Outside Air Tempeture Instrument in Glider
Old October 28th 08, 01:26 PM posted to rec.aviation.soaring
Default Outside Air Tempeture Instrument in Glider
I plan on installing a tempeture guage inside the cockpit of my
glider. I think it's a good thing to have that can add to safety.
For instance, it's nice to know just how hot it is during those summer
days on a short runway. Also, to know if your in potential icing
conditions at altitudes. I've hit some bad icing before in the
spring, at 15,000 feet that iced over my windshield so bad I couldn't
see out even with the windshield heat on (in an aircraft).
Most of all, I'm real interested to find out if anyone has installed
one and noticed a tempeture change when entering a thermal?
Can it be used, in anyway, to help center a thermal? Seek out a
thermal?
Old October 28th 08, 03:20 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
On Tue, 28 Oct 2008 06:26:14 -0700, scottandrewalexander wrote:
Most of all, I'm real interested to find out if anyone has installed one
Its normal to use a sensitive thermistor-based temperature sensor to find
thermals when flying Free Flight duration models in a contest. The usual
temperature swing when a thermal blows through is about 1 degree
Centigrade though it can vary from 0.5 to 2 degrees depending on weather
etc. with the measurement made at around 5m. Secondly, you need a fast
response, which means a very small thermistor bead (no bigger than 0.8mm
diameter and under 0.5 mm is preferable) and it must be a naked bead -
common units which enclose the bead in plastic or metal probes are
useless because their response lags the actual temperature change by
anything up to 30 seconds.
I've never made or heard about comparable measurements at flying heights
and would be interested to hear if anybody else has measurements above
ground level. For the moment lets assume the same temperature range is
found at flying height.
thermal?
You'd need a read-out with a resolution of at least 0.1C to be able to
reliably see the shape and position of a thermal so if your read-out
isn't that accurate you're on a hiding to nothing: my SDI C4 only reads
in whole degrees. Last but not least, its thermistor is buried in a 3mm
diameter plastic housing, so while its fine for monitoring the average
air temp or spotting icing conditions, its response is far too slow to
find thermals: a good vario has a 2-4 sec response, so it follows that
the thermistor-based thermal detector must have a similar response rate.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 28th 08, 07:32 PM posted to rec.aviation.soaring
Mike125
Its my understanding that the thermal reaches the ambient air temp
pretty quickly due to nearby air being entrained. Its the water vapor,
being less dense than dry air, that makes the parcel of air bouyant
and inertia contributes as well. Could be wrong, though.
Mike
Exporting a glider to/import a glider into Germany Pete Smith[_2_] Soaring 1 August 8th 08 09:33 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Gleim Instrument Pilot Audio CD Set AND Gleim Instrument Pilot FAA Test Prep Software - together on Ebay Cecil E. Chapman Products 0 January 14th 04 11:34 PM
