Komet trailer wheel bearings
Old February 1st 09, 07:09 PM posted to rec.aviation.soaring
Dan[_6_]
Default Komet trailer wheel bearings
anyone ever re-packed the whell bearings on a Komet trailer?
I don't know when this was last done on my trailer but I'm thinking
it's something I should do this winter.
Dan
Old February 1st 09, 08:11 PM posted to rec.aviation.soaring
Darryl Ramm
Dan
There should be nothing difficult in this. There are good sources of
info online, one of the best is this boat trailer info at
http://www.sailingtexas.com/Movies/T...rbearings.html
I don't know if or when Komet switched to used sealed wheel bearings
like Cobra.
If my trailer did not have sealed wheel bearings, personally I'd be
doing this annually, especially if stored in high moisture/coastal
areas. And check out brakes, suspension, etc. carefully at the same
time.
Rex Mayes gave a great talk on glider trailer maintenance a few weeks
ago. We need to get Rex or John Murray or others who give these talks
on video some time.
Darryl
Old February 2nd 09, 04:32 AM posted to rec.aviation.soaring
Dan[_6_]
Dan
info online, one of the best is this boat trailer info athttp://www.sailingtexas.com/Movies/TrailerBearings/trailerbearings.html
like Cobra.
time.
on video some time.
Darryl
thanks Daryl;
That video was very helpful.
I really appreciate it.
Take care,
Dan
Old February 2nd 09, 02:05 PM posted to rec.aviation.soaring
Papa3
Dan
Coming in a little late, but...
Nothing to it. I did mine several times when I owned my old (circa
1981) Komet. It was about an hour to maybe an hour and a half to
finish both sides. Pull the wheel. Pry off the cap. Unpin the
castelated nut. Loosen nut. Pull the hub.
Was there something specific that got you wondering?
Regards,
Erik Mann
LS8-18 P3
Old February 2nd 09, 07:47 PM posted to rec.aviation.soaring
Dan[_6_]
Dan
Nothing to it. *I did mine several times when I owned my old (circa
1981) Komet. * It was about an hour to maybe an hour and a half to
finish both sides. *Pull the wheel. *Pry off the cap. * Unpin the
castelated nut. *Loosen nut. * Pull the hub.
Regards,
Erik Mann
LS8-18 P3
I wasn't sure if all Komet trailers had sealed bearings or not, guess
I'll have to look. I don't know the vintage of my trailer.
The video Daryl posted is excellent.
I'll check it out this weekend
Thanks,
Dan
Old February 2nd 09, 09:08 PM posted to rec.aviation.soaring
Dan
Regards,
Erik Mann
LS8-18 P3
Aren't you going to need a replacement inner seal? In order to get the
bearing out of the hub, the seal needs to get pulled. I don't know
about you, but I've never been able to do that without damaging it.
Old February 3rd 09, 02:25 AM posted to rec.aviation.soaring
Papa3
Dan
Regards,
Erik Mann
LS8-18 P3
about you, but I've never been able to do that without damaging it.- Hide quoted text -
- Show quoted text -
IIRC, I was able to punch out the seal using a custom built "bearing
removal impact application device"; i.e. I turned a piece of scrap to
the right diameter to fit the inner bearing race and apply force
uniformly. I could be confusing this one with a Shroeder that I also
worked on... I'll have to go look at my old notebook where I wrote
this sort of stuff down.
Old February 9th 09, 06:13 AM posted to rec.aviation.soaring
Dan[_6_]
Dan
Regards,
Erik Mann
LS8-18 P3
uniformly. * I could be confusing this one with a Shroeder that I also
worked on... *I'll have to go look at my old notebook where I wrote
this sort of stuff down.- Hide quoted text -
Thanks to all for the help.
I re-packed the bearings and put new rubber on the trailer this
weekend.
The bearings were not the sealed type so it was good to check them and
re-grease them.
All set to go for many more miles.
Dan Rihn
WO
Komet III wheel info Gary Emerson Soaring 2 February 4th 09 03:14 AM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
Komet trailer strut John Shelton Soaring 5 November 15th 03 05:04 PM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
