LS4 GPS ant location
Old February 20th 09, 07:20 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Default LS4 GPS ant location
I am planning to mount a GPS/NAV M10 in a LS4. The unit is mounted in the
baggage area. I know 2 LS pilots had to mount the antenna remote from the
unit to get a signal (LS6, LS3) and a ASW 19 owner had no problem with
signal in the package area.
Antenna mount in package area would be easier, so is preferred.
Looking for experienced advice, preferrably LS4 drivers.
Thanks in advance
Hartley Falbaum
Old February 21st 09, 01:22 AM posted to rec.aviation.soaring
JS
I've flown LS-4, 6 and 7 with a GPS-NAV 10 or 20 in the baggage area.
Wasn't a problem. Might be if you pile too much gear on top, or if
it's right next to a metal battery box like the Dittel.
The original model 10 antenna tends to flop over. Either use a flat
external antenna or put a rubber O-ring inside the BNC connector.
Old February 22nd 09, 01:10 AM posted to rec.aviation.soaring
HL Falbaum[_2_]
Thanks
That helps.
Hartley Falbaum
"JS" wrote in message
OLC Take-off location Wayne Paul Soaring 5 May 8th 07 03:41 PM
GPS Antenna Location Kevin Neave Soaring 6 November 25th 06 12:50 AM
ELT Location in HpH 304 Kevin Parker Soaring 5 March 17th 06 06:19 PM
ELT location for V2C [email protected] Soaring 5 October 11th 05 04:13 PM
Question of Location... Robbie S. Owning 15 March 9th 05 01:33 PM
