Lacquer
Old November 21st 08, 05:15 PM posted to rec.aviation.soaring
Roger Fowler[_2_]
Default Lacquer
Does anyone have a source for dark gray lacquer for painting contest
numbers on a sailplane? Preferably in the US. I know it is old
fashioned, but that is what I want to do.
Thanks in advance,
Roger
Old November 21st 08, 06:04 PM posted to rec.aviation.soaring
Tim Mara[_2_]
Default Lacquer
it's call "Krylon" available at Home Depot's everywhere!
A rattle can of any kind does the job just fine...simple enamel spray paint
goes on easy and comes off later on without much difficulty when you change
the numbers.....or use vinyl transfers...easier, just as nice or nicer done
and you can do any fancy font or design you want...even today fancy graphics
can be used....if you can dream it up the design can be done
tim
"Roger Fowler" wrote in message
Thanks in advance,
Roger
Old November 21st 08, 06:25 PM posted to rec.aviation.soaring
bildan
Default Lacquer
Yep, Krylon rattle cans - $1.20 each at Wallmart.
Interestingly, this stuff is completely compatible with gelcoat. The
white primer is an exact color match for white gelcoat and polishes up
nicely. It can even be used for minor scratch repair.
tim
Please visit the Wings & Wheels website atwww.wingsandwheels.com
numbers on a sailplane? *Preferably in the US. *I know it is old
Thanks in advance,
Roger
Old November 21st 08, 10:03 PM posted to rec.aviation.soaring
Craig[_2_]
Default Lacquer
Interestingly, this stuff is completely compatible with gelcoat. *The
nicely. *It can even be used for minor scratch repair.
tim
Thanks in advance,
Roger
Your local autobody supply shop should be able to help you out. Use a
nice slow thinner like DuPont 3602s and thin to about the consistency
of whole milk. Build up the finish in several coats to avoid
running. Mask with 3M Fineline. Before removing the fineline,
wetsand the tape edge that defines your lettering so that the paint is
removed from the fineline. This way when you pull the tape you'll get
nice crisp edges. Block out any orangepeel with 400 wet (carefully)
and finish out with 600 and buffing. Best of luck.
Craig Funston
Old November 22nd 08, 07:24 PM posted to rec.aviation.soaring
Ed
Default Lacquer
On Fri, 21 Nov 2008 13:04:11 -0500, "Tim Mara"
tim
If you intend to hand letter on your surface I think an automotive
paint store or a sign supply shop could supply the laquer that pin
strippers use which is slower drying. I don't know where you are
located, but there is a good sign supply house in Sacramento. The name
is Product Sign Supply 800-660-0553
Ed Sullivan
Old November 22nd 08, 10:18 PM posted to rec.aviation.soaring
Ed
Default Lacquer
tim
Ed Sullivan
I may have spoken too soon, apparently they are now using 1 stroke
lettering enamel. You should use a quill lettering brush if you plan
on hand lettering.
Old November 25th 08, 05:00 PM posted to rec.aviation.soaring
Roger Fowler[_2_]
Default Lacquer
Thanks, all for the suggestions.
Roger
paint
change
done
graphics
tim
Ed Sullivan
on hand lettering.
Lacquer thinner on gel coat Steve Freeman Soaring 8 July 3rd 07 05:34 PM
Butyrate, lacquer thinner, STC,etc [email protected] Home Built 3 June 16th 05 05:55 PM
