19th 05 12:43 AM |
LS3 flaperon gap seal template needed | Birdbones | Soaring | 2 | May 14th 05 12:46 AM |
FS Stemme S 10V | soarski | Soaring | 1 | January 24th 05 10:09 PM |
